PNW Chit Chat thread
    short or loose connection.
    Determine if it's intermittent or consistent. If you can, start from the battery and work your way forward to dash harness testing to see if you can recreate it.
    2016 Ford Flex
      It's not doing it now. Will go screw with it in a while.
      '72 2002 | '88 M5 | '89 330is | '89 M3 | '95 911 | '02 M5 | '04 RR HSE
        I got CB'd by my iPhone.
        '89 Schwarz E30 M3 Cabriolet Build
          no reason to not try it the other way ill do it if you want sat morning. Ive done a few before.
          -Alex
            Anyone know of a good way to get the coolant temp sensor out on a m20b25? im replacing mine, but its soooo damn cramped in there?!
            91' 318iS - S54/6MT Swapped
            08' E90 M3 6MT - Daily
            Originally posted by IronJoe
            Originally posted by 2mAn
              Just did my M50 one. Mine was way in there, behind the intake manifold. Good luck!
                Originally posted by MickeyFinn503 View Post
                Sounds like a short to me but I have no idea.
                A 'short' is when voltage from the positive side of your battery finds a path directly back to the ground side without resistance, aka a hot fucking fire if said path is not fused.
                Sounds to me like you've got the opposite dude. Check both battery connections and all your grounds.
                  Many thanks, good sir.
                    From today. Love my Natty's Blue wax :) I didn't let it haze long enough and it didn't come off very easy
                      geese, i just checked my e-mail that i haven't checked in a few days. i have 8 different tracking numbers from a bunch of crap ive ordered for my car lol, most is supposed to be delivered tomorrow, good thing the wife will be home.
                      Originally posted by nwvb bmw
                      That guy is going to lock you in his basement and make you ware a little pirate costume.
                        I love getting tracking number emails. Makes me feel like a little kid waiting for a present. Same thing with when I walk up to the door and there are boxes stacked outside!
                        84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
                          x2222
                          Bahama Beige E23 Project
                          Bluebird Bus Conversion
                          New Oregon Trail
                            Use a box-ended wrench. I did it a few months back, and it was a bit of a biatch. Think I ended up beating the hell out of my hands trying to squeeze in there.
                            2016 Ford Flex
                              lol very true, same way that i feel. i just know i have a lot of work ahead of me. swapping out steering racks, changing oil pan gasket, rewiring for the ellips and HID's, hooking up the LED's and computer fans for my amp rack as well as cutting some lexan for the window. etc etc. going to be a busy weekend.
                                x3!!!!!!!!!
                                I hear you, I just installed US ellips so now they need 9011/9012 bulbs, there's a Lukebox on its way needing an amp too.
                                I also need to do the oil pan gaskets (upper and lower woooo M10 :|). My control arms have unknown mileage and the ball joints and bushings are going slowly. Plus while I'm under there I should do the rust-covered clutch slave. But then I should probably do the clutch master as well! I hope to do it all together but have been putting it off since I don't have an actual garage...
                                Labor of love. Knock that ish out! I'm already loving the projector headlights and fogs for the rainy season... tight steering will be a must soon too.
                                balticblau-metallic '84 318i 5spd 3.91 LSD
