PNW Chit Chat thread
  • DER E30
    • Sep 2013
    • 2349
    #31036
    How does the tach work? Can you plug the gauge cluster into something from the LS ECU or run your own FW mounted trigger wheel and such.
    I'd assume you leave the gas gauge alone, and run standalone sensors for coolant and oil?? E30 comp running the gauges and that;s all?
    -Christian
    • Wschnitz
      • 8089
      #31037
      Iirc its not to hard to modify e30 cluster to avoid a ton of aftermarket guages clutter. Only hard one would probably be tach and temp.
      willschnitz
      • DER E30
        • Sep 2013
        • 2349
        #31038
        Looking in my e30 electrical troubleshooting manual and in the haynes manual the tach and eco meter get info from the ecm but the low oil light has a simple switch on the motor with one wire and the coolant gauge is the same with a standalone sensor. Those two can be out into the LS pretty easily, just the Tach would need some extra hacking to make work or a replacement.
        edit: Do we know if the speedo itself does the math to figure out speed?
        Edit2 NVM, the speedo does its own thing without ECM
        -Christian
        • Wschnitz
          • 8089
          #31039
          Almost certain it does its own measurements. Takes diff input and does the maths.
          willschnitz
          • OldDrunkenSailor
            • 2271
            #31040
            You should get the LS1E30 manual, worth the investment, lots of diagrams and instructions and such. And Garret is a great guy.
            Tach works pretty easily as long as it has the 4cyl chip in it, the v8 meshes fine with it.
            Alpha Team Inductee
            2014 Icon E-Flyer
            2013 Zboard San Francisco Special
            2010 Buell XB9SX
            2009 Harley-Davidson 883 Iron - "Xerces"
            1991 BMW 362iS Touring - "Stephanie/The Death Machine 2.0"
            1974 Honda CB360/CL360 Scrambler Project
            1971 Honda Trail 90 - "Stephen Parish"
            2008 Saab 9-3 Convertible
            2002 Mazda Miata LS
            • iansane
              • 1342
              #31041
              The tach would be ridiculously easy. With HPtuners or whatever software you plan on deleting VATS and emission stuff you can change the tach output to match whatever cluster you want. The typical LS tach is actually a 4 cyl output. When I swapped the LS into my trans am it read half the rpm it should have until I changed the output. I'd imagine your 4cyl coding plug would take the factory LS output well.
              I'm accruing parts to the the LS swap as well. I did the massive booster delete.
              84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
              • DER E30
                • Sep 2013
                • 2349
                #31042
                Have you driven the car with the delete kit? How feels?
                -Christian
                • iansane
                  • 1342
                  #31043
                  I did the massive booster delete and corrado rotor/wilwood caliper upgrade at the same time. I split daily driver duty between my trans am and e30 with manual brakes. Yes, the pedal is fairly long but all the braking ability is there, it's just easier to modulate over the whole pedal stroke.
                  • iansane
                    • 1342
                    #31044
                    I'm just going to leave this here.
                    How are everyone's winter projects going?
                    • Wschnitz
                      • 8089
                      #31045
                      Anyone got a good powdercoating place? Could even be standard wheel refinishing. But Gonna get the hartges re coated eventually and want the silver to match the Hartge caps silver.
                      willschnitz
                      • e30austin
                        • 15382
                        #31046
                        Slow as fuck. Hoping mine will be done sometime this year...
                        • kid325e
                          • Sep 2007
                          • 6422
                          #31047
                          Dude, I finally put the pieces together. I've been seeing your car driving up and down Bothell Way in the morning while i'm waiting for the bus at the Park and Ride. I drive my iX down there in the AM and drive it home at night. I figured I would have known/heard of you or at least known you from r3v... now I know. The rear flares are killer man!
                          I think i've seen you putting around in your Trans Am too. Funny when I saw/heard it I knew it couldn't be stock. Super clean.
                          If you see my four door ix on black wheels driving around flash your highs at me. I think i've done it to you a few times and got no response. :(
                          clutchCTRL!
                          Move with a purpose.
                          - 1991 325iX 4dr/5spd
                          - 2000 323i AT
                          2016 Mazda CX3 Sport AWD
                          • kid325e
                            • Sep 2007
                            • 6422
                            #31048
                            Now that I think of it.. I just looked at what a 91 Trans Am looks like.. Looks alot like this guy that always pulls out of Oreilly as i'm waiting to get on Bothell Way from the Park and Ride. Always wondered why that Trans Am would rush out of the parking lot (TOP DOWN/FOGS ON) and kinda tailing/riding next to me.
                            That you?
                            clutchCTRL!
                            - 2000 323i AT
                            • 5Toes
                              • 9836
                              #31049
                              made a clutch stop today for the E28, loving it!!! Total cost $1
                              • iansane
                                • 1342
                                #31050
                                That you?
                                Yeah man, that's me. I saw your car awhile back and tried bombing out to give you a thumbs up but you never looked over. It looks good!
