PNW Chit Chat thread
  • imjusthere
    • Jul 2014
    • 119
    #36661
    Hey guys! I need a working blinker stalk for a non airbag car. I was trying to find one with the obc function but haven't had any luck so now any stalk will do. I just want to get this thing fixed. Anyone got one I can buy?
    • UgkNW*
      • Oct 2013
      • 259
      #36662
      I bent the plate back. Flywheel doesn't touch.
      I have one more issue I just noticed. 1 of the two tabs at the back of the trans broke. Can I still keep going or does it have to be welded on?
      • UgkNW*
        • Oct 2013
        • 259
        #36663
        Here's the tab thing off the trans.. Am I good or do I need someone to weld back on
        • djjerme
          • 5082
          #36664
          I wouldn't try rewelding it, and using it as is - too much stress on that mount point.
          Reach out to John Parker. It's happens often enough in race cars that there's a bunch of ways to change the way the tranny is mounted. Usually they involve some sort of bracket being fab'ed that cradles the tranny.
          2016 Ford Flex
          • UgkNW*
            • Oct 2013
            • 259
            #36665
            Thanks ^.
            • 5Toes
              • 9836
              #36666
              Drove to Seattle on $6 of premium last night, about 75 miles. gutted m42 + 3.25 + low rolling resistance tires = best e30 hypermiling setup.
              • EN318isPDX
                • Oct 2007
                • 4373
                #36667
                repost.
                • e30austin
                  • 15382
                  #36668
                  Originally posted by EN318isPDX
                  repost.
                  Seriously, change the fucking record already... :roll:
                  '70 911s | '72 2002 | '88 M5 | '89 330is | '89 M3 | '95 911 | '02 M5 | '04 RR HSE
                  • BraveUlysses
                    • Jun 2007
                    • 3781
                    #36669
                    time to buy a prius and mod it
                    • DrJosh
                      • 2011
                      #36670
                      My S5 goes through $6 of premium just looking at it.
                      Originally posted by Sonny
                      I am a meme for our community.
                      • Matt-B
                        The Waffler
                        • 3856
                        #36671
                        But you are not pulling nearly as many bitches
                        • UgkNW*
                          • Oct 2013
                          • 259
                          #36672
                          Can some one please school me on how I remove the shifter ball bushing 25111469397. Thanks
                          • Matt-B
                            The Waffler
                            • 3856
                            #36673
                            U have to "implode" it inward with a few small screw drivers and twist it
                            • 5Toes
                              • 9836
                              #36674
                              UGKNW dont listen to that crapy technqiue
                              get two right angle shaped picks/pry tools. the two tabs on the sides at 3 oclock and 9 oclock need to get pushed in, and then with a sharp tug the whole white cup bushing will come out the top. the design is hard to figure out at first but those lock tabs are the most important.
                              you may find that the bushing is spun around out of the correct orientation so just orient it correctly then push those tabs in.
                              • Matt-B
                                The Waffler
                                • 3856
                                #36675
                                Then drop in a fully built m42, with low rolling resistance tires.
                                Easiest 500hp and 50mpg you can get
