Originally posted by LuckyHenriksen
View Post
PNW Chit Chat thread
Who wants to help me hunt down my 1222 code?
Symtoms,
occasional high idle
occasional hard start, not exactly hot or cold, just very random and not very common.
Feels a bit down on power.
I was poking around the engine bay with the engine running looking for any broken hoses. When I squeezed the vacuum line for the fuel pressure regulator my idle stopped and didn't come back till i revved the engine a couple times. Also, when the car doesn't want to start I give the gas pedal a pump or two and it starts up just fine.
Do you guys think it could be the FPR? And what is a good and safe way to test the fuel pressure?Last edited by DrJosh; 01-27-2012, 05:34 PM.Originally posted by SonnyI am a meme for our community.
O2 sensor, good sir. Worth a shot, at least.
Got my broken subframe bolts tapped and out. Went and bought 10 grade bolts. Hopefully those fuckers don't snap now. Detailing my car for XXX at the moment and getting a parts pile ready to go so all I have to do in the morning is load up and hit the road!'72 2002 | '88 M5 | '89 330is | '89 M3 | '95 911 | '02 M5 | '04 RR HSE
Good luck getting it back together! I wouldn't drive it with those two bolts broken.
Is there a way to test the O2 sensor short of swapping it out? I would swap it out but I don't have one nor do I want to buy one if this isn't the issue.Originally posted by SonnyI am a meme for our community.
Originally posted by 5Toes View PostWell it appears that m3 springs are the same just 6 coils (instead of 7 like on 325i's)
THe higher spring rate of m3 springs may be because they are just shorter, because cutting sprigns does increase spring rate. The wire thickness/gauge is the same
SO that means one coil off front should lower car half an inch, and I am 9mm or so lower without the spring pads and the e90 drop hats (which are awesome BTW)
Additionally, the M3 and 325i share the same front struts, which means I shouldnt blow them if I go m3 height
Originally posted by AbeSonic View PostWhat he said. Or, just buy lowering springs. No chopping required.Transaction Feedback: -click here
[e30: '91 318is coupe|brilliantrot||e36: '98 318ti|fern green|California top|M-Tech]
[URL="http://www.r3vlimited.com/board/showthread.php?t=300453"]
Originally posted by DrJosh View PostHere is my 02 sensor.
It looks okay, I think. Of course that doesn't mean its in working order but I don't see any signs of it being contaminated from say a leaky head gasket or running rich/lean.'72 2002 | '88 M5 | '89 330is | '89 M3 | '95 911 | '02 M5 | '04 RR HSE
