PNW Chit Chat thread
  • e30austin
    • 15382
    #6451
    Originally posted by DrJosh
    Okay sounds good.
    It is OEM though right?
    Yessir. OEM Bosch.
    • DrJosh
      • 2011
      #6452
      Originally posted by Ryann
      ^1222 can be caused by a lot of different things man.
      Yup. Thats why I am checking things out. But according to my voltmeter the O2 sensor is looking dead. which would explain my terrible gas milage and being down on power if it is the case.
      Originally posted by Sonny
      I am a meme for our community.
      • DrJosh
        • 2011
        #6453
        Originally posted by MickeyFinn503
        Yessir. OEM Bosch.
        Great. Please remember to grab it in the morning or I might cry. When are you coming up tomorrow?
        • Ryann
          • 3350
          #6454
          ^1222 means that the DME has detected a rich or lean running condition, which also usually means that the O2 sensor is doing its job and telling the DME what's going on.
          • e30austin
            • 15382
            #6455
            I'm at the blazer game now but I have to go back to the shop to get my parts pile together, so I'll grab it!
            • Mullet Bullet
              • May 2011
              • 904
              #6456
              Originally posted by iansane
              Can you modify one primary tube on a turbo header I have? :)
              sure can, what do you need done? PM me and we can figure it out.
              Originally posted by nwvb bmw
              That guy is going to lock you in his basement and make you ware a little pirate costume.
              • DrJosh
                • 2011
                #6457
                Couldn't it also mean that the O2 sensor has gone out or is giving a false reading?
                We will see what a new O2 sensor does. Even if its not the problem, id rather buy the nearly new one for the sake of replacing it since I have no idea when it was last replaced if at all.
                If this doesn't work I may jump to fueling. I have a new fuel filter sitting in a box and I have been thinking of rebuilding my injectors. I need to find a good write up on how to check the fuel pressure on the M20. I am going to look in the bentley later to see what it says.
                • Ryann
                  • 3350
                  #6458
                  ^That would typically be a 1221.
                  • DrJosh
                    • 2011
                    #6459
                    Ah okay I see that now as well.
                    Isn't it fairly common for a bad engine temp sensor to cause warm starting issues?
                    • Ryann
                      • 3350
                      #6460
                      In my experience vacuum leaks are the most common cause of warm start issues in Bosch systems. A significant vacuum leak could also cause a lean condition, which could cause the DME to throw a 1222.
                      • DrJosh
                        • 2011
                        #6461
                        Is the gas tank part of the vacuum system?
                        • Ryann
                          • 3350
                          #6462
                          No, but if it wasn't venting properly it could cause fuel delivery issues.
                          • DrJosh
                            • 2011
                            #6463
                            Okay so at least I am stuck in the engine bay looking for leaks. I suspect injectors or intake manifold because pretty everything other then their gaskets/o-rings have been replaced.
                            Is there a way to tell if the brake booster is leaking?
                            • AbeSonic
                              Price check on Vagiclean, aisle five. I repeat: price check on Vagiclean, aisle five. That's Vagiclean. We've got a customer down here with a full-on fallopian fungus. I'm baking a loaf of bread and I think it's sourdough.
                              • 3635
                              #6464
                              Can you get away with murder? Because the Blazers just did! :shock:
                              out dated sig is out dated
                              • Keith M
                                • 2338
                                #6465
                                What happened Abe?
