PNW Chit Chat thread
  • 2mAn
    Señior Mod
    • 21049
    #11101
    installed a new v-belt on my car after the last one decided to self destruct. felt like the tension was good, but im still getting belt slippage at 3k and above....
    im worried i might overtighten this one and have it commit suicide also.
    tips?
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
    • iansane
      • 1343
      #11102
      Originally posted by 5Toes
      Quick question. Do you people often use standard e30 rear struts when doing coilover conversions. Or is there some other ones people use when wanting to go low?
      I've heard f-body (camaro/firebird 82-02) rear shocks are a bit shorter than e30 shocks with very similar mounting.
      84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
      • e30Rooster
        • Jan 2010
        • 958
        #11103
        tips?
        when you push down on it with your thumb you want it to move right around 1/2 inch.
        hows the VW going?
        • Gerta
          • Sep 2009
          • 2119
          #11104
          Originally posted by bmwm42
          16V ftw everything else is just eghhhhh
          ^this.
          Sent from my DROID RAZR using Tapatalk 2
          Parts Collector and Former Houndstooth interior junkie.
          • 5Toes
            • 9836
            #11105
            had a vbelt issue on my car too, it was a bit too tight so it was squeeking.
            • HarukoE30
              • Nov 2011
              • 1057
              #11106
              tips?
              l
              l
              l
              l
              l
              V
              Originally posted by James Crivellone
              1) The internet is NOT serious business.
              • Keith M
                • 2338
                #11107
                Could also be that there is a groove in the pulley meaning the surface area of the belt only touches a portion on the pulley.
                • iansane
                  • 1343
                  #11108
                  Does anyone know if the early e cars use the same 60-2 crank position setup as the later cars? (obviously not in the same location, but the same tooth count/setup?)
                  • Ryann
                    • 3350
                    #11109
                    I installed these on my '91 318i. Requires pressing out the lower F body bushings and reusing the e30 ones. Also requires partial loading of the suspension in order to fit the lower bushings over the mounts, so they are substantially shorter.
                    • PNWDan
                      • Feb 2011
                      • 1326
                      #11110
                      I use to be a 20 valve guy myself.
                      1987 Alpinweiß 325is
                      Like the PNW E30 Local Crew Facebook page
                      • 2mAn
                        Señior Mod
                        • 21049
                        #11111
                        looks like all the abuse ive thrown at the car is finally starting to show...
                        im getting a vibration at low speeds/ low rpms in the driveshaft. CSB? guibo?? im getting under the car soon to do some other work so im hoping to fix at the same time
                        Simon
                        Current Cars:
                        -1966 Blue Boat
                        -1969 Red VW
                        -1986 White BMW
                        -2006 Green Thing
                        • BBDirtbiking
                          • Apr 2012
                          • 323
                          #11112
                          Most likely the CSB, they love to fail on these cars.
                          "Bayerische Motoren Werke - freude am fahren."
                          Brandon {Current: 1991 318iS, 2007 328i, 2014 X5 xDrive35d | Past: 1992 525i, 1997 528i, 1999 540i}
                          • e30austin
                            • 15382
                            #11113
                            Mine completely ripped from the housing about a month ago. Changing that at midnight with no parts stores being open was so much fun...
                            I'd put money on a CSB. When I pulled my driveshaft, the guibo was starting to show some wear, so I changed it at the same time.
                            • e30austin
                              • 15382
                              #11114
                              Heater core just took a shit. Yayyyyy
                              • brutus87
                                • 6280
                                #11115
                                Just remember that at some point you will have replaced everything on that car lol.
                                sorry man, least it's not an E28 heater core
