M50 swap that will blow your mind.
  • Zoncers
    • Aug 2012
    • 10
    #181
    Originally posted by Zoncers
    Any one making these clevis pins for e90 booster in e30? I'm currently doing this but stuck on the pin.
    Its dead around here. Guess every one bought a tesla?
    • Victell
      • 1083
      #182
      Forums abandoned for social media. Try the R3V FB group.
      • Northern
        I like cupcakes & sh!tboxes
        • 5287
        #183
        I found a guy who made pins on Facebook by searching one of the e30 groups (probably r3v facebook), but he hasn't done a run since I asked him.
        Seems like the pedal is the wrong height anyway, so I'm probably going to end up cutting the clevis off the booster and extending the rod.
        Originally posted by priapism
        Originally posted by shameson
        • TheGreatDecay
          • Nov 2020
          • 46
          #184
          I just ordered a e83 X3 booster off ebay yesterday. Curious to see how it mocks up
          • Chilezen
            I weld cats
            • Dec 2013
            • 1944
            #185
            I regret choosing the X3 booster. I'd order a Euro E90 booster if I were to do it again.
            The widest part of the X3 booster really digs into the corner of the manifold. Nothing I can do except shim the engine arm up with a big washer.
            Currently building a badass coffee table
            Random stuff on insta @kevanromero
            • TheGreatDecay
              • Nov 2020
              • 46
              #186
              Originally posted by Chilezen
              I regret choosing the X3 booster. I'd order a Euro E90 booster if I were to do it again. The widest part of the X3 booster really digs into the corner of the manifold. Nothing I can do except shim the engine arm up with a big washer.
              Which mounts did you run? M50 manifold?
              • Chilezen
                I weld cats
                • Dec 2013
                • 1944
                #187
                AKG black poly mounts with an M52 manifold, fins shaved. Still need the washer to prevent contact.
                • eternal24k
                  • Jul 2017
                  • 507
                  #188
                  I'm running black AKG mounts and M50 manifold, i shaved the fins on the manifold but have enough clearance where i can swap the booster without removing the manifold
                  • CavemanGB
                    • Sep 2019
                    • 31
                    #189
                    Anyone use this pin for the e90 booster since the OP is MIA? Half tempted to try it
                    https://www.ebay.com/itm/32483988650...3ABFBMqMbBiM9f
                    • Staszek
                      • 2533
                      #190
                      I did when I was planning on doing using the E90 booster. I ended up using the 944 due to the E90 sticking out to much for my S54.
                      • Chilezen
                        I weld cats
                        • Dec 2013
                        • 1944
                        #191
                        Now that I finally have my car up and running, having driven it around, I can share my thoughts on the X3/E83 Booster.
                        Pedal pressure feels good, natural. It's not a crazy amount of assist. I expected the dual-diaphragm to be over-assisted, but it's not. So far, it feels just right to me. Heel-toes feel good. I haven't done any spirited driving yet, but I think it'll be fine. So yes I would *tentatively* recommend it. I say this because the Euro E90 booster should feel the same but has better fitment. Totally would be worth it.
                        Also, I would go for a pre-made clevis pin.
                        My biggest complaint isn't about the booster- it's the engine mounts! When I was comparing mounts, it seemed the the black AKG mounts would be the softest. But the car has a vibration at idle, and that's where I trace it to. I'm disappointed in that. Does anyone else have a comment about their mounts? Would love to know.
                        • mtech325
                          • May 2008
                          • 572
                          #192
                          For quiet 24v engine mounts, I would suggest (2) of the rubber e28 M5 cylinder mounts part # 11811128932. The stud on one side is a bit long, so you can cut it down to make threading the nut easier, but I've used these for around 5 years now and they are quiet like a factory stock motor mount...go figure! Initially I used the Condor solid motor mounts with my swap, but they were way too noisy for a street car. My friend uses the AKG 24v poly motor mounts in his car and they took a little while to break in, but once they did the NVH wasn't too noticeable aside from the expected cold morning startup.
                          • Staszek
                            • 2533
                            #193
                            This is exactly why I went E28 mounts on my S54. Maybe if it was a track car only I would go with stiffer mounts, but for the street its not worth it.
                            • moatilliatta
                              • 6158
                              #194
                              Running AKG, they seem to be on the softer side of poly. Not a thru bolt design which helps. Didn’t care and won’t do many other poly / delrin / whatever mounts.
                              Didn’t someone recently put e36 mounts upside down?
                              if true, now that’s blowing my mind. It took this long?!
                              @Zakspeed_US
                              • pazi88
                                • Sep 2015
                                • 584
                                #195
                                This is something that people don't seem to understand. It's not like the vibrations are bad with poly mounts. Those are actually quite manageable, because 6-cyl is pretty smooth running. But it's the noise that is the deal breaker. It's not nice to daily car which sounds like the engine is broken, because the poly/solid mounts pass through so much of the engine internal sounds. After some time it gets really annoying. Same goes for transmission mounts. With poly mounts, stock transmission sounds like it has straight cut gears. Horrible... I'm personally still looking for good mounts for my m50. Poly mounts. Way too noisy. Solid rubber ones, (like e28 m5/e34) are nice and silent, but those get too soft when engine warms and cause too much movement to my turbo setup. The e36 ones are really good compromise with stiffness and sound. But those don't fit e30, because those hit frame rail in e30....
