M54 Madness, the remix
  • digger
    • Nov 2005
    • 6176
    #136
    for reduced noise just add a muffler or resonator (or additional ones) with longer length and fatter body (more volume)
    • ForcedFirebird
      • Feb 2007
      • 8300
      #137
      I find that changes note more than anything. Best thing to do is add a j-pipe (Helmholtz chamber) to cancel that noise, leave the rest of the exhaust alone. Drive around and see what RPM the drone is worst, do a little math, and a tee with a curved pipe can be done at your local exhaust shop if you don't have access to a welder. This won't change the sound much from outside the car, but cabin frequencies will be cancelled.
      john@m20guru.com
      Links:
      • hoveringuy
        • Dec 2005
        • 2742
        #138
        Problem is, it's louder everywhere. It feels like the gauge on the headers is thinner and they just make a lot of noise.
        Once Tyler gets his shop back online I'll have him fit my OBD2 headers and down pipes. It's a little bit of a step back but I know they'll be civilized and that's what I'm after now.
        • TheAxiom
          • Sep 2015
          • 59
          #139
          Why not ebay headers?
          E92 Msport
          • digger
            • Nov 2005
            • 6176
            #140
            and what happened to the euros?
            • butters
              • 1205
              #141
              I'd venture to say that the experience will be the same. eBay headers are typically similar to, if not directly copying, the Racelands. Thin-wall tube that tends to be noisy as hell - that was my experience too, and my S50 turned out still pretty dang loud after adding an x-pipe, dual cats, dual resonators, and then changing to the claimed quietest-aftermarket Dinan muffler.
              • TheAxiom
                • Sep 2015
                • 59
                #142
                I made good power with mine and I don't remember them being that much louder than stock (on stock exhaust)
                E92 Msport
                • butters
                  • 1205
                  #143
                  Stock exhaust might be the key there.
                  • Ahmedsinc
                    • May 2014
                    • 4
                    #144
                    Any chance of posting your MSQs?
                    • hoveringuy
                      • Dec 2005
                      • 2742
                      #145
                      send me a PM with your email and I'll send one to you.
                      • bmwmaster81
                        • Sep 2012
                        • 49
                        #146
                        Hi,
                        i want to use the M5430 with Ecumaster EMU ECU. Has anyone maybe an pinout from the original MS43 ECU?
                        I can't find a goog one.
                        • digger
                          • Nov 2005
                          • 6176
                          #147
                          Originally posted by bmwmaster81
                          Hi,
                          email Rama at http://racehead.com.au/
                          • mike25
                            • Jan 2014
                            • 27
                            #148
                            Any Dyno news?
                            • Jaker
                              • Oct 2013
                              • 234
                              #149
                              Ya! What's up with the build?
                              • hoveringuy
                                • Dec 2005
                                • 2742
                                #150
                                Originally posted by mike25
                                Any Dyno news?
                                Yes, sort of.
                                The short answer is 230hp at 6000rpm. I still have a rev limit that I can't get rid of. Somehow it got stuck at 6000 and wouldn't change to 7200.
                                My intake cam is also retarded 6 degrees in static timing and the VANOS seals are weak, torque wasn't that strong down low.
                                Once I get everything sorted still looking for at least 240.
