The Detailed E30 R-134a Conversion Thread/DIY
  • jeffnhiscars
    • Jun 2011
    • 6011
    #436
    Originally posted by parkerbink
    I ordered everything needed for conversion, figured better safe than sorry, does the valance really have to come off to r&r the condenser? Also, FCP Euro is 48.xx cheaper right now than AUTOHAUS AZ for the Behr unit. (95 vs 143)
    Buying a new Behr for what...$4xx...is, IMO a waste of money. It's an r12 compressor w r134 seals whereas you can buy a new high efficiency r134 compressor & expansion valve for half that....as long as you can mount it
    Alice the Time Capsule
    • cory58
      • 1021
      #437
      Are offering to help a brother out, or are you just teasing us?
      1992 325i Cabrio
      1988 320i Touring
      2000 M5
      1977 530i
      2015 328i - Euro Delivery/Performance Center Delivery
      BMWCCA
      E30CCA
      • parkerbink
        • Jun 2004
        • 10138
        #438
        The one I got was the R134 Behr for 95.00.
        I got the compressor the car had so I could just mount it.
        • jeffnhiscars
          • Jun 2011
          • 6011
          #439
          I'm just stating a fact, but....I will look in to making these when we get back from Canada since there is clearly a need.
          Used will get you by as long as you are confident it won't cause any problems. How do you know it's r134 compatible ?
          • parkerbink
            • Jun 2004
            • 10138
            #440
            Both items are new, their descriptions said R134.
            On the compressor, I traded at least 20 messages verifying it was the correct unit.
            http://www.ebay.com/itm/New-A-C-Comp...72.m2749.l2649
            Under item specifics:
            Refrigerant Type: R134a
            https://www.fcpeuro.com/products/bmw...09-64538391510
            Replacement serpentine flow condensor compatible for R12 and R134A A/C systems
            • jeffnhiscars
              • Jun 2011
              • 6011
              #441
              It says "Sanden 508" so its not a Behr compressor so you will need to find mounts for it. It also says serpentine belt.
              Why didnt you just get a PF condensor for the same $$ ?
              • parkerbink
                • Jun 2004
                • 10138
                #442
                The Behr is the condenser.
                I got the same compressor it had.
                2 Grooves Pulley
                • jeffnhiscars
                  • Jun 2011
                  • 6011
                  #443
                  nm
                  • parkerbink
                    • Jun 2004
                    • 10138
                    #444
                    Is this a problem? I read PAG is bad for ex r12 systems.
                    • jeffnhiscars
                      • Jun 2011
                      • 6011
                      #445
                      It's a huge problem since mixing them will ruin your system. That's an r134 compressor
                      • parkerbink
                        • Jun 2004
                        • 10138
                        #446
                        It is the same compressor that was there, the deed is done, the expansion valve & condensor that came out were the same, ac is back, only thing is the Gates 7328 that was in there was too small. To get the ac charged I had to use my power steering belt although it is slightly larger (slightly loose).
                        What belt are people using with the Sanden compressor?
                        • parkerbink
                          • Jun 2004
                          • 10138
                          #447
                          It's hard to see but the compressor seems to have a wobble. Do I need to contact the seller?
                          Because it's a video it won't let me do anything but post the link. Sorry
                          https://www.flickr.com/photos/946846...posted-public/
                          • Jims5543
                            • Dec 2014
                            • 62
                            #448
                            Just an FYI for you guys that do not want to convert their system. You can use HC-12a which is legally obtained and compatible with R-12. Beats the hell out of flushing a system and converting to a less efficient gas.
                            "HC-12a, also called ES-12a, OZ-12a, and Hydrocarbon Blend B, is a "drop-in" replacement refrigerant for Freon-12. It is considered nearly non-ozone-depleting. The mixture can be used in refrigeration systems designed for R-12. HC-12a provides better cooling than an R-12 system retrofitted to R-134a, with much greater energy efficiency as well. Unlike R-134a, HC-12a is completely compatible with the hoses and oils used in R-12 systems, making the conversion much easier to accomplish. HC-12a is also patent-free due to its non-synthetic nature."
                            https://www.amazon.com/Cans-REDTEK-R...eywords=HC+12a
                            Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride! -Hunter S. Thompson
                            • digger
                              • Nov 2005
                              • 6141
                              #449
                              is it worth replacing the aux fan when doing a Nissens PF condenser?
                              is it a 14" or 16" SPAL pusher required, and how much more air does it move compared to the stock aux?
                              any specific models that make mounting easy?
                              • jeffnhiscars
                                • Jun 2011
                                • 6011
                                #450
                                My build thread has a detailed Spal installation but the Photobucket pics are gone. Some use the 16" but I think it's too big so went with a 14". IIRC on low it may have slightly less capacity than a stock fan but I run it jumped somots def pushing enough air with not nearly as much noise. In short, a good upgrade.
                                To mount it I did mod 2 of the 3 brackets. 1 I twisted 90 degrees and one I drilled out the rivet and reversed it. I also bought a SPAL pigtail so the entire assembly is removable without removing the valance.
