HD rocker arms ....lesson learned
  • zaq123
    • Jul 2016
    • 1560
    So what is a consensus as it sits today? Are OEM rocker arms actually Febi ones? Any advantage going OEM or it's the waste?
    • TobyB
      • 5288
      Also stiffer springs were used.
      The numbers here matter- quite a bit. Nose and seat pressures vary tremendously on 'stiffer' springs,
      and I learned (also the hard way) that you really have to do your own measurements and maths.
      Febi has been making the OEM single cam rockers for decades- they just have 2 moulds for the castings.
      They use the same process, and create the same voids. For racing, I would buy 20 Febis,
      pick out everything with no visible external voids, and start polishing the undersides.
      If I broke through to a void, I'd set that one aside, too. I usually got a set of 14 to 16 of them.
      I ran the 'voidy' ones on street cars with no problems.
      I also found that it was worth bluing the cam and using soft springs to make sure the geometry was
      correct. Like you, I'd sometimes find that the pad wasn't contacting the cam well at all. That was when
      I gave up on the currently- available HD rockers and stayed with Febi- their pad alignment was usually pretty
      good, and when it was off, it was easy to correct with a very mild resurface.
      I very much regret tossing my bucket of used rockers when we moved shop- resurfacing rockers isn't difficult
      if you make a pretty simple fixture....
      Likewise, I have broken in cams on soft springs, and then put the higher pressure springs in after a test day or 2.
      It's not as much fun running around with a 6k rev limit, but there's still a lot of things you can work on, if you take
      the effort to regear for it.
      t
      • hasa
        • May 2013
        • 307
        Questions for everyone struggling with rockers:
        1) Do you measure your valve spring stiffness (installed height & max lift). This is crucial for preventing valve float which destroys everything in valvetrain. N/A M20 street / race engine requires 120kg at max lift with Febi/BMW rockers and typical race cam.
        2) Do you use oil that has additives for old-fashioned valvetrain, high ZDDP content?
        I haven't broken yet any rockers or worn out a cam lobe. Silly 312 degree cam, 7500 rev limit. Knock on wood.
        • digger
          • Nov 2005
          • 6194
          i got a response from MM and they dont sell the peened and inspected rockers anymore. They use a single coil spring with light nose "pressure"
          • Northern
            I like cupcakes & sh!tboxes
            • 5283
            No shortage of options at least...
            Stock/Febi/HD crapshoot
            Catcams steel (elephant foot/screw adjust)
            KM cams steel (eccentric adjust)
            VAC aluminum (elephant foot/screw adjust)
            RHD roller (complete setup)...
            Heard of issues with pad/cam wear with basically all options. Pick one and roll the dice.
            Everything is made like shit these days.
            Originally posted by priapism
            Originally posted by shameson
            • Panici
              • Dec 2009
              • 2556
              Ain't that the truth.
              Hard to find car parts that last, even from previously reputable manufacturers.
              • digger
                • Nov 2005
                • 6194
                I had my OE valvetrain measured and setup. The head guy wasn't that happy with the spring forces with Schrick valve springs for 11.75mm lift so we went a bit higher (95-100kg iirc) and at the time VAC were selling some Eibach valve springs that fit nicely (i should have recorded the details as now VAC sell different springs).
                You don't need anywhere near 120 kg for a true street cam engine with 7000 rpm that most people are concerned with, many have run a schrick on stocks springs without issue and catcams recommend 83kg for a typical street cam 11.5 mm lift basically what the schrick springs provide and whatever acceleration rates they use which are slightly higher than schrick
                There is nothing unique about the m20 valvetrain system, any engine where the cam slides e.g., cam on bucket, flat tappet pushrod, finger follower (i.e. anything that isnt a bushed or needle roller) faces similar challenges doesnt matter if it is hydraulic or solid and yet they still work on modern oils.
                You dont need high zddp (excluding say breakin)you need the right amount and need to be careful of other additives that reduce the effectiveness of the zddp e.g. high calcium is a problem as it depletes zddp it also promotes low speed preigntion so modern oils dont have as much zinc but they have less calcium and use other additive for wear protection so lets not stick to 1990's thinking
                • hasa
                  • May 2013
                  • 307
                  Everyone have their own knowledgebase about this topic. I'm not able to analyze M20 valvetrain dynamics to be able to prove what kind cam requires what kind of valve springs. Truth lies somewhere out there... My own thumb rules have worked in my use and I just wanted to give it as anecdotal information if someone has similar use like me and struggles continuously with rockers. Actually my method is just copy of one retired M20 racer fellow who ran Schrick 304 in his B27 and turned his engine up to 7800.
                  • digger
                    • Nov 2005
                    • 6194
                    The best person to know/ask is the cam manufacturer, both schrick and catcams give you the information these days.
                      • 34844
                      wow Metric Mechanic still exists? And Jim is still around? awesome!
                      Funny because it's been nearly 20 years since I built my M20 with MM parts (and Jim's advice) and uh, not a single issue ever. of course we had a lot lower chance to end up with poor quality / counterfeit parts back then.
                      at this point I almost wonder if using old/proven rockers is a better idea than new..
                      • digger
                        • Nov 2005
                        • 6194
                        I bought parts from Jim in 2006 nearly 20 years ago to.
                        Having reached out to him about some things, MM's answer to rocker wear and breakage (per the attachment posted above) is a lighter single spring even with their more aggressive cams rather than peened and inspected rockers of years gone past with a single beehive. To me this reduces one issue but potentially introduces another (or more than 1)
                        I am not sure there are any issues with just using the OE parts (other than the price) 12 x $60= $720 so an extra $450 over aftermarket options.
                        with stock new OE springs these have proven to work ok with a mild cam upgrade
                        At least it isn't an s54 with 24 x $105 = $2,520 or $2,800+ for Schricks which are a must have for warranty apparently
                        • zaq123
                          • Jul 2016
                          • 1560
                          considering Febi is who makes OEM rockers as everyone claims, it's $23 or so a piece. I just ordered 18 Febi to sift through. Was I wrong and should have gotten OEM?
                            • 34844
                            my springs are all stock (I still have the same Schrick 284/272). and Febi rocker arms before they got really shitty (I guess). it's just harder to get decent parts now I suppose.
                            Also the prices on MM engines were always expensive, but now it's even more insane. And they no longer sell individual parts, I guess it's not worth the headache.
                              • 34844
                              hard to know, buying Febi in 2006 when I did is a lot different than now I'm sure. If the cost difference is small maybe getting BMW parts is better.
                              • digger
                                • Nov 2005
                                • 6194
                                I probably would have gone OE to get a warm snugly feeling however flawed that actually may be....
                                Don't FEBI also make the HD with known issues? FEBI may make the OE rockers for BMW but it doesn't mean they are the exact same process or quality as the FEBI labelled ones.
                                One thing about the HD was the surface finish on the pads was garbage compared to the OE as in you could run your finger nail and detect the grinding marks like a very fine file whereas the OE you dont feel anything but smoothness.
                                The important part is I dont know if the non HD Febi are the same crap finish as the FD.
                                Here is a lightly used OE vs new HD (used for mockup only) and the reflectivity shows the difference (it is hard to show some things via photo) also note i am comparing the unworn parts to be fair
