HD rocker arms ....lesson learned
  • zaq123
    • Jul 2016
    • 1560
    Long story short, I'm replacing cyl. head on my freshly rebuilt M20 after 1000 km. (very slow coolant leak under the valve cover around cyl 5&6). Shop that machined the head never pressure tested the head because they had no proper setup. I never used the head before the rebuild so I don't know if it was pre existing condition or something happened during my engine break in???
    But my post is not about that. My new Schrick 288 cam's IN lobe on cyl 1 is all messed up with just 1k km. Clean room assembly with all clean parts, assembly lube, primed engine etc etc. Everything looks very good but cyl 1 IN lobe....the cam is garbage. Also stiffer springs were used.
    It appears all this pressure was rocking the pad in one HD rocker just enough to kill the cam.
    Here is link Metric Mechanic updated article when they tested these HD rockers in 2021. I don't believe there were any changes to current HD arm design since pre Covid era but let me know if anyone aware of any. But it summarizes my issue pretty well. Enjoy the read. One bad rocker and it's an expensive lesson.
  • 82eye
    • Jan 2009
    • 2108
    i've read something about this before but never encountered the issue with mine. i run the hd's since i have a lightweight flywheel and can occasionally hit 7k rpm. the stockies are known to fail much more often up there even when only seeing it briefly.
    i'm running a mild regrind cam which it probably easier than a billet grind cam on them.
    • 2mAn
      SeƱior Mod
      • 21039
      I've been contemplating which rockers to get for the new camshaft install... Cam is a Billet 272 from Ireland Engineering that I will pair with a MarkD chip so it will see 7000rpms since the car also has a lightweight flywheel. The dyno will tell us that revving it that high is probably pointless, except that it would sound great haha
      I'm still on the fence on whether I should get the HD rockers or not. I know MR 325 sells some steel rockers also, but not sure if thats overkill for my cam profile...
      Simon
      Current Cars:
      -1966 Blue Boat
      -1969 Red VW
      -1986 White BMW
      -2006 Green Thing
      Make R3V Great Again -2020
      • zaq123
        • Jul 2016
        • 1560
        read that bulletin from MM in the first post. I'm done with HD, like it's an expensive gamble to get one bad rocker out of 12. My options right now are OEM or something crazy expensive like RHD roller ones with their cam/spring package. I'm thinking about OEM /shot pinned OEM since I have another brand new Shrick cam sitting around.
        • digger
          • Nov 2005
          • 6198
          if you can check that the lobe didnt run off the end of the pad and the edge of the pad didnt dig into the cam? that was one issue since they were designed for reduced base circle cam that you get with a regrind. i thought was solved so may not be the root cause.
          The surface finish of the pads always appeared to be sub standard to the OE rockers.
          i use peened and inspected rockers from MM. i dont know if they still sell those. i see with their article they are marketing hard trying to sell expensive unwarranted stuff and trying to fix problems that dont exist
          • zaq123
            • Jul 2016
            • 1560
            i use peened and inspected rockers from MM. i dont know if they still sell those. i see with their article they are marketing hard trying to sell expensive unwarranted stuff to
            Pad was long enough and no run off...there are visible zones on each side of the pad where cam didn't make any contact. I'm not sure if I want another set of HD for my new cam. Go OEM which are Febi? Go Febi ? RHD is an option but the price of the set with springs and the cam is kind of pushing it. What's your thoughts?
            • digger
              • Nov 2005
              • 6198
              i would use the peened and inspected rockers from MM if they are available
              • digger
                • Nov 2005
                • 6198
                to add to this i use a Catcams cam with 11.95 mm lift with 7000 rpm rev limit and stiffer springs (stiffer than even schricks) and for 10 years daily driving the cam looked like new with the rockers from MM. It wasn't until i mistaken followed a recommendation and tried a different oil that the cam started to scuff (the oil may be a coincidence)
                Also there have been issues with schricks and hardness on other engines so its the world we live in
                • varg
                  Florida Turbo Man
                  • May 2014
                  • 3430
                  Any pics of the of the pad and cam? Areas of no contact on the pad as in a concavity or raised surface profile that's causing isolated areas of wear instead of a clean, even contact patch?
                  Really? Pretty inexcusable for such a big name with fairly premium priced cams to have a pattern of obvious quality escapes. I wonder if Schrick does their manufacturing in house or if they have a supplier who is slacking on hardness testing parallel with production.
                  Does anyone offer inspected rockers? I don't see it on MM's website so I'm assuming they no longer do. It would be nice to be able to buy a set of rockers that have been checked for pad profile and dimensions.
                  IG @turbovarg
                  '91 318is, M20 turbo
                  • It's Soda Not Pop
                    • Jan 2022
                    • 877
                    I've had the HD rockers from Bimmerheads snce 2017 and I have kissed (bounced off) 7k rpms a few times. I've never had any issues. I also have a regrind cam (274/280).
                    88' Seta 2.7i Zinno
                    https://www.r3vlimited.com/board/for...430-my-88-seta
                    • 82eye
                      • Jan 2009
                      • 2108
                      the febi hd rockers being discussed are now nla. the choices are down to the bimmerheads steel rockers, the IE peened rockers, or the rhd sprung rocker. bimmerheads and IE used to carry the febi hds but can no longer source.
                      if you order febis you sometimes get an hd. they just deleted the internal part number and rolled what was left back into their regular stock. they don't make a distinction, and they don't worry about it creating cam issues on a stock engine.
                      • digger
                        • Nov 2005
                        • 6198
                        At least i think it was Schrick, it could have been Catcams on the s54. I think they both now specify their own rockers for warranty
                        i haven't seen anyone offer this service
                        • digger
                          • Nov 2005
                          • 6198
                          Catcams have (atleast they did and i presume still do) a steel rocker arm. They are expensive but look like very good quality and have a coated pad (some kind of dry film not dlc) and have the porsche style elephant foot adjusters.
                          • McGyver
                            • 4636
                            I picked up a 280/274 regrind cam and HD rockers from BimmerHeads back in 2021. (god this project has taken a back seat to other things in life...) The MM pamphlet has me a little worried about running the new HD Rockers I have. Should I be worried? I assume the worst case scenario is that I wipe out the cam and have to replace both cam and rockers in the future, right?
                            MR 325, could you weigh in on this?
                            • 82eye
                              • Jan 2009
                              • 2108
                              i can tell you mine have been fine for the last 2 driving seasons but i'm on a regrind. both bimmerheads and IE have backed away from selling them, they were the same febis. no one has told us definitively if that is due to issues with the rockers, or if febi simply dropped the product.
                              febi has rolled the hds back into their regular stock, and they still pop up on an odd basis when ordering stock rockers from them. if it was a serious problem they would probably have pulled them completely and stopped selling them.
                              this isn't the first time this has come up. i've never seen either IE or bimmerheads react to a request for comment on it.
