M20 with 284/272 idle afr
  • zaq123
    • Jul 2016
    • 1560
    Do you guys think that cam has big enough overlap where idle will improve with 13.8 base afr at idle? My idle isn't super bad but I want steadier considering its at 900 rpm already. Would it makes sense to lower AFR to 13.8 in case the cam lets some fresh air into the exhaust?
  • 88Sedan
    • Apr 2023
    • 267
    Not an expert on m20s but 13.8 sounds pretty rich to me. What engine management?
    • Panici
      • Dec 2009
      • 2569
      Are you running a standalone and can make the change on the fly?
      That's really the best way to do it. Feel and listen to how the engine responds after you drop the target AFR.
      • varg
        Florida Turbo Man
        • May 2014
        • 3429
        Idle it where it's stable. With 630cc/min injectors and a 272° camshaft my target is 13.6:1. M20s are batch fire from the factory and that combined with larger injectors that don't like small pulse widths becomes the limiting factor.
        IG @turbovarg
        '91 318is, M20 turbo
        • digger
          • Nov 2005
          • 6196
          you just do the changes to make the engine happy, only caveat is you dont want to be compensating for some other issue
          • TobyB
            • 5293
            Originally posted by digger
            ...only caveat is you dont want to be compensating for some other issue
            which means no CyburTurk for you!
            t
            tries to compensate with humor. Usually failz
