lighter stock flywheel weight with stock clutch combo ?
  • Panici
    • Dec 2009
    • 2565
    Originally posted by atmh
    How difficult is driving with the flywheel that light?
    Drove my 7.5lb flywheel for a summer with the stock M20 clutch on an M52B28.
    The drivability is fantastic! Revs like a dream too.
    (Temp gauge was not hooked up, VDO gauge was at operating temp for the video)
    Just swapped on a SPEC Stage 3+ clutch this year, and let's just say the first test drive this past weekend was a challenge. Hopefully as the clutch breaks in things get easier.
    • digger
      • Nov 2005
      • 6196
      i would simply get the stock/original SM flywheel lightened for a streetcar that will feature all the modcons and use the stock clutch.
      • 82eye
        • Jan 2009
        • 2102
        i'm just trying to determine a decent weight for one.
        • atmh
          • Sep 2004
          • 165
          Just go as light as possible with a machined single mass flywheel. That's what I did and I was disappointed with how little difference it made, even at 12.5lbs I barely noticed it.
          • digger
            • Nov 2005
            • 6196
            about 12-13 or so is the lightest most say they can be safely taken to, you will really only notice it in 1st gear and a bit in 2nd. I wouldn't get too hung up on it overall
            • e30davie
              • Apr 2016
              • 1788
              I put an m20b20 single mass one on my m20b23 and i was really surprised how light the flywheel was given it is a 6clr etc. I wish i had of weighed it. compared to the b27 dual mass one i had in the shed it was like a feather.
              • digger
                • Nov 2005
                • 6196
                late m20b20 SMFW are same as m20b25 about 8.5kg 18-19lb
                • e30davie
                  • Apr 2016
                  • 1788
                  ah there you go. i just looked them up on real oem and that seems to be correct. Just ignore my ramblings.
                  • varg
                    Florida Turbo Man
                    • May 2014
                    • 3428
                    Mine wouldn't fully disengage when it was new. The transmission came out twice. I figured the flywheel was just under the acceptable minimum height, but don't know for sure. The clutch broke in and became easily driveable with time. As for lightweight flywheels, I'm just hoping my twin disc turbo M50B30 doesn't want to stall with the AC on, that clutch setup is light.
                    IG @turbovarg
                    '91 318is, M20 turbo
                    • 82eye
                      • Jan 2009
                      • 2102
                      i pulled the trigger on the rhd flywheel. guess im running modified now lol
                      anyone know if new flywheel bolts are a requirement. i though they were tty but i could be mistaken. likely just order to be safe anyway..
                      edit : ordered a sachs clutch kit as well
                      gonna be shopping for a chip soon as well. lmk what the recommends are if anyone has any.
                      • bmwman91
                        • Oct 2004
                        • 3134
                        Nice, I think you will enjoy the FW. Replace the bolts, it is best practice.
                        For a chip, I recommend Sssquid Tuning. They have just about the best off the shelf E30 tunes on the market. Tunes from them are full remaps, not just WOT tweaks or “+5deg to the whole ignition map” like many others.
                        Transaction Feedback: LINK
                        • 82eye
                          • Jan 2009
                          • 2102
                          lol i reached out to sssquid a few days ago and will be adding a 1.5 stage chip and injector combo. super impressed with the customer service at sssquid. also interested in their maf conversion, but that's likely a future consideration. i picked up some flywheel bolts as well from fcp.
