Opinion on best or coolest motor swap
  • BECKSTER
    • Jun 2015
    • 667
    #61
    Originally posted by pandaboo911
    Mercedes om606 turbo
    This times 100,000,000
    1990 Alpine 325is
    1992 Schwarz 325ic (sold)
    • mikebloco
      • Feb 2015
      • 190
      #62
      Lol. I don't even smoke. I just felt like saying it because company's have put two of their I6 motors together to form a v12. The m70 is two m20's.
      Here's two 1j's together http://imgur.com/a/iDHWH#2
      • digger
        • Nov 2005
        • 6196
        #63
        Originally posted by nando
        If you want a rough idle, just alter the vanos map for more overlap.
        Deleting vanos doesnt make more power. Deleting it would just lose q bunch of torque - pointless.
        (Oh yeah, sorry, hit edit instead of quote)
        many people seem to claim that you can use a bigger cam without vanos. im not sure why this is the case, for sure youd need to limit the amount of adjustment and add some stops to limit travel if thats even possible.
          • 34844
          #64
          yeah, it doesn't make sense. if you're worried about piston/valve contact, you'd have the same limitations on absolute cam position with or without it. It's basically like people who think deleting whatever random stuff they don't know the function of will make a big increase in power.. I remember a guy locally with an E39 M5 that claimed it came from the factory without VANOS and made more power than a regular M5. :|
          you can limit the travel in software. pretty simple - primarily you would limit the amount of cam retard. again, the limitations would be the same with our without VANOS.
          deleting the electronic throttle is another one - the electronics are way faster than human perception; it's not like there's a 100ms lag or something. And the e-throttle linkage works poorly with a throttle cable, in a lot of ways it's significantly worse for throttle response & drivability (unless you only ever drive at WOT). Also, it costs more.
          • varg
            Florida Turbo Man
            • May 2014
            • 3428
            #65
            Opinion time.
            VQ37vhr
            Decent engine, not light enough vs an LS to warrant it over the LS.
            LS1
            Practical choice, good power potential, not too heavy. If you want reliable power and don't care about originality, best choice.
            Rotary engine. I say 2 13b's together
            Light, good potential, oh wait, just saw the second part you're crazy or have multiple tens of thousands of dollars to spend on an engine.
            1LR-GUE Hey a guy can dream
            Don't even need to address it.
            Coyote 5.0
            Good choice, really expensive though. Heavier than an LS.
            1/2JZ
            Pig fat, heaviest engine on the list, overrated, cool if you want a drag car, oh wait, no it isn't, because it's more played out than pop music.
            M30
            Good engine, strong, not too terribly heavy, hard to fit. Cheap.
            S54
            If you want coolest, best not to do a swap a bunch of other people are doing. Costs a lot, not light. Good power NA, not much torque. If you're going to turbo it, save money and get a cheaper 24V I6.
            S65
            $$$$$ and not so much to show for it except cool factor.
            4G63
            Better off with an F20.
            IG @turbovarg
            '91 318is, M20 turbo
            • mikebloco
              • Feb 2015
              • 190
              #66
              Actually a vvti 1j is about the same weight as an aluminum ls1. It came from the factory with a single turbo so it drops weight quite a bit. The 2j with stock twins is just under 600lbs and is a fat pig
              • 2mAn
                Señior Mod
                • 21011
                #67
                I feel like this thread came over from the FB group
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                Make R3V Great Again -2020
                • varg
                  Florida Turbo Man
                  • May 2014
                  • 3428
                  #68
                  They're close, still a lot of weight for a 2.5L I6. You get 2x+ the displacement and the weight further back and lower down with the LS :up:
                  IG @turbovarg
                  • agent
                    Vice Grand Pubaa
                    • 7960
                    #69
                    That's definitely where it belongs.
                    Originally posted by kronus
                    • Exodus_2pt0
                      • 5943
                      #70
                      BUT! Most people nowadays are swapping in the iron blocks, because half the cost or less.
                      Hell I picked up my 5.3 for $500 a few years ago.
                      Still the best option for flat out power. 5.3 + boost = Permagrin.
                      No E30 Club
                      • mr2peak
                        • 2388
                        #71
                        K20/24 hybrid, basically a modern-day S14
                        Drive it hard. Maintain it well.
                        A Topless Memorandum
                        • roguetoaster
                          Biggus Tippus
                          • 7830
                          #72
                          Good call, and still more power than my M42... but it's no two-smoke!
                          • Thunder Child
                            • Jan 2016
                            • 11
                            #73
                            I had an M30 in mine for awhile. Went great with a 4 speed. Damn thing was cursed though. Three HGF's
                            "Like a river that don't know where it's flowin', I took a wrong turn and I just kept goin'"
                            R3v member since 2012
                            • varg
                              Florida Turbo Man
                              • May 2014
                              • 3428
                              #74
                              Yes, but cheap iron block truck engine != LS engine
                              All of those iron block junkyard special LQ4/9/L96/LY6/whatever else that people are putting in their cars these days and calling "LS" engines are GM V8s, but they aren't LS engines. Calling an LQ9 an LS engine is like calling an M50 an S54. True cast iron LS engines like the LSX are not cheap or junkyard bound. Those iron block truck engines may be an excellent ingredient in the cheap power recipe, but putting them in light cars like Miatas and E30s is senseless, stick them in something that wasn't made to go round corners like a fox body or a supra potstir
                              IG @turbovarg
                              • Kevinl
                                • Oct 2012
                                • 897
                                #75
                                Hell why not a S70/2
                                1989 BMW 325is Lachsilber metallic 5 speed
                                2007 BMW 335i KARMESINROT 6 Speed manual
                                2011 BMW X5 35I
