S52 finally!
  • 2mAn
    Señior Mod
    • 21053
    #241
    You're almost there!
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
    • parkerbink
      • Jun 2004
      • 10138
      #242
      • parkerbink
        • Jun 2004
        • 10138
        #243
        Solution to losing belts was the Hydraulic tensioner and belt 2 sizes smaller.
        • parkerbink
          • Jun 2004
          • 10138
          #244
          Click image for larger version  Name:	Screenshot 2024-03-23 at 8.18.48 PM.png Views:	0 Size:	154.2 KB ID:	10116851
          This is "IMG_8475" by Jeff Jeffers on Vimeo, the home for high quality videos and the people who love them.
          This is "IMG_8476" by Jeff Jeffers on Vimeo, the home for high quality videos and the people who love them.
          • parkerbink
            • Jun 2004
            • 10138
            #245
            This happened today.
            • parkerbink
              • Jun 2004
              • 10138
              #246
              This is "IMG_8546" by Jeff Jeffers on Vimeo, the home for high quality videos and the people who love them.
              • parkerbink
                • Jun 2004
                • 10138
                #247
                Drove the BMW a bit over 40 miles round trip on the freeway. It's a freaking blast!
                • parkerbink
                  • Jun 2004
                  • 10138
                  #248
                  The bung is in!
                  • parkerbink
                    • Jun 2004
                    • 10138
                    #249
                    Soooooooo. I'm on top O' the world, all is well, car feels great, went on several fun in the sun drives (until it got too hot & the no AC due to heat on all the time made it no fun) and I hit the brake & it needs 10+ times the pressure.
                    Booster or MC more likely & is there a upgrade like on e30s to the e32 mc?
                    I just bled the entire system with Motul full synth.
                    • Panici
                      • Dec 2009
                      • 2575
                      #250
                      Vacuum line between intake manifold and booster still good? Inline check valve still good?
                      • parkerbink
                        • Jun 2004
                        • 10138
                        #251
                        Yup, no vacuum leaks. I'll look at the check valve.
                        Thanks
                        • parkerbink
                          • Jun 2004
                          • 10138
                          #252
                          The sensor for the AFR/boost gauge is defective. Reads 22.4 when revved and 7.4 at idle.
                          Searched forums, found it's a known issue if the gauge does not like the ground.
                          Opened the pita to open center console ran the ground to a bolt holding the gas pedal assy on the car, no change. As I bought the PSB1 direct, called Innovate. After some drama, they are sending another O2 sensor.
                          I have one I bought for the Sequoia that disappeared, searched and searched, then it occurred to me I put the new one in the box the gauge came in.
                          Mystery solved!
                          • parkerbink
                            • Jun 2004
                            • 10138
                            #253
                            Got the PSB1 "working" but it's readings make no sense. 10.x at idle up to 15 at throttle. WTF?
                            • MrBurgundy
                              R3V Degenerate
                              • Mar 2012
                              • 5607
                              #254
                              I would look into DOT 5.1 fluid.
                              Way better than DOT 4 and can be used in dot 3 or 4 systems..
                              • Northern
                                I like cupcakes & sh!tboxes
                                • 5284
                                #255
                                Is there any weird setup you need to do with the PSB1?
                                I remember the LC1, you needed to go into LM Programmer and change it to AFR/Gasoline because it came defaulted to something else.
                                Otherwise is it just really lean? AA tune I think I saw? correct MAF/injectors/fuel pressure and whatnot?
                                Originally posted by priapism
                                Originally posted by shameson
