S52 finally!
  • parkerbink
    • Jun 2004
    • 10138
    #196
    I hope it goes in like this, getting the belt on was a massive pain in the butt!
    Had to release the outside PS pump bolt & hold the tensioner as far as it would go with a gigantic breaker bar on my long ratchet (with my shoulder) while levering the belt on with a screwdriver.
    • parkerbink
      • Jun 2004
      • 10138
      #197
      Transmission os out, it was no fun!
      • parkerbink
        • Jun 2004
        • 10138
        #198
        SOON
        • parkerbink
          • Jun 2004
          • 10138
          #199
          I need to do all the fluids and am doing the rear subframe bushings which requires removal of the rear end and brakes, I have to bleed the hydraulic system including the clutch slave so that's next. The rear shocks and springs will go in when it goes back together.
          Also. Mock up....
          • parkerbink
            • Jun 2004
            • 10138
            #200
            Subframe out, nightmare is too small a word.
            Spring comparo.
            Also, fluids.
            • Panici
              • Dec 2009
              • 2575
              #201
              What funnel is that?
              Threads right into the oil cap spot?
              • parkerbink
                • Jun 2004
                • 10138
                #202
                Click image for larger version  Name:	Screenshot 2024-02-16 at 4.36.20 PM.png Views:	0 Size:	103.3 KB ID:	10114450
                https://www.ecstuning.com/b-schwaben.../029348sch01a/
                Yup, love it!
                Bad thing is I have one for my Sequoia, didn't realize it has the adapter for BMW :P
                lol
                It runs! The DME needs to learn so it needs to warm up, & it's open headers so sounds like a P51 (which is pretty cool actually)
                Finally found blanks that fit the M console.
                • parkerbink
                  • Jun 2004
                  • 10138
                  #203
                  I paid 93 to get the differential seals TODAY. Wanted to finish and drive tomorrow. I'll be demanding my money back for the shipping.
                  • parkerbink
                    • Jun 2004
                    • 10138
                    #204
                    Spoke to Bimmerworld, refund incoming. Thier CS is amazing!
                    • parkerbink
                      • Jun 2004
                      • 10138
                      #205
                      Starts right up but does not idle. I emailed the tuner asking if he sees anything in the file needing attention.
                      https://jmp.sh/s/1TbCZNbiIKPddp0de5YJ​
                      • moatilliatta
                        • 6158
                        #206
                        Did you do big maf?
                        @Zakspeed_US
                        • parkerbink
                          • Jun 2004
                          • 10138
                          #207
                          Nope, OEM.
                          • parkerbink
                            • Jun 2004
                            • 10138
                            #208
                            I was offered a DInan high-flow throttle body. Does anyone have any input on them?
                            • Northern
                              I like cupcakes & sh!tboxes
                              • 5284
                              #209
                              Stolen from bf.c:
                              There are THREE Bosch 3.5HFMs that work in the E36 Cars... the 800, the 803, and the 806.
                              The software Dinan (and all the other chip tuners use) will drive the 800 (BMW 540/740) and 806 (BMW Euro M3) HFMs. The 803 is one Porsche uses and most Turbo guys run that as it has a different voltage/metering characteristic.
                              If it's just the MAF itself, it's likely going to be one of those two.
                              If the tuner says you need a MAF, I guess you need the MAF. Otherwise I'd be looking for vacuum leaks.
                              Edit: derp you said throttle body, not MAF.
                              Originally posted by priapism
                              Originally posted by shameson
                              • parkerbink
                                • Jun 2004
                                • 10138
                                #210
                                Tuner has not responded. But I'd love to know if I should get the 9% biggerr TB.
