S52 finally!
  • Northern
    I like cupcakes & sh!tboxes
    • 5284
    #211
    Whoops I completely misread that.
    I think a bunch of people make BBTBs, I don't know if it's worth it for an FI car. Probably should have a tune adjustment for TPS enrichment if you do.
    Originally posted by priapism
    Originally posted by shameson
    • parkerbink
      • Jun 2004
      • 10138
      #212
      27 year old MAF is the issue, verified by removing it & it idles. I had a cheap Amazon on hand & it runs fine. Ordered a new OEM.
      • Panici
        • Dec 2009
        • 2575
        #213
        Glad you got it sorted out.
        I wonder if the MAFs can go bad with time? Maybe humidity in the air?
        • parkerbink
          • Jun 2004
          • 10138
          #214
          I'd think like anything eventually they fail. Not a lot of humidity in Phoenix so I doubt it's that.
          lol
          • parkerbink
            • Jun 2004
            • 10138
            #215
            99% there! Should be driving today!
            I just put in the trans & differential fluids, all that's left is running the hoses from the PS pump/cooler to the reservoir & adding fluid. Taking a break & then I'm dropping it off the jackstands & going for a ride.
            https://jmp.sh/G3LKAL7z
            • parkerbink
              • Jun 2004
              • 10138
              #216
              It runs! Feels great!
              • parkerbink
                • Jun 2004
                • 10138
                #217
                Thinking I need spacers, how can I tell what size?
                • Panici
                  • Dec 2009
                  • 2575
                  #218
                  Looks great out in the daylight!
                  Drop a plumb line off the fender lip (can tape it on), and then measure from that into the wheel/tire.
                  • parkerbink
                    • Jun 2004
                    • 10138
                    #219
                    2" to the roundel, 1.5 to the lip.
                    1.5= 38.1 mm, thinking I don't want to be all the way out so 30mm?
                    https://www.amazon.com/BLOXSPORT-Hub...071VS9WWR?th=1
                    • Panici
                      • Dec 2009
                      • 2575
                      #220
                      You measured all four corners? Sometimes cars don't sit perfect side-to-side.
                      On my E28 I actually have a 12mm spacer on the Left rear, and 15mm spacer on the Right rear to get it sitting even.
                      Are the fender lips rolled? If they're not, you do want to leave some space as you've noted.
                      • parkerbink
                        • Jun 2004
                        • 10138
                        #221
                        Nope, just the back 2. I'm ok with the front.
                        I ordered 15mm from Amazon, if they are wrong, I'll send them back and get the next direction indicated.
                        • 2mAn
                          Señior Mod
                          • 21049
                          #222
                          You'll also want to get longer lugs, or convert to studs. Motorsport Hardware always has the goods...
                          Car is looking great, you basically built yourself a Z3M haha
                          Simon
                          Current Cars:
                          -1966 Blue Boat
                          -1969 Red VW
                          -1986 White BMW
                          -2006 Green Thing
                          Make R3V Great Again -2020
                          • parkerbink
                            • Jun 2004
                            • 10138
                            #223
                            15mm spacer in. Except losing the short stud lock, I like it.
                            • parkerbink
                              • Jun 2004
                              • 10138
                              #224
                              What size do I need? The stock are 50.8mm. I think the ones the spacer came with are about 65mm but did not measure. What about nuts?
                              • 2mAn
                                Señior Mod
                                • 21049
                                #225
                                If they came with longer bolts, you'll probably be fine, however studs tend to be easier to live with.
                                If you want, reach out to them and let them know R3V sent you
                                Simon
                                Current Cars:
                                -1966 Blue Boat
                                -1969 Red VW
                                -1986 White BMW
                                -2006 Green Thing
