S1 325 vert semi rescue? Potential mid life crisis era
  • econti
    • May 2014
    • 1149
    My last few cars have been short term ownership. Finding something that needs a bit of love, fixing it, moving it on to another owner. First was a '87 Toyota MR2, AW11 chassis, that was a delightful little unit saved from gathering dust in an old guy's collection. After that was a E39 530, 420G converted, bit of this and that, neglected by a complete moron who shouldn't work on cars. I sold that and was then looking around, and found this little sweetheart on a little-used sale website. '90 325 auto, 104,000km on the dash, second owner. Didn't run, a bit neglected, but basically rust free and really good bones.
    Picture from the ad, featuring a real estate sign with an address. I guess they didn't care about it being stolen?
    Trailered it home. Little dent on the front guard but the paint is still good, so hopefully a PDR guy can remove.
    Gave it a solid wash (I'm not a detailer by any stretch)
    Pinch rails are immaculate and not bent at the jacking points which is the first time I've seen one like that
    On first look I saw a little fuel leak. Seems they were the original lines still, impressive lifespan.
    Interior is mid. Cracked dash, seats need some help, roof is fucked. You'll have that on the big jobs
    Overall it's a solid contender. The important bits are good. I made it run (it didn't) by overdosing it on some injector cleaner and replacing the FPR vac line.
    It's my first early model and first convertible. I had a M20 parts car before but all I did was pull the motor out so this is all new ground for me.
    I'll do the timing belt, because that's an unknown, and either fit a new roof or just pay the man to fit a new roof. Once I've had my fun for a few months, it'll be off to a new owner to be enjoyed.
  • McGyver
    • 4637
    Looks like a solid car! Scrub the interior and you'll have a nice little cruiser for the upcoming summer months!
    Can you get away with just replacing the rear window? They sell kits for both the zip-in and sew-in versions. It's a little time consuming, but way cheaper than having to replace the whole top.
    • 82eye
      • Jan 2009
      • 2087
      nice purchase. glad you keep them going.
      • Northern
        I like cupcakes & sh!tboxes
        • 5270
        Looks pretty damn good from here
        Originally posted by priapism
        Originally posted by shameson
        • 2mAn
          Señior Mod
          • 20954
          Looks good to me too!
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          Make R3V Great Again -2020
          • econti
            • May 2014
            • 1149
            Nah the whole roof is properly cooked. Can see daylight through the fabric, inside layer is hanging down, its a debacle. These cars in nice condition here are worth a fair bit of money so it's worth spending extra to do it right
            • McGyver
              • 4637
              Fair enough, some future owner will be happy that it's been fixed properly! It'll be cool to see this brought back to life.
              • econti
                • May 2014
                • 1149
                I think it blew up. No idea how just yet, or exactly what is blown up.
                I've fixed a bunch of little basic things like cleaning window switch contacts, putting the shine back in plastic trims, etc.
                I used a mix of Autoglym trim and bumper gel and INOX, which is like WD40. I used a lot of it when I was a locksmith and it puts the oils back in plastic really nicely. Doesn't last forever but application takes approx 5min for the entire car.
                Feeling proud of it I took it for a maiden voyage around the block. Absolutely fell in love with it, it drove really well, misfire clearing up bit by bit, steering good, just lovely.
                As I was pulling back in to the driveway after maybe a 4 minute drive it just died. Hit the key to re-start and was met with a dead cylinder and it died again. Hit the key again again, and was greeted by this delightful noise: (the squealing is because I took the valve cover off to make sure a rocker wasn't shattered)
                Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.
                So, yeah. Sounds an awful lot like rod knock to me. I've got an inspection camera on the way to take a gander in the cylinders. I've looked for exhaust gasket leaks and found nothing, no intake gasket leaks either. Based on all the rockers still moving normally my guess is that one of the rod bearings is making contact on ignition. Pretty frustrating, but it is what it is. I'll do more diagnostics tomorrow.
                • Northern
                  • 5270
                  Yeah that's a couple fun noises. Hopefully just a vacuum leak and valves needing adjustment...
                  • AWDBOB
                    hooptie connoisseur
                    • Aug 2013
                    • 4490
                    Sounds an awful lot like the last time an eccentric loosened up on me….. hoping for the best!
                    • econti
                      • May 2014
                      • 1149
                      Did a valve adjustment, oil change with 15w50, and now it sounds like this:
                      If it were a M5x I'd say it's just a lifter that needs to be pumped up, but it's not, so it isn't. I saw a tiny bit of gold glitter in the oil, not enough for the usual wiped out bearing kind of destruction but definitely some unwelcome shiny.
                      I've got a cheap ebay boroscope on the way to have a look in the chambers and see if its a lightly bent valve or something but I don't think it will be. I'll do another valve adjust to be 100% sure they're fine.
                      My current hypotenuse is that a rod bearing grabbed and then freed up again, hence the small amount of glitter, but its spun so now just knocking a little bit.
                      • AWDBOB
                        hooptie connoisseur
                        • Aug 2013
                        • 4490
                        For whatever reason in the video it still sounds like top end.... piston slap, loose cam bearing clearance (typically gets a little better with heat in the motor in my experience if its this), eccentric adjustment too loose, oil tube in head not dripping oil, one missing rocker pad, or missing tab holding rocker shaft rods causing rocker shafts to spin slightly and block oiling holes.
                        The fact that it didn't exist then did after a test drive you can probably rule out piston slap.
                        All that said, you're the one in person with the car and it's always tough to capture the sound, so it may very well be rod knock.
                        • 82eye
                          • Jan 2009
                          • 2087
                          hard to hear much above the valve train. i do hear something lower though. would expect it to be more dramatic if it's a spun bearing ... maybe i just blow them up better lol ?
                          i did put a rod through an m10 once
                          • econti
                            • May 2014
                            • 1149
                            Crisis maybe averted? Hopefully at least.
                            I went over the top end with a fine toothed comb as I still wasn't sure where the clatter was coming from. In doing so, I realised that the oil spray bar thingy was a bit bent and bunged up, and so wasn't spraying on cyl6 exhaust rocker and cam lobe. With the hole cleared and it rectified the noise went a lot lot quieter, so I was on the right track. I then did its valve clearance again, tighter than the book value says, and its sounding like a normal M20. I think the bottom end is perhaps a bit suspect considering the oil was 4 years old and probably bunged the spray bar up for a reason, but with a diesel flush and some temporary 50 weight w/ Lucas additive it seems quiet enough. I'm not tracking the shitheap, it's just an auto convertible.
                            So, onto fixing more things.
                            Everyone's favourite job, odo gears:
                            Central locking was completely dead. I went through the e30zone wiki, god bless whoever keeps paying for hosting, that said to check out the relay in the driver's speaker footwell area.
                            On a convertible the kick rail trim means you can't take the speaker grill off without removing the trim, or so the internet says; with a tiny corner of the trim cut back, it slides out, saving the risk of smashing the irreplaceable trim.
                            Removing the central locking module I found this: it's low heat solder, as a basic sort of fusible link. When it gets hot, the solder melts, the strip springs back and cuts power to central locking. A quick bit of solder and it was repaired.
                            This worked tremendously well a total of one (1) operation of the key. Second go, it locked, then pulsed the locks a bit then assumedly melted the solder. Now the passenger door is stuck deadlocked which is fun. That's tomorrow's job.
                            Anyway, I worked out how to put the roof down and took it for a burn to the gym then to the servo. Misfire is almost completely gone now with some fresh fuel and injector cleaner.
                            Incredible car for cruising. Indicators on the left side of the wheel mean my right arm never has to leave the door, just as the lord intended. These cars would be incredible for drink driving.
                            Standard springs + 14" wheels = smooth ride for ya bevy. Love these shitboxes.
                            I've got some brake pads on the way, I've got to fix the cluster backlights and the headlight dimmer, headlight adjustment, and the roof void cover thingy struts are on their way too. Great car just in time for summer.
                            • econti
                              • May 2014
                              • 1149
                              Little bit later, still running fine. I think I was phenomenally lucky catching the valvetrain problem before any damage occurred.
                              Swapped around parts from a few spare clusters, made that all work. Did brake pads, still a loooong pedal but stops way better.
                              Gave it a good clean in some of the problem rust areas. Don't understand why people neglect to wash the boot corners, takes like 5 minutes
                              Discovered that injector cleaner is majority kerosene and acetone so I made a jungle juice that seems to have worked quite nicely, with the bonus of looking cool (the dirt is on the outside of the jar)
                              Looking like a sweetheart as it should
                              And parked next to my original 318is which I really should do some work on. First job is to put the entire sunroof assembly back in which I am dreading, hence the procrastination.
                              That's about it for now. It's booked in for a complete soft top replacement early November as that's very clapped out. I've got some poly control arm bushes that just turned up that I'll fit this weekend. Also discovered the tyres are from 2009 so that's on the 'very soon' list, as is timing belt and water pump.
