I'm a poor-sha guy now
  • 2mAn
    Señior Mod
    • 20969
    #76
    Thought I was out of the storm! Pelican Parts had ONE ground cable left in stock and I had just enough time to pick up my kid and head straight out there to pick it up.
    Success!
    or so I thought... Car immediately came to life with the new ground cable, but so did the hesitation and stumbling. Got some codes and it looks like I have a vacuum leak.
    T-Minus 30 hours...​
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
    • MrBurgundy
      R3V Degenerate
      • Mar 2012
      • 5596
      #77
      adventure
      • Chilezen
        I weld cats
        • Dec 2013
        • 1938
        #78
        Wtf? That's a clean cut on that ground cable. You just.. pulled it apart?
        Currently building a badass coffee table
        Random stuff on insta @kevanromero
        • MrBurgundy
          R3V Degenerate
          • Mar 2012
          • 5596
          #79
          as Simon and I were scratching our heads as to why there was 0 electrical power, I went to touch the negative battery cable to the battery to see if there was any spark that you’d normally see when attaching a battery.
          it literally just fell off lol. There was no battery tie down so the battery was hopping around in there and it severed right at the metal section that is crimped on the copper wiring
          • 2mAn
            Señior Mod
            • 20969
            #80
            Where did we leave off? ... Vacuum leak and a ton of codes.
            Step 1 was to pull off the airbox and grab the mini mirror to see if I could find anything on the crossover pipes. Luckily it didnt take long to see it. I took a pic so you could see it too...
            Could it be an easy repair for once? with less than 24 hours to go?...
            Yup! That was it. My first real drive was riddled with traffic as I used the smooth running idle as an excuse to drive the ~5 miles round trip to pick up my daughter from Daycare. She gets more excited to see the Porsche than my wife does haha
            So the next day was at the PEC.
            All smiles
            My buddy joined me and took some pics. I have some more on the way. Next post will have em​
            Simon
            Current Cars:
            -1966 Blue Boat
            -1969 Red VW
            -1986 White BMW
            -2006 Green Thing
            • 2mAn
              Señior Mod
              • 20969
              #81
              Action shots!
              Car did mostly wonderful, I was having a good time pushing it for the full session. However, it wasnt totally flawless. I had a code for P1397, Camshaft Position Sensor 2. Car wasnt running odd so I ignored it. After the session I checked the codes again, especially since there was a random idle surge that came and went. P1514 Idle Air Control Valve Opening & P1551 Idle Air Control Valve Closing. Sounds like I need to pull the Idle Control Valve and clean it out, but not sure what to do about the Camshaft Position Sensor.​
              Simon
              Current Cars:
              -1966 Blue Boat
              -1969 Red VW
              -1986 White BMW
              -2006 Green Thing
              • 2mAn
                Señior Mod
                • 20969
                #82
                After a month passing which was just cleaning the ICV and still having the lumpy idle I sent the car to JMP last week to install the adjustable GT3 arms and also dealing with the idle.
                Going to get a corner balance and alignment when they are done too, so we'll see exactly how much this Beetle weighs
                I have a few updates from the shop and it looks like my aggressive driving has yielded its first casualty. Chances are this would've happened eventually but it looks like the corrugated plastic hose was rubbing against stuff in the engine bay and has a pinhole leak that was revealed during the smoke test. They will repair this section and confirm that there are no other leaks. Initial patch showed the idle settle down.
                The other update was that these arms will not work. Looks like the solid bushing wont fit, but luckily the old arm still has a good rubber bushing.
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                • Panici
                  • Dec 2009
                  • 2535
                  #83
                  Getting caught up on your thread Simon.
                  That engine bay looks like an absolute nightmare to work in. The driving experience must be worth it!
                  Car looks like a stunner out there on track. Your ugly duckling sig pic on every post really throwing me off haha.
                  • 2mAn
                    Señior Mod
                    • 20969
                    #84
                    I hope to never have to work in that engine bay again, but I'm a glutton for punishment so I'm sure there's more things I will do myself soon and refuse to pay a shop to do...
                    That said, I signed up for a track day at Streets of Willow on December 9th which should be a blast. I will be out there with JMP which has been always my go-to BMW shop.... who also helped with the last job.
                    As for the sig pic, that was courtesy of my number 1 fan here on R3V and shockingly, nobody on Rennlist has made any comments about it.
                    Simon
                    Current Cars:
                    -1966 Blue Boat
                    -1969 Red VW
                    -1986 White BMW
                    -2006 Green Thing
                    • AusScare
                      • Jun 2014
                      • 220
                      #85
                      Good to see you getting out there and enjoying the car! Love the updates.
                      '90 318is
                      • 2mAn
                        Señior Mod
                        • 20969
                        #86
                        One thing I forgot to add. Part of what JMP did was a corner balance after installing all of those suspension arms. Ignoring the benefit of the corner balance I was more concerned with the weight. They are factory rated at 2901 and my weight reductions should've put it right around 2800, but sounds like 2901 is a dry weight.
                        I have 2 items coming soon that should be me to an actual 3000#-dead. My goal of 2750 seems a little bit more difficult, but if I can get it into the 28xxS than it should be a hoot!... We'll see.
                        Simon
                        Current Cars:
                        -1966 Blue Boat
                        -1969 Red VW
                        -1986 White BMW
                        -2006 Green Thing
                        • roguetoaster
                          Biggus Tippus
                          • 7830
                          #87
                          Rennlisters are getting lazy, or have never seen multiple generations of MR2s. Glad to hear that the low quality image is at least disconcerting someone here at the very least.
                          • moatilliatta
                            • 6152
                            #88
                            Weighs just as much as my Cayman. SPC makes a nice toe link with rubber bushing.
                            @Zakspeed_US
                            • 2mAn
                              Señior Mod
                              • 20969
                              #89
                              Verified weight or estimated?... also why do we NOT have a thread on the Cayman. I love your E30 so I can only imagine what the Cayman is like.
                              According to Porsche Excellence mag, the 996.1 should be 2901 and the 987.1 Cayman 2976
                              https://www.excellence-mag.com/resources/specs/57
                              https://www.excellence-mag.com/resources/specs/211
                              I had my original weight estimate based off that, but yea was (sort-of) surprised. Considering mine has actual hollow spokes and some sound deadening removed I was hopeful it was that light (~2800). I do have the 3rd radiator and a deep sump oil pan so those add weight, but not 250#. However add those items, a full tank of gas, all the oil, and coolant... that could be the difference. In the end, its just a number and now I can work towards getting it under 3000# and going from there.
                              Simon
                              Current Cars:
                              -1966 Blue Boat
                              -1969 Red VW
                              -1986 White BMW
                              -2006 Green Thing
                              • roguetoaster
                                Biggus Tippus
                                • 7830
                                #90
                                Cayman > 911. Personally, I think a 987.1 despite the lower power, lack of a 6th gear, and no LSD would be the way to go for a street car. Maybe it's just that they're the cheapest ones.
