Eta-to-M50: Build thread
  • Jand3rson
    • 37587
    #916
    Originally posted by bimmerteck
    . . .and all was as it should be. :D
    I'm sending this thing your way in the morning, bolts and all. Cleaned up pretty nice considering how covered in oil it was.
    Photo by systemdelete, on Flickr
    Awesome, thanks a TON man! Andrew is taking some measurements of that wheel bearing tool, and then I'll ship it back to you. He wants to see if he can make one!
    • uofom3
      • Jan 2004
      • 5392
      #917
      That thing is tits! Awesome Josh!
      PNW Crew
      90 m3
      06 m5
      • drutt23
        • Feb 2011
        • 392
        #918
        It's always been like that, it's kinda strange. Must be an early model thing, my car is an 01/86.
        Oh ok gotcha. Just curious cuz I don't think I've seen one like that before...
        1989 325i|1992 325i|And completely obsessed|:woowoo:
        sigpic BMW. The Ultimate Driving Machine.
        The Build...
        • Matt-B
          The Waffler
          • 3856
          #919
          I think it is because the harness from older cars, that have square plug have it running between firewall and box..
          nice progress man, I got mine in
          • Jalves619
            • 596
            #920
            Top 2 inside the boots go to the OBC horn, or at least they did on my 85.
            • dirty30
              • 3013
              #921
              Thats strange about Greg... I just got an 84E adapter and the transaction went smoothly.
              • HighOnLife
                • Jan 2009
                • 209
                #922
                Is there any way you can send this Andrew guy up to Canada when you're done with him? I could use some help with my harness :)
                Dale
                1991 E30 Touring
                • 87e30
                  • Jul 2008
                  • 5676
                  #923
                  I do still have a few questions, tho. I can't figure out/remember what the 3 things pointed to by the yellow arrows are for/connect to. At the top, what do those 2 connectors inside the rubber boots go to, in the middle, what do those 2 small connectors go to, and at the bottom, what do those 2 wires go to?
                  I'm guessing you already know.
                  I can't tell too well what the two sensors closest to the firewall are. I don't recognize them, are they left behind from the two bellhousing sensors in the trans?
                  The two smaller slip on connections with brown wire (it looks like) are for the reverse signal on the trans. (again, pretty sure)
                  No clue on the last one.
                  If you already figured this out, how'd I do? haha
                  I just hate everyone.
                  No need for discretion.
                  • Jand3rson
                    • 37587
                    #924
                    So the reverse lights come on, right? What do they connect to? Isn't there a wire that comes up from the transmission through the shift boot that connects to them somewhere? I cannot for the life of me remember how that goes. Help me out here, I'm a little lost on these last few things.
                      • 34839
                      #925
                      the reverse wire is chassis side on E30s, it doesn't hook into the engine harness like the E36. So however it was before - check the ETM?
                      • Jand3rson
                        • 37587
                        #926
                        I found the wire that goes from the tranny up through the boot for the reverse lights, it was still on the old shift carrier. :D
                        And now that I think about it, those 2 sets of connectors were never hooked to anything, I don't remember unplugging them from anything. I still need to figure out what that blue and yellow wire are for.
                        • Matt-B
                          The Waffler
                          • 3856
                          #927
                          e36 motor? I thought Danny posted in an old thread, you can remove from harness, or just leaving hanging, on e36 harness cars
                          • AndrewBird
                            The Mad Scientist
                            • 11898
                            #928
                            You don't actually have a C101 connector anymore. You have an X20 connector. ;)
                            • Jand3rson
                              • 37587
                              #929
                              Right.
                              Just spent a good deal of time doing some more cleanup in the bay. Removed all of the foam/tar backing junk from my blower motor cover, and with the spare inside part of a 318is harness cover, mocked up and zip tied all of the harness up and into it's final locations. I'll remove it and clean up a little better when my new set gets here. And yes, that blower motor cover will be cleaned up and painted. :)
                              • MrSlacker
                                • 2494
                                #930
                                Looks like it will be alive very soon. Cant wait!
                                My Seller/Buyer Feedback
                                Performance Aftermarket Parts & Accessories
