Kamotors E30-Turbo to ITB M20
  • DirtyTh3rty
    • May 2015
    • 101
    #3571
    Good stuff Kam glad to see old red can get some attention again!
    88' BMW 325is - Daily
    • kamotors
      • Nov 2007
      • 7102
      #3572
      Originally posted by imjusthere
      What's the reliability like with ITBs? My e30 is my DD. Would this be a good idea or not?
      Same as stock, your not putting any additional stress that would make it unreliable. But if you need smog w/ visual inspection i don't think it'll fly lol.
      Sent from my SM-N920T using Tapatalk
      7speedshop.com
      • Good & Tight
        • Apr 2004
        • 2057
        #3573
        What's with "The End" in the title..? Your a mod fiend there is no END..!!!!!
        Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
        ____________________________
        E-mail Panayiotisx2@gmail.com
        Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
        • Bullet Ride
          • Dec 2010
          • 598
          #3574
          Keep in mind that you are adding more moving parts to the system. Although reliability may not suffer, there are more things that you will have to keep an eye on in order to maintain the reliability moving forward.
          • 318aye
            • Jun 2010
            • 895
            #3575
            I would agree with this more than "same as stock". Am I afraid to drive the car 5+ hours away? Nah. Do I travel with the necessary allen keys to disassemble the throttle linkage and AAA? Yeah.
            The only thing that degraded for me over the last 5000 miles was the TPS, and that's been solid for about 6 months.
            It requires some attention, but nothing out of the norm for a modified 80's car.
            • digger
              • Nov 2005
              • 6216
              #3576
              I’ve been using RHD ITB’s for 2.5years (Airbox for 2 years) the only issues I recall having had are with TPS’s or not setting up and balancing linkages correctly because I screwed up or forgot to tighten something properly so not an issue with the throttles. He uses a different TPS with the kit these days which ive never tried but I bought a Penny and Giles TPS and have never looked back as even new OEM sensors seemed to give odd behavior.
              I got one of the early kits so I had to add a return spring but that’s included now. I also found it a little awkward to access the idle screw adjuster and balance grub screws but I modified my tools so overcome this and I keep them in the trunk in my extra toolkit so I don’t lose them.
              Probably one short coming over other throttle kits is not being able to individually adjust each throttle as they adjust in pairs only, no matter how good the machining is there is always differences due to individual variations in the engine itself so you can’t get it 100% balanced. However it still idles very well and part throttle over single throttle is 10x better. I can easily coast in 3rd at idle speed and pullout of tight corners without any hiccups something that was impossible on the single throttle manifold no matter how good the tune was.
              As for whether its a good idea that would depend on your goal(s)
              • kamotors
                • Nov 2007
                • 7102
                #3577
                The new tps bracket is nice and I'm using an OEM Bosch m50 tps, so shouldn't have any issues.
                Also car would of been running today but then I noticed this lol. Must of slipped out then when tightening it I crusher it into 2 pieces lol
                7speedshop.com
                • kamotors
                  • Nov 2007
                  • 7102
                  #3578
                  Found the most 80's zender e30 spoiler lol. Still in original rubber which is cool just needs some prep and paint. Not sure whether I'll sell it or keep it though. It's a bit on the bulky side, but it'll be a fun restoration project and would look cool on a more 80s themed e30
                  7speedshop.com
                  • bangn
                    • Sep 2011
                    • 760
                    #3579
                    YUCK! liked your home made spoiler better
                    Boris - 89 E30 325i
                    84- E30 323i
                    • digger
                      • Nov 2005
                      • 6216
                      #3580
                      Originally posted by 318aye
                      Is there a reason the 2.8 route seems heavily favored over the 3.0 route? Is there something I'm missing aside from custom pistons that makes the cost astronomically higher? I feel like the 800 bucks to get whatever compression ratio you want and use 135mm rods would be worth it. Open question to you, digger and whoever else.
                      sorry kam.
                      budget 2.8 vs off the shelf pistons
                      It’s just cheaper with OEM bits, it may be cobbled together a bit but it works and you aren’t giving up massively for a basic street build but you have more options with custom pistons.
                      Ultimately if you can afford custom off the shelf or true custom then it kind of makes sense you will definitely see some benefits e.g. , slightly more compression, more PtoV so more choice of cam profiles, slight increase in capacity and able to get bores oversized, thinner rings and or different materials, slightly lighter pistons, 4% less side loading due to 5mm longer rods so slightly less friction and wear, More tolerance to bad tune, better choice of rods, bragging rights, cool looking parts…. it’s hard to quantify some things as they are subtle and frankly basically irrelevant in the grand scheme with the goal of making more power or torque. Its upto the individual if they see enough benefits.
                      Don’t expect night and day differences unless you’re designing something for a different type of goal, e.g. a high rpm kind of race engine you probably wouldn’t go for short rod, cast piston but on this kind of engine its not just going to be the piston and rod that differ the whole engine would be different.
                      • kamotors
                        • Nov 2007
                        • 7102
                        #3581
                        So close....https://youtu.be/ay0CnD9DB94
                        7speedshop.com
                        • kamotors
                          • Nov 2007
                          • 7102
                          #3582
                          Started right up! still running speed density(turbo tune) as I havent even got it out of the garage yet. So its on a cyclical map signal and idle was way high. Got idle sorted out but still need to tune it to run alpha N
                          7speedshop.com
                          • rzerob
                            • Jun 2013
                            • 2315
                            #3583
                            Wait you can run RHD itb's with a brake booster? I didn't think there was enough room with RHD setup. What brake booster are you running?
                            • ForcedFirebird
                              • Feb 2007
                              • 8300
                              #3584
                              Stock booster clears ;)
                              john@m20guru.com
                              Links:
                              • 318aye
                                • Jun 2010
                                • 895
                                #3585
                                Haha yeah man. That's probably one of the biggest selling points. Clears the airbox too.
