Emma Watson and 2 E34's (Low Mount Turbo M50 Project)
  • zwill23
    • Jul 2015
    • 615
    #526
    Seems like you've already pulled the trigger anyway, but going from the photos it seems like there are some small pings on the fire ring. Maybe not enough to blow the gasket, but I thought it might be indicative of some pinging. Maybe that's just due to the crush while torqueing the head studs? Either way, hope the rebuild goes smooth. Looking forward to seeing some redemption numbers.
    • Dj Buttchug
      • Jun 2010
      • 7688
      #527
      I believe these indents are premade into the gasket so the valves will clear. There is one located in the lower right of the sealing ring as well.
      The m50 is completely torn down now and so is the m52 engine I had as an extra.
      The plan now is to use the 2.8 crank with 135mm rods. Stroker M50 on way. There will be a bit of downtime on updates as I am waiting for pistons which are 1-2 months out.
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • Dj Buttchug
        • Jun 2010
        • 7688
        #528
        Little things now waiting for engine block machining
        Rebuild oil pump, new spring, plunger and o ring.
        Ig:ryno_pzk
        • Dj Buttchug
          • Jun 2010
          • 7688
          #529
          Block, cylinder head and crank on its way to socal.
          Ig:ryno_pzk
          • Dj Buttchug
            • Jun 2010
            • 7688
            #530
            The time has come my brothers.
            Ig:ryno_pzk
            • varg
              Florida Turbo Man
              • May 2014
              • 3429
              #531
              Yes, it is time. Glad to see it. Nice Molnar rods too, I wish they weren't backordered when was buying my parts. Good luck with the build!
              IG @turbovarg
              '91 318is, M20 turbo
              • LJ851
                • 7919
                #532
                I like where this is going !
                Lorin
                The M30 is God's engine.
                • Dj Buttchug
                  • Jun 2010
                  • 7688
                  #533
                  As soon my absolute shit storm Terminator X ECU swap to run my M42 is done assembly will begin. All was going well until I figured out you must have a cranking speed of over 250ish RPM to sync the crank and cam sensors... Turns out we are only turning sub 190 or so meaning the E30 is dead in the garage and I need the space to build this engine.
                  Should have some more updates soon.
                  Ig:ryno_pzk
                  • Dj Buttchug
                    • Jun 2010
                    • 7688
                    #534
                    Alright lets get started while I wait on new oil squirters.
                    Tungsten Cerakoted Block.
                    Ig:ryno_pzk
                    • Dj Buttchug
                      • Jun 2010
                      • 7688
                      #535
                      Squirters came in from the mother land. Heres a few photos of the crank install. Checked my machine shops work and installed the crank. All main bearing tolerances are .001 +/-.0005. Using Permatex engine assembly lube. Dropped the crank in and torqued in three steps to 60 lb ft per ARP instructions. The only thing throwing me off a tad is my crankshaft end play. Spec with oiled parts is .006. My engine is at best .004
                      Not sure if that is because of this gooey juice I am using or what.
                      If anyone has any 2 cents on that chime in.
                      Otherwise no issues. Crank spins in block but it takes a little force to move it. Not much but enough where both hands are required. I think we are in the money.
                      ​One step closer to clapper 5 Emma Watson tribute build back running.
                      Next up check rod bearing clearance and start the tedious process of pairing rods with pistons and grinding rings...
                      Ig:ryno_pzk
                      • Dj Buttchug
                        • Jun 2010
                        • 7688
                        #536
                        The crankshaft seems a bit tight to me. Does anyone have any thoughts on this. Check my work.
                        Main bearing tolerance .0008 to .0023. My measurement check with plasti gauge was .001 to .0015 on all 7 mains. The crank takes a considerable amount of force to spin. I want to verify this is ok before I proceed. Let me know what you guys think.
                        Main 1 (starting at front of engine)
                        Main 2
                        Main 3
                        Main 4
                        Main 5
                        Main 6
                        Main 7
                        Ig:ryno_pzk
                        • Dj Buttchug
                          • Jun 2010
                          • 7688
                          #537
                          Confirmed all ok with my machinist.
                          Moving on now to pairing internal parts for balancing.
                          Ig:ryno_pzk
                          • Dj Buttchug
                            • Jun 2010
                            • 7688
                            #538
                            Short block finishing up.
                            Ig:ryno_pzk
                            • Dj Buttchug
                              • Jun 2010
                              • 7688
                              #539
                              Modified windage tray to clear ARP studs
                              Ig:ryno_pzk
                              • Dj Buttchug
                                • Jun 2010
                                • 7688
                                #540
                                GT30 going on this round.
                                Ig:ryno_pzk
