Emma Watson and 2 E34's (Low Mount Turbo M50 Project)
  • Dj Buttchug
    • Jun 2010
    • 7688
    #556
    ^ That is an excellent idea! I would have to remove the factory hood insulation no matter which way I went. I need to inspect the hood and see if that modification could be done.
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • Dj Buttchug
      • Jun 2010
      • 7688
      #557
      Some exhaust work in progress converting to a full 3 inch set up. Ignore the disgusting undercarriage.
      I hate building exhaust.
      Ig:ryno_pzk
      • Dj Buttchug
        • Jun 2010
        • 7688
        #558
        Version 2 exhaust is close to completion.
        Extravagant dump pipe V banded so I can remove the complete center section of the system for service without the need to remove the wastegate. Cool. 3 inch stainless to dual 2 inch collector mated to Super Sprint 304 Muffler. Vibrant bottle style 18" resonator to keep any drone away.
        Ig:ryno_pzk
        • 2mAn
          Señior Mod
          • 21049
          #559
          What’s with all these BMW pics.. we need more Emma Watson lol
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          Make R3V Great Again -2020
          • Dj Buttchug
            • Jun 2010
            • 7688
            #560
            I agree. This thread has derailed horribly.
            Current state of fckery.
            Small tasks to do such as routing vacuum lines. installing IC piping and oil lines. Time to crank the engine and check for oil pressure soon.
            Ig:ryno_pzk
            • 2mAn
              Señior Mod
              • 21049
              #561
              As usual… doing my part to keep this ship afloat…
              Simon
              Current Cars:
              -1966 Blue Boat
              -1969 Red VW
              -1986 White BMW
              -2006 Green Thing
              • Dj Buttchug
                • Jun 2010
                • 7688
                #562
                ​A fine wine our goddess ages.
                Ig:ryno_pzk
                • OSAH racing
                  • Apr 2022
                  • 244
                  #563
                  Emma has some big footprints to follow.
                  Just for Fun: if your born in the 60's, became a man in the 80's this is your English beauty. Still stunning today.
                  • Dj Buttchug
                    • Jun 2010
                    • 7688
                    #564
                    Spy my meth port. I will try a single nozzle and see how that favors. If things dont work out I can move to a port injection system later. The charge pipe from compressor housing to intercooler does not fit quite right after switching the turbo and manifold. I will have to fabricate a new one with a different bend.
                    Getting closer to first start up.
                    Ig:ryno_pzk
                    • Dj Buttchug
                      • Jun 2010
                      • 7688
                      #565
                      Here is a couple pics showing how little room we are working with on the hot side. This sht is getting ridiculous. No wonder its taken me two years to construct this mess.
                      Maybe I will make all the piping one color with the correct insulation. Maybe I wont. Maybe who cares. Maybe suck my balls.
                      The turbo is so packed in there you cant even remove it in one piece. This car needs a complete manual just to know how to work on it. Probably should of gone top mount. Wouldnt that be so easy...
                      Only a few more tweaks now thankfully.
                      Ig:ryno_pzk
                      • varg
                        Florida Turbo Man
                        • May 2014
                        • 3431
                        #566
                        Yeah that hot side is crowded no matter what you do. It has been a battle for me since day one. I'm probably going to have to revise my AC lines somehow to get them to hug the firewall better and mount the service ports higher, like where the fittings are now. At least it isn't like the E39 though, where the ABS unit is mounted where a turbo belongs.
                        IG @turbovarg
                        '91 318is, M20 turbo
                        • Dj Buttchug
                          • Jun 2010
                          • 7688
                          #567
                          Yea. Id say the only thing I havent had to touch is the AC lines.
                          Ive been thinking. What engine oil are you using in your E34?
                          Ig:ryno_pzk
                          • varg
                            Florida Turbo Man
                            • May 2014
                            • 3431
                            #568
                            I've used Mobil1 (15w50?) and Delvac 15w40 (mostly this) in it. Delvac is cheap and meets the required standards, which is important when the damn thing won't stop leaking or burning oil. For break in I used whatever the metric mechanic engine break in instructions pdf recommended.
                            IG @turbovarg
                            • Dj Buttchug
                              • Jun 2010
                              • 7688
                              #569
                              Is it synthetic?
                              Ig:ryno_pzk
                              • varg
                                Florida Turbo Man
                                • May 2014
                                • 3431
                                #570
                                Is it synthetic?
                                Which? Delvac no. The break in oil no, I looked it up, it was Havoline 10w40.
                                IG @turbovarg
