Emma Watson and 2 E34's (Low Mount Turbo M50 Project)
  • Dj Buttchug
    • Jun 2010
    • 7687
    #571
    Originally posted by varg
    Which? Delvac no. The break in oil no, I looked it up, it was Havoline 10w40.
    Right. Reason I ask is because we have had several instances where people at our shop are running synthetic oils in these older cars and every gasket sweats, leaks start from all over and no matter what you cant seal the engine up. Switching to a good conventional stops all the leaks ( or a good majority of them) My plan was to start with and potentially stick to a conventional Castrol in my E34 engine. Ive had the same issue with my M42. Apparently the molecules in the synthetic oils are smaller...??
    I wonder if conventional oil would reduce your oil consumption problem but it sounds like you had ran that prior and the results are still the same.
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • AWDBOB
      hooptie connoisseur
      • Aug 2013
      • 4501
      #572
      Subtle flex using $26 of gates barricade for your airbox grommet
      Lookin good!
      • Dj Buttchug
        • Jun 2010
        • 7687
        #573
        Lookin good!
        LOL make no mistake. I am broke.
        Good point I should say. Not the ideal material to use for sure.
        Ig:ryno_pzk
        • Dj Buttchug
          • Jun 2010
          • 7687
          #574
          The stepchild is out!!!!
          First 5 or miles of break in complete. Kept it under 5k and no more than about 6-7 pisseyes.
          NO LEAKS
          NO SMOKE FROM THE EXHAUST.
          When the M50 is all lined out this photo will have about 900 HP in it.
          Time for a much needed wash.
          Ig:ryno_pzk
          • Dj Buttchug
            • Jun 2010
            • 7687
            #575
            Celebratory brew and a much needed wash after over a year of building.
            We have some small tuning quirks to sort out. The idle control lockouts and decel overrun is causing the engine to randomly stall when you depress the clutch coming to a stoplight. I built a new VE table mirroring my E30 and its pretty damn close. LINK PNP is complicated. The Aussies built this ECU after ripping a couple blizzies. This morning I flushed the cooling system with distilled water to remove any debris left in there from the build. A good bit came out in the fluid so I am happy with that for now. I will do an oil change in about 100 miles. Castrol 10w-40 CONVENTIONAL.
            I got my hands on some pretty slick quick disconnect oil fittings for my oil cooler so I will be installing those soon. It will allow me to disconnect the oil filter distribution block during an oil change without having to fight the AN lines.
            Then soon after 500 or so miles of break in I will take it to the dyno and post a chart. Still to finish is some sort of fix for the cars paint (wrap the stock color or try and save whats here) I also have some ideas for a front splitter, rear diffuser and E90 skirt trim to finish this off.
            As stated previously in this thread many times. Do not attempt this build unless you are ok with dragging your nuts across broken glass for 2 years.
            Total build costs as of now (obviously no labor)
            +/- 750 hrs of research and wrench time. (Probably conservative here as it is likely more)
            Total estimated cost all in as the car sits. +/- $37,500.00
            Ig:ryno_pzk
            • AWDBOB
              hooptie connoisseur
              • Aug 2013
              • 4501
              #576
              That's gotta feel good- nice to see you tracked hours too. When I tell someone how many hours it takes me to mechanically revive a shitbox E30 most just laugh and assume it's not a real number. The opportunity cost of building these cars is real
              • Dj Buttchug
                • Jun 2010
                • 7687
                #577
                Totally. Things add up so quickly. Only those who have done it really understand what it takes. Its safe to say I am officially burnt out with custom projects. This will be the last turbo build I do ( at least for a very long while) With my first kid on the way here in November most of my time will be taken up.
                Ig:ryno_pzk
                • Dj Buttchug
                  • Jun 2010
                  • 7687
                  #578
                  Another 30 miles of engine break in done. Making boost at 2400rpm. Very nice for a street car.
                  However, I would like to see more air moving past my cooling system. Earlier a discussion was had about hood vents. I have ordered some from Condor. One on each side paint matched to keep the rice down. It is the only effective way I can think of to reduce the positive pressure in the bay.
                  Ig:ryno_pzk
                  • 2mAn
                    SeƱior Mod
                    • 21014
                    #579
                    Car looks fantastic. Hope all the hard work makes it a smooth process from here
                    Simon
                    Current Cars:
                    -1966 Blue Boat
                    -1969 Red VW
                    -1986 White BMW
                    -2006 Green Thing
                    Make R3V Great Again -2020
                    • OSAH racing
                      • Apr 2022
                      • 244
                      #580
                      I agree, What a great looking street car.
                      • Dj Buttchug
                        • Jun 2010
                        • 7687
                        #581
                        Is it goy or is it not gay
                        That is the question.
                        Ig:ryno_pzk
                        • OSAH racing
                          • Apr 2022
                          • 244
                          #582
                          I would not.
                          • varg
                            Florida Turbo Man
                            • May 2014
                            • 3428
                            #583
                            Well you already know how I feel about hood vents, but I cooked my AC lines with my stubbornness. As part of my winter projects I'm probably going to put another fan in the engine bay that just forces cool air in on the exhaust side.
                            IG @turbovarg
                            '91 318is, M20 turbo
                            • Dj Buttchug
                              • Jun 2010
                              • 7687
                              #584
                              I agree guys. I cant get up the motivation to do it. If I had an extra hood maybe but I think I may return these and figure out a different option. I want the car to look stock and the vents are just to raced out for me.
                              I did find a problem with my coolant temp sensor that was causing issues with cold temp and hot temp readings. I was getting a 30 degree incorrect cold reading and a 10-15 degree normal operating temp reading. At 180 degree normal temp LINK ecu was showing 192-195 and cold IAT temps would be say 45 degrees in the morning and ECT would read close to 100.
                              5v reference on coolant temp sensor wiring was the culprit. 4.03v was all I could get so that pointed to a partial short somewhere drawing the voltage down. To fix the issue I had to pull new wire through the loom and replace number 78 pin. I installed a new 2 pin connector that plugs to the sensor. After testing the voltage the 1v drop is now gone.
                              This problem has lead me to believe my engine was operating hotter than it actually was. Now that I have it sorted we may be ok with cooling. Only further testing will confirm.
                              I have yet to get the car to a dyno
                              Hopefully in the next few weeks I can get some time set aside to get a good tune written.
                              Ig:ryno_pzk
                              • 2mAn
                                SeƱior Mod
                                • 21014
                                #585
                                Can you vent out the fenders like the Z3 supposedly did?
                                Simon
                                Current Cars:
                                -1966 Blue Boat
                                -1969 Red VW
                                -1986 White BMW
                                -2006 Green Thing
