1990 325is restomod project aka "Klaus"
  • R3Z3N
    • Jan 2011
    • 3056
    #571
    As all my IMGs are hosted on my server, any reference to the GEN 1 pic has been corrected as you will see in post 565
    • maxpostma
      • Oct 2018
      • 91
      #572
      Originally posted by masterofnone
      Untitled by Evan Nessim, on Flickr
      Really cool build!
      Just to be sure:
      So it's possible to use pin 4 of the x60004 connector of ms43 (e39 530i)
      for a signal to trigger a relay which triggers a electric fan @200F? This without adding an additional temperature sensor.
      I'm asking because I'm planning to use the e39 electric fan to cool down the radiator in a e30.
      M54B30 E30 build:
      https://www.r3vlimited.com/board/sho...d.php?t=426585
      • Staszek
        • 2533
        #573
        Originally posted by maxpostma
        Really cool build!
        Just to be sure:
        I think you need to ask R3Z3N, I believe you can you just need the file to have it programmed correctly.
        • R3Z3N
          • Jan 2011
          • 3056
          #574
          Really cool build!
          Just to be sure:
          I know nothing of the MS43 ECU
          Instead of using a relay for the main fan, use a PWM fan controlle IE:
          Reason being, the PWM will spin up the fan gently as to not draw huge amperage on start
          Derale PWM Fan Controller
          • Staszek
            • 2533
            #575
            Small update, the fans are now working. Not sure if the Can bus is working right yet but at this point, I just want to drive the car and figure that out later.
            I took it for a nice rip around today, not far, just to test it out after alignment and I have a rubbing problem in the rear. Any time I load the car and it squats back the 225 tires are rubbing on the outer edge of the fenders.
            I am running 16x8 Et23 with H&R Sport Springs, didnt have rubbing before, but I think now that all the weight is back in the car with the E36 M3 exhaust and the bigger battery I am just getting a slight rub. I also have thinner spring pads. I think I am going to go back to the thicker pads and probably a slight roll which I didnt necessarily want to do. But at this point, I can't even dyno the car because it will squat back during the hard acceleration.
            That said the exhaust sounds awesome after I added the X Pipe. For those who didnt read back, I have Strasse Groupe Headers, to 2.25 inch dual section one with N54 Cats to a magnaflow X-Pipe back to dual 2.25 pipes into an e36 M3 exhaust.
            Here is the video of me revving with the windows closed than open. Sounds way better if you have headphones on or on a computer, the iphone regular speakers suck.
            Also a few pics of it sitting. I will say even with half throttle so I didnt rub bad the thing is crazy fast. I can start out in second and it feels like I am in first its so quick off the line.
            • AWDBOB
              hooptie connoisseur
              • Aug 2013
              • 4516
              #576
              Wow, the car is looking (and sounding) great! I envy the S54 swap- your car will be a blast. I rolled the rear on my setup (same wheels, but with a 215 instead of a 225).
              Honestly if you take it slow and heat up the paint properly to avoid cracking it only takes a small bit of time with a roller to get the job done, and you can make it look factory-ish.
              • Staszek
                • 2533
                #577
                Thanks, thats what I plan on doing. I mean the car is going to get repainted anyway when I put on the Mtech II kit, so for now I just want the thing driving well lol!
                I will say WOW what a difference the ZHP steering rack makes. The car feels like a go cart, its so quick to turn.
                • AWDBOB
                  hooptie connoisseur
                  • Aug 2013
                  • 4516
                  #578
                  Oh wow, I didn't realize you were going to paint and all that as well! Don't make it too nice or you won't drive it :D
                  Driving my car after the Z3 rack swap was amazing. Such an improvement in overall driving feel/experience.
                  • R3Z3N
                    • Jan 2011
                    • 3056
                    #579
                    Thumbs up!
                    • Staszek
                      • 2533
                      #580
                      Oh I have no fear of driving it lol!
                      • e30RS
                        • Mar 2019
                        • 437
                        #581
                        That is an incredible "gift."Love the build and the nickname. Both superb. Good luck going forward I will be checking back!
                        • 2mAn
                          Señior Mod
                          • 21088
                          #582
                          Glad to see that it’s basically done. Have you considered going one step up to the H&R super sports? They are right in between the Sport and Race
                          Simon
                          Current Cars:
                          -1966 Blue Boat
                          -1969 Red VW
                          -1986 White BMW
                          -2006 Green Thing
                          Make R3V Great Again -2020
                          • Staszek
                            • 2533
                            #583
                            Maybe, I actually have the 3mm spring pads on the rear, I’m going to swap that to the 10mm ones. Plus a slight roll. It’s sits so nice now.
                            • R3Z3N
                              • Jan 2011
                              • 3056
                              #584
                              With the usual S54 swap without the PWM fan, its best to put the MSS54/HP into Z3 chassis config which uses a dual relay setup like the E30. But with Garys solution or the one that Airventdisplay.no is coming out with, make sure your MSS54/HP is set for the default E46 chassis config.
                              • Jokester
                                • Sep 2016
                                • 1818
                                #585
                                The super sports are a lot softer of spring rate. I’d expect the rubbing issues to stay there if he went with the super sports or possibly get worse.
                                A little camber, roll the fenders, stronger springs. Call it a day
