Be cool to dyno with and without the SSSpacer.
The Journey of Linda and Friends - the M20b31 Lives
That’ll be easy-peasy to switch out on the dyno.Comment
I posted up my Stromung on the local Indy page with like 30 members and got a message from a guy who had the exact exhaust parts I was looking for and wanted to trade for a bolt-on catback. Funny how things work out sometimes. I got his bits plus some coin to contribute to the exhaust fab, so I think this will work out very well.
It's going to be 2.25" dual out of the headers, back 64" to the Y pipe which turns it into single 2.5" to the muffler which is single 2.5" in and a dual tip out.
Untitled by Bobbie Morrone, on Flickr
Pretty cool development- Jay (sssquid) is going to tune the car on Motronic, so I sold the whodwho setup to Bradnic. We have been chatting about it for a minute, and he feels confident we can get it tuned properly on the stock ECU with some new developments he has made.
He is modeling and CFD testing a bunch of stuff, I got an actual compression reading to go off of, should be interesting. Staying 3bar FPR but bumping up to a 24# injector.
Put fresh plugs in, drained out the "first start" oil and put in the good stuff!
Oh, and I really need help with exhaust. I've been through the wait list at 4 shops now, all who have since bailed.
dang dude. look at that engine bay. I'm 2-3 months behind you
definitely want to hear more about motronic tuning - maybe that will work with my 2.9 325 buildI BUY/SELL REFURBISHED CM5907s & CM5908s
HOWTOs:
DB vert plastic bumpers
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
e30m3s54turbo: I save my money for tuner parts.Comment
that is the best explanation I've ever seen. THANK YOU digger
the squish area on 200 and 731 is the surface bounded by the two red loops (the outer loop is the D86mm or bore and the inner loop is the chamber) the piston needs to be perfectly flat in the corresponding areas to maximise squish which means the two surfaces will then come within around 0.035" and 0.045" (parallel seperation) of each other to squeeze the air increasing the turbelunce speed in the chamber and moving the charge towards the spark plug. Its no coincidence the squish bad is the farthest / opposite region from the plug.
HOWTOs:
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
AWDBOB, if you are still looking for a center muffler/resonator to minimize drone I'd suggest looking at snagging an E46 one. It's the only thing I've been able to find that is small enough to fit in the tunnel.'87 5-speed 325is
The best $750 I ever spent!
Are you in Michigan?
Do you want to know where all the E30's are?
Try checking out the Michigan E30 MapComment
I ended up with a vibrant ultra quiet resonator after the Y, into the 14815. We shall see how it sounds!Comment
Oh yeah, after the Y there are options. I thought it was going before the Y. The E46 option is dual in and dual out'87 5-speed 325is
Yeah, I know. I remember seeing digger's trials in a thread years ago.
64" is way the heck out there. You mentioned that the O2 was going to be after the merge. Is there any concern with having it be that far downstream.'87 5-speed 325is
I am doing 32” to simplify things a bit while keeping the 02 closer to the engine, although I am unsure if it makes a difference or not regarding a reading that far down the line.
Every time I have had a car tuned in the past, they pull 02 out of the tailpipe in addition to whatever 02 I have wired in, and 99% of the time the tailpipe 02 was what was used for tuning. That may also be due to inconsistency/quality between/of customer equipment, though.Comment
