10k RPM – 1991 Diamantschwarz 318is Slicktop – 231hp NA M42
  • digger
    • Nov 2005
    • 5977
    #166
    Originally posted by chriso
    Not sure, as tuner said what I was seeing on the dyno screen wasn't accurate. But, it was posting 173 on the dyno end. When I asked, saying that was low, he said its 260 crank currently, with some room left. This isnt my specialty, though.
    not sure where you are located but when tuning is 100% done be sure to find a dynojet to see what it makes as that is the gold standard reference
    • chriso
      • May 2015
      • 192
      #167
      It's being tuned on a Mainline ProHub right now.
      1986 325e Maaco Black M62 Project [SOLD]
      2008 135i Alpinweiss III Cabriolet 6MT [SOLD]
      2013 Subaru WRX [SOLD]
      2011 BMW X5M [Daily]
      1991 318is Slicktop Diamantschwarz Metallic [Thread]
      1973 BMW R75/5 Toaster Tank [Summer Daily]
      • chriso
        • May 2015
        • 192
        #168
        Upon further inspection, we believe we blew the throw out bearing. Ordered a new one just in case, and pulling the transmission likely this weekend. Tune should be good to go, but once we solve the transmission issue we’ll do an official dyno sheet with the machine calibrated.
        Currently, the car is unable to shift while it’s running, and starting it while in gear will make the car move even if the clutch is fully pressed, so the clutch is not fully disengaging.
        Hoping we’re just looking at a throw out bearing issue, but replacing master and slave cylinders, and removing the chase bays line that I used for some reason.
        • chriso
          • May 2015
          • 192
          #169
          Jogged my memory on parts installed when I put the engine in.
          I had replaced both master and slave cylinders, but I failed to replace the clutch release arm, pivot, spring, and throw out bearing.
          Transmission is out this week, parts will be here Monday, so hoping this is the issue. Also doing input and output shaft bearing where were out.
          With any luck, this will be all good to go in time for spring.
          • chriso
            • May 2015
            • 192
            #170
            Update:
            Transmission was good. No damage. The issue ended up being that hardware was too long and was making contact with the very center of the pressure plate and crankshaft. There’s very light scratches on both, but it was enough to prevent the clutch from fully engaging. We also discovered that the rear main seal had began leaking, so new hardware properly sized for the flywheel, and RMS are en route. Car is back on the dyno on Friday for the final run, and should be ready to go for when the salt is off the road in April.
            This time around, we’re red loctiting, and metal marking bolt positions to ensure nothing is backing out.
            We’re finally there.
            • chriso
              • May 2015
              • 192
              #171
              Final issue: it appears that all of the transmission issues are leading back to the Bosch iBooster swap, and it boiling the brake fluid. I took the car out for a drive last Friday, and noticed the longer we ran, the worse the shifting got until it no longer would disengage the clutch.
              This was happening at idle, and during driving whether the brakes were being used or not. Rather than troubleshooting, I am reverting it back to an e90 brake booster and putting the iBooster in the Vixen 21TD which needs a replacement for its ancient electric booster anyway, and will give me a bit of time to troubleshoot it and/or get the proper wiring harness which is now available from a few vendors for direct plug and play.
              • eternal24k
                • Jul 2017
                • 507
                #172
                interesting, any idea how or why it could be boiling fluid? I was going to swap my X3 booster for an iBooster, this is the first i have heard of issues
                • chriso
                  • May 2015
                  • 192
                  #173
                  I’m honestly not knowledgeable enough here to be able to actually diagnose.
                  I originally swapped the iBooster into the car in 2019, I believe I was one of the first, after reading a basic write up on the EV DeLoreon forums. And even then, it was for an iBooster 1, and we wired it up with that information after finding a German wiring chart for the iBooster 2.
                  The E90 booster that was available locally fell through, so I instead ordered a pre-made iBooster 2 wiring harness with labeled pigtails, as originally we wired it directly the the iBooster pins, as the connector wasn’t available in 2019.
                  In addition, I don’t believe we’ve done a full brake fluid flush on the car, so that will be done at the same time. The car did sit undriven for 6 years, so who knows. Hoping this fixes the issue.
                  The other thought, is that it is related to a failing ABS module. I’d like to keep ABS, so I hope this isn’t the issue, and I really don’t want to pay to have it refurbished.
                  • chriso
                    • May 2015
                    • 192
                    #174
                    In news that will shock everyone, it looks like the only issue we could find would be that the Chase Bays clutch line is leaking and Introducing air. Ordered a new OEM line.
                    Did have air stuck in the brake system as well, but no issue there. Did a full flush and bled it properly, and the iBooster feels great.
                    • 2mAn
                      Señior Mod
                      • 20249
                      #175
                      Keep at it! Excited to see the results
                      Simon
                      Current Cars:
                      -1966 Lotus Elan
                      -1986 German Car
                      -2006 Volkswagen Jetta TDI
                      Make R3V Great Again -2020
                      • AWDBOB
                        • Aug 2013
                        • 4396
                        #176
                        the crowd remains unshocked
                        • Northern
                          • 5116
                          #177
                          hahah I was going to say. Who would've thought there would be a quality issue with something from Chase Bays
                          Originally posted by priapism
                          Originally posted by shameson
                          • chriso
                            • May 2015
                            • 192
                            #178
                            Not looking like it's the cable, but I ordered a new OEM line from BMW, and new FTE Master and Slave Cylinders from FCP Euro. This is my third time purchasing Slave and Master cylinders from FTE, according to FCP's purchase history. I never ran the current Master / Slave, but apparently the first set I purchased leaked, which I dont remember, because 3 days after the first time I ordered them (2019) I did a warranty exchange for a new set. So, now assuming it's the Master / Slave, but no fluid is leaking from either, despite not being able to bleed them.
                            • Northern
                              • 5116
                              #179
                              Bench bleed the slave before installing?
                              • AWDBOB
                                • Aug 2013
                                • 4396
                                #180
                                Are you bleeding the slave with it mounted to the trans?
                                I always bolt the lines up, let it hang, open the bleeder until a solid stream of fluid comes out, what’s that John Mayer song?
                                Then bleed the system via plunging the slave against the body to get any last air out, rather than with slave bolted up using the clutch pedal.
                                I have never had luck bleeding the slave via the clutch pedal with the slave bolted up.
                                Also doubt it’s the case since all 318iS cars were manual, but most auto pedal boxes don’t have the captive nuts pressed in for the clutch master, if you only swap pedals and use an M6 nut and bolt to hold the clutch master instead of the correct pedal box there is enough room for the clutch master to move and blow the seal
