10k RPM – 1991 Diamantschwarz 318is Slicktop – 231hp NA M42
  • 82eye
    • Jan 2009
    • 1925
    #181
    Originally posted by AWDBOB
    Are you bleeding the slave with it mounted to the trans?
    I always bolt the lines up, let it hang, open the bleeder until a solid stream of fluid comes out, what’s that John Mayer song?
    Then bleed the system via plunging the slave against the body to get any last air out, rather than with slave bolted up using the clutch pedal.
    I have never had luck bleeding the slave via the clutch pedal with the slave bolted up.
    well respected older mechanic told me to do the exact same with mine.
    • DesertBMW
      • Aug 2011
      • 1023
      #182
      the most under appreciated and underrated E30 in the USA is 1991 318is in stock form.
      • chriso
        • May 2015
        • 192
        #183
        Alright guys.
        I’ve contacted ClutchMasters, and have had the transmission out multiple times.
        I’ve replaced the entire hydraulic loop 3 times.
        It’s fully bled.
        It’s running a ClutchMasters 15lb Flywheel and FX350 disc.
        The clutch doesn’t fully disengage, despite feeling great. The bolts provided by ClutchMasters were about 2mm too long, and we shaved them down.
        There are slight hot spots on the clutch surface.
        It’s not synchros, as it’s an issue in every gear.
        Shifts fine when off. When running and in neutral, sometimes it will go into gear. The longer the car is running, the harder it becomes to shift.
        Everything looks correct in the transmission. I’ve completely resealed the transmission and replaced all clutch components (pivot, fork, spring, etc).
        I’m kind of at a loss, here.​
        1986 325e Maaco Black M62 Project [SOLD]
        2008 135i Alpinweiss III Cabriolet 6MT [SOLD]
        2013 Subaru WRX [SOLD]
        2011 BMW X5M [Daily]
        1991 318is Slicktop Diamantschwarz Metallic [Thread]
        1973 BMW R75/5 Toaster Tank [Summer Daily]
        • AWDBOB
          • Aug 2013
          • 4397
          #184
          Warped clutch disc from letting trans hang on friction disc before getting it on the dowels, damaged pressure plate straps, incorrect TOB stack height.
          You running an M20 flywheel? If so, I’d just throw a stock M20 clutch in it
          • econti
            • May 2014
            • 1102
            #185
            Can you fit a slightly longer pushrod on the slave?
            • Dj Buttchug
              • Jun 2010
              • 7638
              #186
              OP has the exact same clutch I am running on my turbo M42 engine. Apparently he made a post on fb saying he believes now it is clutch pedal adjustment height causing the issue.
              Turbo M42 Build Thread :Here
              Ig:ryno_pzk
              I like the tuna here.
              Originally posted by lambo
              • chriso
                • May 2015
                • 192
                #187
                This is correct.
                I spoke with ClutchMasters again, and after walking through the entire process I did with the clutch install, and subsequent times I removed the trans to try to fix it, they believe that the clutch pedal itself has been adjusted, as there's not enough free play at the top of the pedal.
                I haven't had a chance to get back to the car to check, but I will this week.
                Hoping this is the issue. I also ordered the 30mm TOB just in case, but ClutchMasters advised me against using the taller TOB, saying it will make the issue worse.
                • 2mAn
                  Señior Mod
                  • 20250
                  #188
                  Wishing you the best of luck, you have had enough headaches already.
                  Simon
                  Current Cars:
                  -1966 Lotus Elan
                  -1986 German Car
                  -2006 Volkswagen Jetta TDI
                  Make R3V Great Again -2020
                  • chriso
                    • May 2015
                    • 192
                    #189
                    Solved. Pedal position was the issue. It also needed a clutch stop, as pressing it too far would make the clutch re-engage.
                    Just needs an alignment and the final dyno run, now!
                    • Dj Buttchug
                      • Jun 2010
                      • 7638
                      #190
                      Nice. Glad you got is sorted.
                      Ig:ryno_pzk
                      • chriso
                        • May 2015
                        • 192
                        #191
                        It’s complete! However, the downside is that I’m moving to LA on Wednesday, and the car is in no way able to registered in California, as it will never pass smog with this build.
                        Very likely for sale. Still deciding. Going into storage tomorrow while I decide what to do.
                        The Vixen IS for sale.
                        • 2mAn
                          Señior Mod
                          • 20250
                          #192
                          Is it still plated/ registered in California? You know how I feel about this car. PM me
                          Simon
                          Current Cars:
                          -1966 Lotus Elan
                          -1986 German Car
                          • moatilliatta
                            • 6121
                            #193
                            Dyno numbers?
                            @Zakspeed_US
                            • chriso
                              • May 2015
                              • 192
                              #194
                              Originally posted by moatilliatta
                              Dyno numbers?
                              Didn't have time for the final run. Preliminary run during the final tuning session was 265-275hp on E85.
                              Won't have the final dyno run now until I have the car in LA.
                              I drove it to the storage unit in Vermont last week after buttoning the car back up. I fell in love with it again, so it's definitely. coming out to LA around October as a birthday present to myself. I have to figure out how to quiet it down, as it will draw too much attention, even if I get it smogged.
                              • 2mAn
                                Señior Mod
                                • 20250
                                #195
                                Hey Chris, so glad this is coming to SoCal. I cant wait to see it.
                                Simon
                                Current Cars:
                                -1966 Lotus Elan
                                -1986 German Car
