My Hoopte30 Project Attempt #6 - the painless way to earn cash back every day
  • AWDBOB
    • Aug 2013
    • 4393
    #301
    Originally posted by moatilliatta
    Painless.
    painless time removal, cheap rates
    I replaced the sun visor panel with a nicer one, and got the sunroof motor working smoothly.
    Untitled by Bobbie Morrone, on Flickr
    PS lines no more leaky
    • AWDBOB
      • Aug 2013
      • 4393
      #302
      Operation turn my entire backyard into a pole barn is underway
      I also made some more progress on the TXholdem
      I used the AFM that came with the car, and had a miss under load. Surprise, that AFM was bad.
      I used the radiator that I got with the car, went to bleed the coolant and it leaked through the end tanks. Replaced with a nissens.
      New PS lines STILL LEAKED so I ordered alloy crush washers instead of copper. NO MORE PS LEAKS
      Got the Ansa Sport aligned a little better.
      Tail lights that came with the car looked fine in photos but were all sorts of cracked. Replaced with a good set.
      The front valence and trunk lid that came with the car were in awful shape, so I had a straight valence, air ducts, trunk lid, and iS spoiler painted. I did another buyout last weekend, and it came with a genuine alpine II iS lip, so I threw that on the car. Shoutout to E30Bastard for the smoked fogs!!!! What a legend
      Installed good fender liners, splash shields, under tray, and air ducts to finish it off.
      Blower motor works well, needs resistor which I'll install soon. Wipers work as intended, shockingly. This thing is almost over the finish line!
      I'm going to plate it and give it a good shake down once the weather breaks.
      • AWDBOB
        • Aug 2013
        • 4393
        #303
        barn have roof
        • AWDBOB
          • Aug 2013
          • 4393
          #304
          Hoopty is done! Header V2 is finished up. Once I'm done spending every waking moment moving shops for the next 3mo, I'm going to do a stock exhaust/header dyno comparison to get some data. The primaries are HUGE. They step to 2" before hitting the collector. This is what the data said it wanted, but real life I'm sure will tell a different tale. It's straight piped with a Magnaflow 14815 muffler. Not too loud, sounds glorious.
          The crew has been killing it! The color matches nicely with the house. It's intimidating making such a big decision based on a 1"x1" swatch, but really worked out. Went with a burgundy and a charcoal. Or as we all know it, Malaga.
          Untitled by Bobbie Morrone, on Flickr​
          • 2mAn
            SeƱior Mod
            • 20215
            #305
            That space looks wonderful. Going full concrete inside and 1 lift? Im guessing you want insulation so you can play in the barn year round?
            Simon
            Current Cars:
            -1966 Lotus Elan
            -1986 German Car
            -2006 Volkswagen Jetta TDI
            Make R3V Great Again -2020
            • AWDBOB
              • Aug 2013
              • 4393
              #306
              Thank you!! I am very happy with how it sits on the property and how the color matches the house/garage.
              Yep, doing concrete hopefully next week- trying to land a nice day so it sets up nice.
              I am going to run wiring for my lift, but idk if I'm going to have the space or not since I am condensing from a large space to a way less large but still substantial space. My normal garage is insulated and has heat/AC so my thought was that I will use that as my workshop, and then use the barn for storage. But if I can squeeze the lift in there, it's going in, especially considering I only bought it a few years ago.
              I'm hopefully going to spray foam the walls, but I'm not closing in the ceiling and really don't want to spray foam the under side of the roof, so still trying to figure out what to do there since I can't blow in insulation.
              Likely going to build a 7' mezzanine as well to take advantage of the 14' walls​
              • AWDBOB
                • Aug 2013
                • 4393
                #307
                maaaaan the stoke is high today. I drove the white car for the first time a few hours ago and it feels fantastic. Apparently replacing everything mechanical on a car will cause it to drive quite well.
                I have to get it aligned and then have the paint guy finish going over a few things and I'll start driving the car!
                It's also disgustingly dirty, but can't really fix that with all the construction at my house so it'll have to wait.
                • 2mAn
                  SeƱior Mod
                  • 20215
                  #308
                  Thats too nice, must sell to retain hooptie title
                  Simon
                  Current Cars:
                  -1966 Lotus Elan
                  -1986 German Car
                  • AWDBOB
                    • Aug 2013
                    • 4393
                    #309
                    I’ll sell it, but only if you change the title under my username to something hooptie related
                    • moatilliatta
                      • 6121
                      #310
                      Royal Flush.
                      Building is exciting.
                      @Zakspeed_US
                      • AWDBOB
                        • Aug 2013
                        • 4393
                        #311
                        Royal Flush.
                        Concrete this week!
                        Cluster time..... I polished a lens, installed a set of my bro's trim rings, replaced a main board due to a cold solder joint making the gas gauge go wild, and replaced the odometer gears preventatively (somehow they hadn't failed yet).
                        • e30m3s54turbo
                          • Jun 2010
                          • 3212
                          #312
                          I love the white e30!!
                          • AWDBOB
                            • Aug 2013
                            • 4393
                            #313
                            Thank you- it turned out better than it should have!
                            Barn is coming right along. They hung the garage door today and finished up the concrete. Waiting on the miserably slow city engineer for electric. Once the concrete cures a bit, the mezzanine build will begin. I am feeling quite blessed I was able to build this at my house.
                            • twright
                              • 707
                              #314
                              You've created space for me!
                              I'll start filling it up. Be there soon.
                              • 2mAn
                                SeƱior Mod
                                • 20215
                                #315
                                Dang, that looks great!
                                Simon
                                Current Cars:
                                -1966 Lotus Elan
                                -1986 German Car
