Nonsense Thread
  • MrBurgundy
    R3V Degenerate
    • Mar 2012
    • 5616
    #13906
    Originally posted by 2mAn
    Its quite surprising how much of a difference the tires can make
    I am crazy tho
    • Northern
      I like cupcakes & sh!tboxes
      • 5284
      #13907
      Originally posted by varg
      Vibration analysis requires some fairly cheap equipment and some basic knowledge, and it won't tell you much more than amplitude of the peaks and where they are. Torsional deflection analysis (which is relevant here) requires expensive equipment and more knowledge. It's not likely anyone who builds engines as a hobby is going to do that. FEM of the crank itself is also not easy and would be quite expensive because of the software requirements unless we find an engineering student or an engineer who can load the models up at work (I can't).
      By no means is it the complete story, but I think gathering the natural frequencies between the different crankshafts would be a reasonable starting point (and pretty low effort)
      If nothing came of it, it wouldn't be too big of a waste.
      Either way, it does seem to be the only one with an issue.
      Originally posted by priapism
      Originally posted by shameson
      • Chilezen
        I weld cats
        • Dec 2013
        • 1944
        #13908
        Originally posted by Northern
        I think the popular theory is that the 3.2's second harmonic is just low enough that it becomes a problem.
        Easy enough to prove but I don't think anyone has done it.
        Metric Mechanic seems to build happy revving engines without a fuss. He is super detailed and thorough, so that helps. He will make a reliable beast out of an aluminum M52, he tells me. Built one for a competitive autocrosser, who won several things without issue. I don't remember much else (conversations were a few years ago), but I know he casts his own pistons with really short decks or whatever, to achieve the longest rod ratio he can. The crank is untouched and I think he uses the stock dampener.
        Currently building a badass coffee table
        Random stuff on insta @kevanromero
        • moatilliatta
          • 6158
          #13909
          D day is May 3rd.
          I went with the ATi damper, well see how it goes.
          I did forget to balance the clutch, but will take it apart after first dyno day to get it balanced. Ill be back the 11th with the ITB's and see what the gains are.
          @Zakspeed_US
          • ForcedFirebird
            • Feb 2007
            • 8300
            #13910
            sup
            john@m20guru.com
            Links:
            • Chilezen
              I weld cats
              • Dec 2013
              • 1944
              #13911
              Random, but I was searching for any build threads of race cars with roll cages. I'm about to build one, and there's sparse info/photos here for such a thing. The SpecE30 forum probably has a lot but I didn't feel like making an account just for that (because I kept finding "private" pages for members only). Is there a collection on here?
              • ForcedFirebird
                • Feb 2007
                • 8300
                #13912
                I've probably built ~20-30 e30 cages? Whatcha need?
                john@m20guru.com
                Links:
                • Chilezen
                  I weld cats
                  • Dec 2013
                  • 1944
                  #13913
                  Lol I knew it'd be a good time to ask when I saw you. I'm building the kickers off boxes that encapsulate the shock towers, but I saw some people go to the trunk floor. One guy suggested going to the spring perch, but I'm like, you can't, and that would be way too severe of an angle to the main hoop. Where do you go?
                  • ForcedFirebird
                    • Feb 2007
                    • 8300
                    #13914
                    Originally posted by moatilliatta
                    I got 260 on the S50 with terrible cam timing.
                    It’s still S50 just now with 11.5 cp pistons and 140mm rods and room to set cams up to the cam card.
                    the sunbelt kits on stock s52 bottom ends I’ve herd will do 275. That’s what’s most the hot BMW CCA IP cars were running.
                    I think the ITB kit on a stock motor is worth close to 15-20 HP.
                    I installed a set on SB cams a couple moths ago in an e36 ST car. Power increased a max of 8whp, no matter where we moved them. Granted, its was a semi-tired s50b30 making 234 on a Mustang. Owner bought another "de-tuned" 380whp s54. It's getting out of hand in the racing circuit. Ever since Randy at EPIC did the v8 swap in the e46, racing rules are all over the place.
                    john@m20guru.com
                    Links:
                    • MrBurgundy
                      R3V Degenerate
                      • Mar 2012
                      • 5616
                      #13915
                      ITBs on the S52 will have some nice gains
                      A stock long block with S54 headers and a tune will put you around 280whp
                      • 2mAn
                        Señior Mod
                        • 21085
                        #13916
                        sup
                        Sup. Glad to see you here!
                        Simon
                        Current Cars:
                        -1966 Blue Boat
                        -1969 Red VW
                        -1986 White BMW
                        -2006 Green Thing
                        Make R3V Great Again -2020
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          #13917
                          I haven't seen anything that high on my local dyno. I built an "s52" (3.2l) with +.5mm 11:1 pistons, stock s50 cams, +1mm intake valves, s50 manifold, eBay SS clones, , a 3.2 put down 274whp for me. Client ended up blowing that one and we put a stock JY 3.2 in it's place and it dropped to 248whp. Most ST and ITS classed cars with stock s52's are putting down low/mid 250's (we are required to use Dynojet , STD correction, smoothing 5, 3 consecutive runs set to RPM mode).
                          EDIT: DERP, missed the ITB's. I saw a ~18whp increase with ITB's on a bone stock 200k mile m50. Haven't dyno'd ITB's on an s50/52.
                          john@m20guru.com
                          Links:
                          • ForcedFirebird
                            • Feb 2007
                            • 8300
                            #13918
                            Thx. Had to regroup, and forums/social media didn't fit in the agenda/schedule. Still have no desire to go back on social. Just a few forums.
                            john@m20guru.com
                            Links:
                            • Northern
                              • 5284
                              #13919
                              On the other hand, Terry Fair/Vorshlag's DSP E46 330i was a nightmare. They went through what, 3 engines before they called the abort?
                              Went for an extra 500 RPM and had oil pumps shearing off and other things, with an ATI damper and all.
                              I think the oil pump chain tensioner, new chain, and a tacked nut would do more for these engines than the ATI damper, and the cost of all of that is maybe $40.
                              • MrBurgundy
                                R3V Degenerate
                                • Mar 2012
                                • 5616
                                #13920
                                This guy was hitting 280 consistently! Honestly, that's a rad setup for the money
