PNW Chit Chat thread
  • Anjreu
    • Oct 2013
    • 51
    #26266
    dirty......what are you doin this afternoon? might wanna pick the lights off the white car and give you moneys for the bumper and valence
    1985 318i Sedan POS. Cosmo Bleu {R.I.P}
    • EN318isPDX
      • Oct 2007
      • 4373
      #26267
      Originally posted by Anjreu
      Find me a driveshaft
      Portland Driveline
      • 2mAn
        SeƱior Mod
        • 20859
        #26268
        Im seriously losing my mind with this 24v build.... really starting to regret not just forking over the money on a good 885 head and just being done with it. Ive got way too much money tied into it now and its back to square one...
        Simon
        Current Cars:
        -1966 Lotus Elan
        -1986 German Car
        -2006 Volkswagen Jetta TDI
        Make R3V Great Again -2020
        • e30austin
          • 15382
          #26269
          What the hell happened?
          • 2mAn
            SeƱior Mod
            • 20859
            #26270
            not exactly sure yet. only thing Im sure of is that the engine is coming back out AGAIN and going BACK to the machine shop. could have bent valves in the head. they are suspecting that the piston/ valve clearance was too small with the new pistons. fucked up thing is I didnt ask for any fancy piston, just the next overbore size. the worst part is that theres a good chance that this will all be my own fault even though I have done the least amount of work on the engine
            Simon
            Current Cars:
            -1966 Lotus Elan
            -1986 German Car
            • Mlarsen
              • 4082
              #26271
              From what I understand from my machinist the valve design on 24v's they're common to bend slightly.
              • e30austin
                • 15382
                #26272
                Eek. This makes me rethink stroking my S50 this winter. Planned on using the stock bore 11.5:1 JE pistons and S52 crank. Maybe not now...
                • 2mAn
                  SeƱior Mod
                  • 20859
                  #26273
                  Not sure, but when he had it idling and did a compression test they were all over 200psi. Friday when he noticed an oil leak and they did another test the highest one was 150psi and many were under 100psi
                  Simon
                  Current Cars:
                  -1966 Lotus Elan
                  -1986 German Car
                  • e30austin
                    • 15382
                    #26274
                    What pistons did you use? Sounds like a deck clearance issue.
                    • 2mAn
                      SeƱior Mod
                      • 20859
                      #26275
                      TMS supplied Wiseco Pistons. They initially sent me S52 pistons, sent them back and told them I needed M52 pistons and first I was told 6 weeks, but then they showed up to the machine shop 2 weeks later. The Machine Shop was skeptical that they were the right ones, but I called TMS and they told me they were the right ones. Im just pissed because Ive spent a good amount of money to make sure this motor is built right and after thousands of dollars, its basically back to square one. Im heading into month 7 of this engine build
                      Simon
                      Current Cars:
                      -1966 Lotus Elan
                      -1986 German Car
                      • iroll253
                        • 96
                        #26276
                        Originally posted by IronJoe
                        Glad you found us and this thread! Greg's car is legendary, I'm for sure going to miss it!
                        FYI We rolled the fenders on that car.
                        I know but they weren't rolled flat. So it definitely needs more. The car is solid besides the driver fender. It looks like it had been cut short and resprayed. Took me a couple days of owning it to even notice. Ill be replacing it with an oem fender and having the whole car sprayed eventually. Let me know if anyone in the pnw is really good at a roll and pull. They are 17x10 in the rear et20
                        • 5Toes
                          • 9836
                          #26277
                          Are you sure the machien shop aint dumb and didnt deck your head too much...?
                          Pistons arent designed to ruin motors, they are designed for engines in spec
                          • the imitator
                            • May 2013
                            • 1006
                            #26278
                            m30 ftw
                            • Ryann
                              • 3350
                              #26279
                              I smell a machine shop fuck up.
                              • 10Toes
                                Me Father Was A Tree
                                • Jan 2008
                                • 61222
                                #26280
                                Any good machine shop should of clayed the head if they are using anything but stock pistons. Could of just got a good low mileage iron block m52 for $300 and been done.
