PNW Chit Chat thread
  • spiDmang
    • 3941
    #30541
    Originally posted by Wschnitz
    Lol so many r3v FB fgts fapping hard to catuneds sema car.
    Brb putting bolt ons on my car and bringing it to sema for mad scene points.
    You do understand that CAtuned has TWO cars that act as their "poster boy"/showroom cars right??
    They have their Henna s50/supercharged coupe that was literally FULLY rebuilt with static suspension that CAN be tracked, as well as their estoril blue early model that has air suspension and crazy wheels to accommodate them. 2 totally different builds for two different purposes.
    91' 318iS - S54/6MT Swapped
    08' E90 M3 6MT - Daily
    Originally posted by IronJoe
    Originally posted by 2mAn
    • Wschnitz
      • 8089
      #30542
      Originally posted by Wardie
      "Bro bro choo choo bro" - will
      choo choo
      willschnitz
      • delamaize
        • Nov 2013
        • 1463
        #30543
        ok guys, thanks to 318isbmw for hooking me up with a 2nd rear subframe, and a mess of other rear suspension parts. I'm going to be able to finish my suspension. From research, based on what I'm planning on doing with the car, and research on here, I've made a plan, and I want r3v's opinion.
        Front: I'm running H&R E36 M3 Race springs, E90 drop hats, stock housings, stock Control Arm Bushings (New ones), stock sway bars and bushings. Planning on going to stiffer sways and new, better bushing throughout. I'm torn on Offset Control Arm Bushings, Not 100% if it's something I want to do or not. I'm happy with the ride height, but I've got about some camber I have no choice but to address. I'm looking into plates to fix the camber, not sure if I wan adjustable or fixed plates though.
        Rear: right now I'm running H&R E36 M3 race springs, with no spring pads. everything else is stock. Planning on building on an entire new subframe that I can get all set up and just drop it in. I'm not happy with the ride height on the back, I'd like to get down another 1/2 inch, if I can't I can live with it the way it is. Everything is getting replaced and reinforced in the rear. New Bushings, I'm looking at Revshift's blue (street) bushings for everything, but I am torn on if I want to raise the rear sub or not. I'm planing on using Garagistic's camber/toe adjusters. and of course eventually a stiffer sway bar and new bushings for it also. Going to try to source a new diff also, and get rid of this crappy 2.93 open I have. Eventually I'm planning on a swap, so I want to find between a 3.25 and 3.75 LDS.
        So, suggestions, opinions, etc? also someone sell me on using the Offset Control Arm Bushings and raising the rear sub or sell me on staying away from them, because I am on the fence about both.
        Dumpster Fire Pilot
        • ck_taft325is
          • Sep 2007
          • 6880
          #30544
          Honestly? Go coilovers and don't look back. It'll always, always do better than just springs when it comes to dialing in exactly how low you want to be. I'm not talking hard park ride height adjustment but, your an early model thus, you'll need something lower in the rear just to begin to even it out. You can get 2.5" ID GC springs in the rear and try to snag some adjusters on the FS board however, those adjusters are going to become necessary if you're not going sleeves/adjusters up front. At that rate tho, just save some money and pick a full GC setup.
          What's your motor? If you're an E, I'd stick with the 2.93. Just upgrade to a LSD. I loved my little 2.7e. Determined to swap? I'd stay in the range of 3.25. Anything higher is rape on your wallet at freeway speeds.
          Need a part? PM me.
          • the imitator
            • May 2013
            • 1006
            #30545
            Everytime I hear a GC user says "just cut the bs and go with gc coils." it makes me that much more excited to drive me e30.
            • delamaize
              • Nov 2013
              • 1463
              #30546
              My motor right now is a SETA. As for the swap, I'm on the fence, it'll either be a M50/52, or a M30B35. Lately I'm leaning towards a M52B30 if I can find a decent one with tranny and everything, that will be a year or more down the line though.
              In the past, I have shy'd away from coil overs because of the cost Vs benefit for my plan, I'm not trying to get super low, right now, I dropped about 1.25" in the front with just those springs and drop hats, and I'm happy with the front. The back isn't that bad, I lost about 1" with the springs and pad delete in the back. it's not so much the low in the back thats the problem, it's the rake, but like i said I can live with it. I like the way these springs ride, and thus far, the way they handle also. The other thing I had thought about doing was notching about 1/2" out of the swing arms, below thee spring perches, reinforcing, and rewelding the perches back in. But I'm not sure an extra 1/2" is with the effort.
              Dumpster Fire Pilot
              • the imitator
                • May 2013
                • 1006
                #30547
                here's my hoopty on gc coils high as I can get them on cut strut housings. I personally wont be dropping it on its nuts, I live by way to many good backroads. Do what suits you, it looks like you have a killer project.
                FIY I'll be selling my m30b35 swap after sometime after christmas.
                • ck_taft325is
                  • Sep 2007
                  • 6880
                  #30548
                  ^ That's why you go GC Coils. It's not the "slam it on it's nuts" part. It's more to do with being able to adjust your height AND having amazing performance. As for cost, you can get them for less than $700.00 if you shop around or buy some used in the realm of $450. And, no more rake ;)
                  Not to mention, if the rest of your suspension is up to snuff, it's literally like driving a car on rails. Absolutely amazing.
                  Need a part? PM me.
                  • the imitator
                    • May 2013
                    • 1006
                    #30549
                    im running bilsteins which GC doesnt reccomend, my buddy the PO had it lowered to the point it was on bumpstops, and no they arent cut.. lol
                    • delamaize
                      • Nov 2013
                      • 1463
                      #30550
                      [ATTACH]90993[/ATTACH]
                      I might be interested in that swap. I'm trying to buy a house right now, so I don't know what my funds will be like after that. I can't stay in the housing situation I am in right now.
                      Dumpster Fire Pilot
                      • the imitator
                        • May 2013
                        • 1006
                        #30551
                        I'll take partial trades for a known working 335i manual transmission gs6-53bz.
                        The n54 is 4 bolts from being removed fully, which is cool.
                        Looks like I'll need a walnut shell blasting though, I've seen worse, which means it's been done before, but man its caked on pretty good.
                        The car is currently up in the air with front subframe screws cracked and ready to be freed and the whole unit will be lowered to the ground upon freeing 2 more transmission brace nuts, and then the will be car pushed away.
                        You guys think I should start a thread yet? or keep it here still for a minute.. at this point I'd have a pretty good starter post, but i feel like maybe i should wait until i have the motor mocked up to an e30 shell before making the mounts, that way people can see that process too. Maybe have a jig made so we can have these mounts made in the future too.
                        • kid325e
                          • Sep 2007
                          • 6422
                          #30552
                          Guys. Let's talk commuter cars.
                          Let's get specific. Name off some choice cars you'd be caught driving on the daily CUMmute.
                          My needs:
                          Good MPGs
                          Automatic
                          Budget would be less around 2k for a budget commuter. Need ideas! Not concerned with brands really.
                          clutchCTRL!
                          Move with a purpose.
                          - 1991 325iX 4dr/5spd
                          - 2000 323i AT
                          2016 Mazda CX3 Sport AWD
                          • DER E30
                            • Sep 2013
                            • 2349
                            #30553
                            [ATTACH]91011[/ATTACH]
                            Make a thread!
                            -Christian
                            • Matt-B
                              The Waffler
                              • 3856
                              #30554
                              My needs:
                              Good MPGs
                              Automatic
                              Lol your budget. I dailyed a 240dl wagon for years, wasnt bad. Roughly 24-26mpg
                              currently daily e36 m3, 25-27mpg, the volvo never needed repairs.
                              • AbeSonic
                                Price check on Vagiclean, aisle five. I repeat: price check on Vagiclean, aisle five. That's Vagiclean. We've got a customer down here with a full-on fallopian fungus. I'm baking a loaf of bread and I think it's sourdough.
                                • 3635
                                #30555
                                My needs:
                                Good MPGs
                                Automatic
                                Infinity G20.
                                out dated sig is out dated
