PNW Chit Chat thread
  • DER E30
    • Sep 2013
    • 2347
    #34876
    #bronzitlivesmatter
    -Christian
    • EN318isPDX
      • Oct 2007
      • 4373
      #34877
      Originally posted by DER E30
      #bronzitlivesmatter
      rofl
      • vaughnbannister
        • Aug 2012
        • 206
        #34878
        Originally posted by spiDmang
        yessir. obd2 S52. the build thread is in my sig. Check it out if you have any questions or feel free to PM me
        Is this where we start the OBD1 vs OBD2 argument?
        - S50 Swapped E30 1/1 Mineral White -
        @vaughnbannister on IG
        • EN318isPDX
          • Oct 2007
          • 4373
          #34879
          There is no argument. OBD2 is better but OBD1 is easier/cheaper
          • vaughnbannister
            • Aug 2012
            • 206
            #34880
            I don't like the emission shit of obd2
            • EN318isPDX
              • Oct 2007
              • 4373
              #34881
              You only have to run that crap if you live in california
              • vaughnbannister
                • Aug 2012
                • 206
                #34882
                Yeah. But it's just more shit to delete when swapping [emoji24]
                • EN318isPDX
                  • Oct 2007
                  • 4373
                  #34883
                  Not really. Biggest difference is running OBD1 ECU out of the box vs obd2 needing to be flashed. Its worth it, if you can afford it
                  • vaughnbannister
                    • Aug 2012
                    • 206
                    #34884
                    Well I've only done s50 in an e30. But I've converted an s52 to obd1 for an e36. So I'm kinda bias [emoji39]
                    • EN318isPDX
                      • Oct 2007
                      • 4373
                      #34885
                      Being bias is basically being close minded, coolest thing about OBD2 is the ability to get real engine codes and live readouts to a smartphone via bluetooth, but here are other reasons OBD2 > OBD1
                      Originally posted by 328ijunkie
                      Common Arguments:
                      -Running your M52/S52 OBD1 does NOT make more power.
                      -Its not really easier
                      -If youre having someone like me do the wiring its no different to you
                      -You can still run a M50 manifold with OBD2
                      -You DONT have to mess with EWS at all, it is easily flashed out of an ECU
                      -Custom Tunes are just as available for OBD2 as they are for OBD1
                      -Secondary air pump and Evap stuff can also be flashed out of the ECU.
                      Gains with OBD2:
                      -Ability to reuse the sensors/harness/ecu that you most likely got with your engine
                      -Smarter/Better ECU that allows you to troubleshoot small issues alot better than an OBD1 ECU would
                      -Ability to pull live data just like you could off any other OBD2 car, data like codes, current engine temp, vehicle speed signal, short and long term O2 adaptations, etc.
                      -Generally better/cleaner running engine because of the smarter ECU=more power
                      • Matt-B
                        The Waffler
                        • 3856
                        #34886
                        People ask me why I haven't done an m50 intake on m3. Sorta the same reason. Loss of power vs torqe. And loss of abilty for codes and such. Obd2 intake looks puny but works fine
                        • DER E30
                          • Sep 2013
                          • 2347
                          #34887
                          Obd2
                          -Christian
                          • vaughnbannister
                            • Aug 2012
                            • 206
                            #34888
                            Well the big reason I went s50 was because they are much less common and you don't hear about it as much.
                            But having the readout with a scan tool would be nice lol
                            • EN318isPDX
                              • Oct 2007
                              • 4373
                              #34889
                              For the record I am OBD1
                              • kid325e
                                • Sep 2007
                                • 6421
                                #34890
                                I'm a big fan of the stomp test. Lololol
                                Sent from my iPad using Tapatalk
                                clutchCTRL!
                                Move with a purpose.
                                - 1991 325iX 4dr/5spd
                                - 2000 323i AT
                                2016 Mazda CX3 Sport AWD
