PNW Chit Chat thread
  • 5Toes
    • 9836
    #5221
    I will likely need to Ryan. GG 5 lug doesnt appeal to me... wheels aren't that important to me.
    Its funny because my car got all new struts in May 2010 but they reused all the mounts. lol
    so parts list so far is:
    New strut tube/spindle. (if you have one and are in Seattle or Tacoma please PM me)
    New control arms
    New tie rod ends
    New E30 m3 cabs
    New strut mounts
    New Sway Bar mounts
    possibly new sway bar
    Maybe some E90 drop hats?
    • LuckyHenriksen
      • Jun 2010
      • 4244
      #5222
      Originally posted by Eta power
      Damn E30 drivers.
      Austin in his new car??
      5Toes, if you need used parts LMK although it sounds like you don't have much budget to work with right now. I have a set of strut housings with low milage if you need some
      Bahama Beige E23 Project
      Bluebird Bus Conversion
      New Oregon Trail
      • HarukoE30
        • Nov 2011
        • 1057
        #5223
        Lucky, is there any other hoses that run down by the transmission/engine besides the one tube to the slave cylinder? In the Bentley book, I'm only seeing that one hose to the master cylinder.
        Originally posted by James Crivellone
        1) The internet is NOT serious business.
        • e30austin
          • 15382
          #5224
          There is one line to clutch master cylinder and one line to clutch slave cylinder.
          • HarukoE30
            • Nov 2011
            • 1057
            #5225
            So the line from the Master, goes to the slave and that's it?
            • e30austin
              • 15382
              #5226
              The line from the master cylinder feeds off the brake fluid reservoir. Not too sure where the one from the slave cylinder runs.
              • 5Toes
                • 9836
                #5227
                Lucky I only need one strut housing. But Id prefer local because we all know shipping it would be a bitch.
                This is the correct "drophats" yes? Looks like it would be $20 ish for 2 from Blunt- http://parts.bmwofsouthatlanta.com/p...336764093.html
                • HarukoE30
                  • Nov 2011
                  • 1057
                  #5228
                  Well I know the Master has to holes, top one to the brake fluid reservoir, but the longer end that shoots through the lower firewall is to the Slave Cylinder. If that's the case, I'm putting on my flywheel & clutch tomorrow.
                  I'm struggling to find where to install the Pilot Bearing because Bentley doesn't have it anywhere under the names I've looked and realoem just shows that I stick it in the hole where my flywheel is.
                  • e30austin
                    • 15382
                    #5229
                    That makes sense. Good luck! I wanna see this fucker on the road and at the Jan 14th meet!
                    • djjerme
                      • 5082
                      #5230
                      Damn E30 drivers.
                      Nice, yours? Brass or reworked plastic.
                      Sent from my NookColor using Tapatalk
                      2016 Ford Flex
                      • DrJosh
                        • 2011
                        #5231
                        Haruko:
                        Yes the master goes trough the firewall and at that end that is where the hard clutch line attaches. That hard line goes down past the steering Guibo to a tab welded to the body. That is where the soft clutch slave line attachs and then goes I the slave. There is a hole in the crank where the pilot bearing is pressed in. It is located where the center of the flywheel is. If you google pilot bearing instal it will give you an idea. It is pretty much the same.
                        What it does is stabilize the transmission input shaft so it doesn't wobble around when the clutch is not engaged. It does this by cupping the tip of the shaft (haha) at the flywheel.
                        If there is already a pilot bearing (if engine was attached to manual trans) you will need a pilot bearing remover tool. OR you can take a stick like a monkey and push balls of wet paper into the hole until you get enough pressure behind it to pop it out. If the engine was attached to a automatic trans there will be no previous pilot bearing installed so just press your new one in and be done.
                        Originally posted by Sonny
                        I am a meme for our community.
                        • Ryann
                          • 3350
                          #5232
                          Just noticed Eric D 'unfriended' me. Wtf Eric!
                          *sniff*
                          • Eta power
                            • 342
                            #5233
                            The E30 is a plastic kit. The SD45T-2 is a stock Athearn Ready to Roll (plastic), but it is going to get some more detail this coming year.
                            Originally posted by 5Toes
                            bux bux bux. Im all about the bux Mr. Autism
                            • 2mAn
                              SeƱior Mod
                              • 20988
                              #5234
                              im thinking about selling the long tube headers i have....
                              Simon
                              Current Cars:
                              -1966 Blue Boat
                              -1969 Red VW
                              -1986 White BMW
                              -2006 Green Thing
                              Make R3V Great Again -2020
                              • IronJoe
                                • 2275
                                #5235
                                I am fucking done with Apple's shit. I was going to buy an iPad 2 but after the issues I've had with iTunes/iPhone backups/iOS5 installation/their fucking ridiculous "library" locks, I am getting an Android tablet.
                                Trying to find the Asus Transformer Prime somewhere in stock!
                                Originally posted by kid325e
                                So... what's everyone doing for NYE?!
                                Sent from my LG-P999 using Tapatalk
                                You tryna put something together?
                                '89 Schwarz E30 M3 Cabriolet Build
