N52 intake shootout
  • hoveringuy
    • Dec 2005
    • 2750
    N52 intake shootout
    I have, at this point, gotten my N52 swap pretty well sorted, run plenty of track days and put enough miles on it. This has been on the N54 intake, which isn't necessarily the "best" intake for the motor, it just happens to fit, clears everything and makes good power.
    My mission for this year is to run 100% on the dual-DISA intake and do a comprehensive compare-and-contrast. Dynos. Lap times. (top speed on the straight, too!) Driving impressions, etc.
    I have the new intake completely mounted and have already driven it a bit. It still has the tune from the N54 intake, my plan is to have a duplicate ECU just for this intake. It definitely has more torque down low but can't say too much more because the DISA isn't active yet. The sharp-eyed will notice that I have a dual-MC booster delete to clear the intake,
    (this space reserved for future updates, like who would take it?)
ID:	10078720 Click image for larger version
  • moatilliatta
    • 6157
    Looking forward to updates!
    @Zakspeed_US
    • LukeJ
      • Jul 2019
      • 139
      Excited to find out the pros and cons of each manifold.
      • 2mAn
        Señior Mod
        • 21024
        Yay! I love hoveringuy experiments
        Simon
        Current Cars:
        -1966 Blue Boat
        -1969 Red VW
        -1986 White BMW
        -2006 Green Thing
        Make R3V Great Again -2020
        • Panici
          • Dec 2009
          • 2570
          Following this thread for science!
          • DEV0 E30
            • Oct 2004
            • 8904
            This aligns with my interests, looking forward to all your findings.
            • hoveringuy
              • Dec 2005
              • 2750
              There is some data on this already, N54 intake mod was widely discussed starting around 2016 and there are some before/after dyno plots that show an increase in top-end power, but most of the threads devolve into name-calling and nothing really shows real-world performance. My theory is that I spend more time accelerating between corners in the the 4k rpm range than drag-racing down the straight at 7500, so lap times would really be the ultimate barometer, plus not everyone cares about power at 7000 but just wants useable power for commuting.
              • DEV0 E30
                • Oct 2004
                • 8904
                I think that's a valid theory and thought process.
                More power down low to keep up with a Chrysler Pacifica and overtake a Toyota Sienna with more ease would be nice. I know you went booster delete, so for those with booster'd setups, time will tell what sort of combo will work with that.
                EDIT: OH MY LAWD WE HAVE A SECTION BOYS, ITS A CHRISTMAS MIRACLE.
                • hoveringuy
                  • Dec 2005
                  • 2750
                  Spoiler alert, before I bolted everything I test-fit a Tesla booster. Clears fine.
                  Note: All the cool kids are running the CR-V remote reservoir (there's a picture of an S54 car with that setup somewhere....) that gives even more room.
ID:	10078820 Click image for larger version
ID:	10078821 Click image for larger version
                  • hoveringuy
                    • Dec 2005
                    • 2750
                    I finally got the DISA-enabled ECU and had a chance for a quick test drive. What a hoot!
                    Next step is to put a few miles on it and take it to the dyno...
                    • hoveringuy
                      • Dec 2005
                      • 2750
                      Baseline dyno!
                      Good news and bad news...
                      The good news is that I've picked up 17 torques at 3100. Interestingly, both graphs have peak torque at exactly 3168. What are the odds? There's a 10-15hp boost all the way to almost 5000.
                      The not as good news is that the motor kinda dies by 6000, but nando quickly noticed that the torque curve doesn't have the characteristic torque peaks that other N52's have. INPA shows that the DISA valves are opening and closing, and I can hear them "click" but removing them showed that it was bound-up at best and then it was stuck closed, so two new DISA valves are in the mail (they're at risk of disintegrating at this age, anyway)
                      That's opportunity #1, number 2 is that the A/F until around 4500 was in the 15.5 range, so there's room for a better fuel map which should bump power. The thought of getting 270ft-lbs is just delicious, show me an S54 that makes 270 ft-lbs....
                      The dyno is something of a dick measuring contest, what's more important is how the car feels to drive and from 6th gear on the freeway to getting groceries it's awesome now, it sure feels like 262 ft-lbs.
                      Click image for larger version  Name:	Capture.jpg Views:	0 Size:	101.9 KB ID:	10083539
                      • moatilliatta
                        • 6157
                        What type of dyno? Are you Reving out to 7800?
                        @Zakspeed_US
                        • hoveringuy
                          • Dec 2005
                          • 2750
                          Not Dynojet, it's a magneto-resistance one that's supposedly calibrated to match Dynojet (there's a Dynojet up the road and they say cars are the same on the two)
                          Nice thing about this one is it's perfect for holding part-throttle load for data logging and fuel corrections.
                          We werent holding it that long because it was pointless.
                          • LukeJ
                            • Jul 2019
                            • 139
                            Dang it! haha. This is some good info here.
                            I guess I have some more work to do....
                            Thanks!
                            • DEV0 E30
                              • Oct 2004
                              • 8904
                              Thanks again for sharing and improving this swap for everyone else.
