Emma Watson and 2 E34's (Low Mount Turbo M50 Project)
  • Dj Buttchug
    • Jun 2010
    • 7686
    #466
    Originally posted by Hoffbrohaus
    When you did your leak check did you keep the charge pipe attached to the intake manifold or block it off? If you kept it did you just make sure your air compressor didn't go over 6psi? I'm just afraid of too much pressure going in to the engine.
    Left it all hooked up. I did the first leak check with a smoke machine. With the throttle plate closed I should be able to pressure the system up to 20psi or so to check for leaks. Works pretty good for 5 bucks.
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • Hoffbrohaus
      • Sep 2013
      • 519
      #467
      Also your reflective heat tape on the charge pipe, where did you buy? DEI looks expensive. I saw Panici running it too. Guessing I'll want that here in Phoenix when it hits 120F.
      '90 325is
      • Dj Buttchug
        • Jun 2010
        • 7686
        #468
        Its all over ebay and amazon. That is where I got mine.
        Ig:ryno_pzk
        • moatilliatta
          • 6152
          #469
          By the way, what a great view to welcome you while walking outside.
          @Zakspeed_US
          • Dj Buttchug
            • Jun 2010
            • 7686
            #470
            Utah is a beautiful place to live that is for sure.
            Ig:ryno_pzk
            • Dj Buttchug
              • Jun 2010
              • 7686
              #471
              Pic dump. She dusty but w/e
              Ig:ryno_pzk
              • Panici
                • Dec 2009
                • 2558
                #472
                Spare engine for $100, can't beat that! Cheap insurance for piece of mind.
                Such a classy looking car, inside and out.
                • Dj Buttchug
                  • Jun 2010
                  • 7686
                  #473
                  IC spray version two here. Much cleaner with the delrin knob.
                  Ig:ryno_pzk
                  • zwill23
                    • Jul 2015
                    • 615
                    #474
                    This car is really satisfying, from an interior / exterior perspective I don't know how it could be more subtle given how much its been modified. The intercooler sprayer install is bitchin'
                    I was curious how you like the self-centering shifter, I'm always tempted by body mount shifters to try cleaning up the internal G260 trans slop, but I'm hesitant to install solid / poly trans mounts. Trying to thread the needle of keeping the car enjoyable on the street with "race car" parts. Though, even with solid mounts I imagine the E34 masks vibrations a bit better than a E30.
                    • Dj Buttchug
                      • Jun 2010
                      • 7686
                      #475
                      Thanks for the comments. Its been a long hard build ha.
                      I always have run OEM mounts on all my cars because they are all street driven. I did have to upgrade to poly subframe mounts in my e30 due to OEM parts failing constantly. Poly mounts definitely make things louder. The difference is substantial. This self centering shifter is actually really nice. It is a bit notchy but I enjoy the feel. Expensive for what it is but it will definetly remove ALL slop in a shift linkage. There is zero play in the assembly and it has a wide range of adjustment. Worth the $400+ in my opinion.
                      Ig:ryno_pzk
                      • Dj Buttchug
                        • Jun 2010
                        • 7686
                        #476
                        Installed new blow off. Sounds nice. (Ignore shitty tig welds. The aluminum was not cooperating for whatever reason)
                        Catch can setup to keep the few watery oil drips from my crankcase vent off the driveway and garage floor. Nice location using old airbox bracket and factory crankcase nipple under the intake.
                        Ig:ryno_pzk
                        • 2mAn
                          Señior Mod
                          • 21005
                          #477
                          Love this car... so dope
                          Simon
                          Current Cars:
                          -1966 Blue Boat
                          -1969 Red VW
                          -1986 White BMW
                          -2006 Green Thing
                          Make R3V Great Again -2020
                          • zwill23
                            • Jul 2015
                            • 615
                            #478
                            That's good feedback, I appreciate it!
                            • varg
                              Florida Turbo Man
                              • May 2014
                              • 3427
                              #479
                              I had the bubblegum weld problem putting my BOV flange onto my pipe too, with the generic BOV I just assumed the quality of the material they made the coped flange out of was terrible and causing me problems. Looks worse than yours for sure. What's with the screw in the fitting on the intercooler end tank?
                              IG @turbovarg
                              '91 318is, M20 turbo
                              • Dj Buttchug
                                • Jun 2010
                                • 7686
                                #480
                                Yeah I may redo it at some point but its alright for now. That ghetto screw is a plug for a IAT sensor location that comes factory with the volvo intercooler. I need to fix that lol
                                Ig:ryno_pzk
