Panici's '87 325is E30 - Boosted In Bronze
  • Panici
    • Dec 2009
    • 2535
    #106
    May 2/16
    Weather is finally warming up. It was about 12c today so I got a little work done in the afternoon.
    • Washed the car for the first time this year.
      • I can't believe how dirty the car got sitting under the cover. Going to buy a better one for next winter.
    • Took off hood blanket and found some rust on the hood.
      • Going to deal with the rust and fabric paint the hood blanket while I have it off.
    • Tested out some 3M aerosol adhesive remover on the cosmoline.
      • This worked pretty well, but still required wiping off the cosmoline.
      • I am going to test it with the powerwasher next time I am cleaning.
    • Got my Alpina Recaro seat I sourced from Germany.
    Sneak preview of the Recaro. More information and pictures to come!
    May 3/16
    • Took the front bumper off as well as all the trim
      • Luckily there is no more rust under here. Valance looks to be in great shape!
      • You can clearly see the "shark nose" heritage without the diving board mounted.
      • Of course two of the bolts didn't cooperate and I had to cut them.
    • Made another front license plate delete.
      • This time I used the bandsaw and some precision. Much better then my reciprocating saw attempt.
    • Painted all the front bumper trim pieces with Duplicolor Bumper Coat.
      • I laid down 6 or 7 coats
      • Unfortunately, the UV damage / pitting still shows through. I was hoping the bumper coat was a higher build and would hide the damage.
      • When I tackle the rear trim, I'm going to try a high build primer first along with some sanding. I can always redo the front trim in the future if it bothers me.
    • I'm soaking the bumper and trim mounting hardware overnight in some rust converter. Anything that doesn't turn out nice will be replaced with new hardware (if I can find it).
    Prep consisted of a rubdown with Duplicolor grease and wax remover, followed by a wash with dish soap and water.
    3 coats.
    7 coats.
    May 4/16
    Mostly worked on my girlfriend's Jetta this afternoon. Had to take the front bumper off to change a headlight housing, and de-oiled the side-mount intercooler while I was at it. She pulled out the driver's seat and gave the interior a full clean, then she did some prep and paint on her DS fender rust.
    I did paint the E30's hood blanket with a can of Duplicolor Fabric Paint. I think I got 4 or 5 coats out of a single can. I bought a second can, but decided it wasn't needed. Hood blanket looks WAY better. Well worth the $14 and time to paint.
    I did literally zero prep to paint the hood blanket, as a spot test with just a cloth and water was already pulling the blanket fibers apart.
    I picked up some SS hardware to replace the stuff I cut from my bumper trim. Also grabbed some aluminum stock to make some iS airdam brackets.
    Before (back of the blanket, which was actually cleaner then the front):
    During (Front, one or two coats):
    After: see May 11 update post below for finished+installed pictures.
    • Panici
      • Dec 2009
      • 2535
      #107
      May 5/16
      Only had a little time to work on the E30 late this afternoon.
      Finally had some success removing the cosmoline from the engine bay!
      I realize this shouldn't be a huge deal, but if you look at all the earlier pictures of my engine bay in this thread, I think you'll see why I want all of this nasty stuff gone!
      I first removed my newly painted grilles, as I wasn't sure how this adhesive remover would affect the non-clearcoated trim paint.
      I then used a can of aerosol "3M Specialty Adhesive Remover - 38987".
      (Unfortunately this stuff removed my matching VIN tag from my hood, and the other underhood stickers are starting to peel. But worth it to remove this cosmoline.)
      Sprayed the stuff on an area, waited 5 seconds, then hit it with the pressure washer. Tough areas needed this done 3-4 times to get most of the cosmoline off.
      No rubbing or scraping needed with this method. However I suspect the stubborn areas will need some scrubbing during my next session.
      I paid special attention to the back of the hood (in prep for painting the rusty spots), and the front rad support area, which was terrible looking before.
      I then finished up by giving the entire car a quick wash, I didn't want any errant adhesive remover sitting on the paint.
      Little bit of Before/After with pictures from earlier in the build thread:
      May 6/16
      • Pulled the hood off and took care of the rust on the underside. Used Eastwood Rust Encapsulator. Eventually the parts not covered by the hood blanket will be colormatched. For now I just wanted to slow/stop the rust.
      • I made a first attempt at banging out the large hood dent (just using a hammer and block of wood). Made some careful progress but need to get my heat gun and give it a second attempt.
      • Started taking care of some rust spots in the bay and on the front of the car. Still have a LOT of them to tackle.
      May 9/16
      • Painted the last rusty spots around the front bumper area in preparation for the front trim and bumper going back on.
        • The plan is to continue the process down both sides of the car, until all the spots are covered.
        • When I paint the iS airdam and e28 spoiler, I'll also colormatch the visible spots.
      • Fabbed up an airdam bracket out of 1/8" x 3/4" aluminum stock, with just a vice and a hammer.
        • I used my partial bracket and filled in the blanks.
        • This took the better part of an hour to get all the angles right. My friend Kevin has a metal brake at work, he's going to have a crack at making me two more brackets.
      May 10/16
      Washed up the '87 325is airdam (from the previous owner), for the first time. The repair (after the PO hit a cat) seems decently well done, but I still have to address the missing side bracket on the silver half.
      I also split and washed the E28 335is heckspoiler.
      May 11/16
      • Took another shot at fixing the hood dent.
        • It's not perfect but it's much better then before!
        • Painted repair marks on the backside of the hood dent
      • Pulled out big dent in driver's side rear quarter.
        • I used my Go-Pro suction cup mount.
        • You can't even see where the dent used to be. Unfortunately now the dent in my driver's door looks quite bad.
      • Reinstalled front diving board trim.
        • It really bothers me that I didn't paint the reflector surrounds to match. I'm sure I'll have it apart again at which point I'll paint them
      • Repaired the two destroyed front trim screws. Used 2-part epoxy and some SS hardware.
      • Painted my ellipsoid trim rings with some duplicolor "chrome" paint. They aren't fantastic, but are better then before.
      • Found out the ballasts I got for free with my ellipsoids are shot.
        • Both HID bulbs that he threw in still worked when tested with some spare 50w ballasts I had lying around. I will probably run this setup until I retrofit in some nicer projectors.
      • Reinstalled my hood blanket, which was painted with Duplicolor Fabric Paint.
      May 12/16
      • Finished my front plate delete.
        • Stainless hardware. Filled the sides with hot glue to hold them down. (Should have done this before painting, the glue is slightly visible on the edge when installed)
      • Installed repainted front bumper trim. Installed front bumper on car.
      • Ordered rear wheel bearing removal kit.
      • Removed all four rear TA bushings in my spare set, using a combination of force and fire.
      May 16/16
      • Installed a new reverse light switch (FAE) on the Getrag 260.
        • I have reverse lights for the first time since the transmission swap!
      • Installed the 325e crank sensors into the trans bellhousing.
        • Essentially using them as blockoff plugs as the 325i motor uses the front crank sensor only.
      • Put in the battery, and started the car for the first time since it was put away last year.
      • Went for a drive, everything seems in order!
      • Going to DD the E30 for a while until I sort out some stuff with my Jeep. After that it's subframe refresh time!
      May 24/16
      • Have been DDing the E30 for a little over a week now.
      • I think my mechanical fan may be on its way out. Having temperature creep issues when stopped.
      • Did a reduced interval oil change today. Used Castrol GTX 20w50 dino oil and a Mobil 1 filter.
      • Gave the dash, center console, and other plastic+vynal parts a healthy coating of Vynalex.
      May 25/16
      • Dug up my under dash panels. This one was from my parts car.
      • Installed dash panel with random hardware I found. Still missing a middle screw.
      • Shot some clear on my ellipsoid rings. They certainly aren't "chrome" as the spray paint indicated, but they look better then before.
      • Ordered a 16" Spal 30101517 pusher fan
      The 16" Spal 30101517 was ordered as my fan clutch isn't working properly. Water temp is fine when moving, but rises when sitting in traffic.
      It was the same price, if not a little cheaper, then a new Sachs fan clutch.
      Some bonuses: It should make the front of the motor easier to work on, get rid of the parasitic loss of the mech fan, and work with my eventual M52 swap.
      • 2mAn
        Señior Mod
        • 20969
        #108
        nice, looking good! lmk when your parts arrive
        Simon
        Current Cars:
        -1966 Blue Boat
        -1969 Red VW
        -1986 White BMW
        -2006 Green Thing
        Make R3V Great Again -2020
        • cypriotgeeza
          • Jun 2015
          • 126
          #109
          Nice!
          Can't beat a fresh engine bay! 8)
          "When Passion and Skill work together..the end result is often a masterpiece. ."
          Project Frankenstein :twisted: http://www.r3vlimited.com/board/showthread.php?t=359297
          • Panici
            • Dec 2009
            • 2535
            #110
            May 31/16
            • Bearing puller set came in the mail
              • Pulled the old wheel bearings out of my spare trailing arms, with ease
            • Attempted to fix the exhaust leak at the joint from my front to "catback" exhaust sections
              • Used some exhaust gasket maker.
              • The repair didn't last more then a few days. I assume the whole exhaust system is flexing too much because there is no center hanger.
              • The (reduced) weight of the system is supported only at the manifold studs and then at the rear muffler hangers
              • Once I have my own welder I'll be fixing this properly.
            • Finally tore into my sunroof, which I hadn't used all last year out of fear.
              • I'm very lucky that my sunroof cassette has little to no rust! Huge worry off my mind.
              • The one side of my sunroof panel was very rusty, and was responsible for the "rain" of rust when the sunroof was used previously.
              • I took the panel out of my parts car roof, cleaned up the rusty edges, and painted with flat black Eastwood rust encapsulator.
              • It's a poor paint job, but in my defense I was working with an almost empty can of rust encapsulator. I can't buy the Eastwood stuff here, but I have more on order to my friend's USA address.
              • I reused the seal from my silver panel for now.
              • There was also a small rust hole in the top of the panel, which I plugged with a trim plug and some black RTV. This is a poor repair, but will work as a temporary solution to keep the water out.
              • I am attempting to find a nice Lachssilber sunroof panel without rust to replace this one. It will get a brand new edge seal.
              • I also took some time to snake the drains, clean and grease the sunroof track, and repair some cracks with "plastic weld" in the rails.
              • My sunroof is now fully operational again!
            • I'm conducting some long-term testing on "DuPont's Rubber Saver". It claims to recondition and extend the life of plastic and rubber parts.
              • I've applied a heavy coat to my trunk seal, as well as the plastic trunk trim piece.
              • I also dabbed a single spot on my 2004 Jeep TJ's faded fender. It sits out in the weather all year, and will be a good test of how well this product actually "soaks" into the rubber/plastic.
              • I will update with pictures periodically. If I'm pleased with the product, and sure that it won't "dry out" seals similar to armor-all products, I'll apply it to the rest of the rubber on the car.
              • I should note, that the bottle claims to work for 5-6 automobiles, and I've used almost half of it already on just my trunk seal. I am probably applying it much too liberally.
            June 2/16
            • Replaced wiper blades, went with a 19" passenger side, and a 21" driver's side.
            • Swapped my TDA7492 "50w+50w" amplifier board out.
              • It was running into over-current protection and cutting out.
              • Replaced it with a TDA7498 "100w+100w" Class D board, and now it's able to be run loud without cutting out
              • Noticed driver's side tweeter isn't working, will need to investigate further.
            • Panici
              • Dec 2009
              • 2535
              #111
              June 3/16
              • Wrapped and tucked the modified radio amp harness.
                • Used OEM "tesa" cloth harness tape
              • Washed the car in preparation for a safety inspection tomorrow morning. Fingers crossed!
              • cypriotgeeza
                • Jun 2015
                • 126
                #112
                nice work man! :up:
                • Panici
                  • Dec 2009
                  • 2535
                  #113
                  Originally posted by cypriotgeeza
                  nice work man! :up:
                  Thanks! More to come.
                  • Panici
                    • Dec 2009
                    • 2535
                    #114
                    June 13/16
                    Subframe Refresh: Day 1
                    Finally started my subframe refresh today.
                    I've been following the DIY here:
                    BMW E30 rear subframe and subframe bushing removal and installation guide - with and without the special bushing tool.
                    I am still not happy with the jackstand location supporting the rear of the car, as I usually place the jackstands on the subframe. The spots do seem to be fairly solid rust-wise, at least. I have been placing the floorjack under the spare tire well when I am working. Just slight pressure through a piece of wood gives a third contact point and makes the car rock solid. With just the jackstands I was able to get some slight side-to-side motion with my standard "push hard to see if the car is stable" test.
                    Three of the four allen head body bolts stripped out, and luckily I had a perfectly sized bolt extractor to remove them. I will have to either get new bolts from the dealer, or source an equivalent size and grade bolt from a hardware store.
                    The guide wasn't overly helpful when talking about getting the subframe out with the driveshaft in the way. I ended up removing the exhaust heatshields and the entire shaft. I was able to squeeze it out around the front section of the exhaust, as I previously deleted the center resonator.
                    I'm going to be finding a lower mileage shaft or getting one of the u-joints replaced, because it has failed and is quite notchy. The slight driveline vibration at speed actually caused the front three driveshaft-to-giubo bolts to loosen up since I did the transmission swap last summer.
                    I had the subframe hang up on the driver's side bushing and refuse to drop. I ended up buying a short 5/8" bolt and notching the thread in four places, which allowed it to bite into the soft aluminum. I then made use of one of the old subframe bolts and hammered from above, with a large 9lb sledgehammer, until it finally came free.
                    On the passenger side, the rubber bushing completely separated from it's metal sleeve, leaving the sleeve stuck to the car. I'll look at removing this tomorrow using the same method.
                    Also, I just cut the e-brake cables rather then trying to remove them while the subframe was in the way. I have new ones to replace them anyways.
                    • Panici
                      • Dec 2009
                      • 2535
                      #115
                      June 14/16
                      Subframe Refresh: Day 2
                      Separated the major components of the subframe today.
                      I didn't mess about with the very rusty trailing arm bolts. I scraped off all the crusty rust, and then hit them with the propane torch. Along with plenty of PB blaster in the last few days, they came off without issue.
                      Discovered that my subframe has some major rust on the outer TA mounting points. I'm going to either have to find a local welder to get them reinforced, or find a replacement subframe.
                      Driver's side trailing arm off, showing the center locating pieces I had epoxied on in 2014. They were still solidly attached (enough to stop the spring from shifting should the suspension be completely unweighted)
                      Passenger side trailing arm off
                      Workspace at the end of the day
                      Bagged and tagged hardware
                      Replacement trailing arms compared to the ones that came off the car. Take note of how nice the brake dust shields are on the old arms. I will be reusing these.
                      Subframe and differential after cleaning up all the dirt and tools. That jack I made up when I did the transmission swap last year, came in handy again today.
                      And the downer for the day.
                      Very rusty outer subframe mounts for the trailing arms.
                      The area was packed with undercoating, which trapped water all these years, and rusted the metal away. Similar to one of my front spring perches, which I replaced back in 2014.
                      • efficient
                        • Feb 2012
                        • 3312
                        #116
                        Dang, that rear subframe looks bad. Hope you can find a decent used one.
                        • Panici
                          • Dec 2009
                          • 2535
                          #117
                          I found a used one, but the guy wants $150 for it. Plus he is a 3 hour drive away (in each direction).
                          So I decided to attempt to fix my existing subframe. My friend Kevin found a good deal on a new Lincoln Electric Easy-MIG 180, and we split the cost. He is looking into a gas setup, and already has welding gloves and a helmet. Meanwhile, I've wired my garage up with a 30A 240v circuit, and a plug for the welder.
                          I'll need some major practice before I attempt to weld my subframe, but that's ok because there is a lot of other rear-end refresh stuff to be done meanwhile.
                          I powerwashed the rear differential, subframe, and wheel wells. It did a decent job of taking off the undercoating, but I'll have to finish up by hand.
                          I also took some comparison pictures of my 14" iS, 15" iX and 15" Euro basketweaves.
                          • 2mAn
                            Señior Mod
                            • 20969
                            #118
                            Are you planning on adding the subframe adjusters & camber correctors?
                            Simon
                            Current Cars:
                            -1966 Blue Boat
                            -1969 Red VW
                            -1986 White BMW
                            -2006 Green Thing
                            • Panici
                              • Dec 2009
                              • 2535
                              #119
                              Nope.
                              The car will never be low enough to justify the hassle and cost.
                              I've also heard from Spec E30 guys of the toe adjusters suddenly loosing adjustment mid-corner, or over the course of a race weekend.
                              I don't want to have to re-align the rear every season, so I'm not making it adjustable.
                              • Panici
                                • Dec 2009
                                • 2535
                                #120
                                June 28/16
                                Subframe Refresh: Continued
                                I'm behind in my updates, let's see if I can get everything in this post.
                                Updates not pictured below:
                                • Removed remainder of e-brake cables from body side (that I cut when I removed the subframe)
                                • Bought brake line "Bubble" flaring tool, brake line cutting tool.
                                • Bought 25 feet of COPPER 3/16" brake line, along with 10 new fittings.
                                  • This should be enough length to run a new hardline all the way to the rear from the ABS module, as well as all new hardlines on the subframe.
                                • I somehow lost my FEBI rear diff bushing. The Corteco one I then bought is 2mm too big. I need to source a FEBI bushing or pay the premium for a BMW one from the dealership.
                                Lessons in POR15 i've learned thus far:
                                • Prep metal as per instructions. This means mechanically removing scale, followed by POR15 degreaser, and then POR15 Metal Prep.
                                • Use thin coats. When applied thick the POR15 doesn't cure properly, and the subsequent 2nd coat bubbles up when applied.
                                • Expect any surface which makes contact with POR15 to bond with it. This means if you paint on cardboard it will be STUCK to the surface.
                                  • I had to take the bottom of the TAs cardboard contact points back to bare metal and re-etch with POR15 Metal Prep because of the above.
                                  • I also have to touch up a couple more cardboard contact spots from when I painted the bottoms. (Didn't learn my lesson the first time.)
                                • Don't paint in direct sun or bright light, it makes it difficult to see what spots you've missed.
                                • Don't use cheap paintbrushes, they loose bristles and embed into your POR15 coating. You'll need one new paintbrush per coat, unless you spring for the special POR15 cleaning solvent.
                                Took off rear shocks and installed Turner Motorsport Rear shock mounts (HP Aluminum/Rubber)
                                Since I'm getting a lot of use from it, I sprung for some better wheels for my makeshift jack.
                                First round of differential cleaning/degreasing. Also prepped trailing arms for POR15.
                                POR15 on the topside
                                Second round of diff cleaning/degreasing. Also cleaned the brake dust shields which came off my old trailing arms.
                                Welder on modified tool cart (modified to fit the tank, allow the side panel to open, and the front cables to pass)
                                Cardboard stuck onto trailing arms after first round of POR15.
                                Had to grind back down to bare metal, and then re-etch with the POR15 metal prep. :|
                                Replaced rear differential side seals.
                                Second round of POR15 on the trailing arms (bottoms this time)
                                Edge of new diff seal started to tear/catch at one spot, so I pulled it out and put the damage at the top (where it won't be immersed in gear oil). I used some Curil T for good measure around the edge of this damaged seal.
                                New o-rings
                                Teeth in the diff all look brand new. I guess that Automatic transmission was good for something, no shock loads to the drivetrain!
                                Differential cover after cleaning
                                Pressed out old bushing myself using a vice and my wheel bearing removal kit (which I used earlier to remove the rear wheel bearings)
                                Painted the backing plates with two coats of Eastwood Rust Encapsulator. (Obviously both sides got two coats each)
                                Thin subframe tabs cleaned up in preparation for welding/reinforcing.
                                Rear underbody, still deciding how far I want to take cleaning this up.
                                Measurement of original diff bushing
                                Corteco bushing which DOES NOT fit.
                                To-Do list as of Jun 28. (Ignore terrible handwriting, the angle is awkward to write.)
