PNW Chit Chat thread
  • BraveUlysses
    • Jun 2007
    • 3781
    #36136
    If that rack is really the same as the Z3 1.9 short rack, you'll have a heck of a time driving it with a power steering delete.
    • 2mAn
      SeƱior Mod
      • 21049
      #36137
      Originally posted by imjusthere
      I need a blinker stalk for my e30. Anyone have a working spare I can buy? I keep forgetting to manually shut off my left signal and wind up driving around like an old lady.
      Its ~$25 for all the parts brand new from BMW
      Simon
      Current Cars:
      -1966 Blue Boat
      -1969 Red VW
      -1986 White BMW
      -2006 Green Thing
      Make R3V Great Again -2020
      • EN318isPDX
        • Oct 2007
        • 4373
        #36138
        Originally posted by ncsubowen
        Do you have to if you're non-airbag?
        Sent from my SAMSUNG-SM-N910A using Tapatalk
        He said M42 oil pan... So most likely its a late model airbag car
        • ncsubowen
          • Nov 2013
          • 1012
          #36139
          This is Toes. Don't assume he didn't swap an m42 into an otherwise useful e30 ;)
          4 doors.. so much room for activities!
          IG @bluebombr
          Transaction Feedback:
          http://www.r3vlimited.com/board/showthread.php?t=323622
          • Matt-B
            The Waffler
            • 3856
            #36140
            yea air bag cars need firewall modified.
            anyone that says they didnt, has it binding against metal, and has the boot covering hole, off , so you can see the road better...
            that is if its a airbag late model car, and not some m42 powered dodge flat bed
            • 5Toes
              • 9836
              #36141
              I installed the delete plate then pressure washed it. its fine.
              my 350mm momo monte carlo and no power steering is barely a challenge... much easier than my 325is mtech I 385mm without power steering. I think the car will be fine. I removed the splined shaft that goes from the steering wheel shaft to the lower knuckle, to make the mods on firewall easier.
              the racks are pretty damn close, Im just going to throw it on tonight. I measured the best I could but it is sorta difficult to get accurate measurements. I made an appt for an alignment tomorrow after work. Seems like the best way to go about it, Im sure the car will drive good enough to get to the shop.
              • djjerme
                • 5082
                #36142
                You know it's inevitable conclusion to this story.
                2016 Ford Flex
                • imjusthere
                  • Jul 2014
                  • 119
                  #36143
                  Sounds like the little plastic part on the steering wheel may be broken
                  I think it's the stalk. The white part that hits the wheel should be horizontal when either blinker is on. Mine goes up or down depending on which blinker is on. I believe the tiny springs in there are broken.
                  Are you sure? The stalk online is $180.
                  • 2mAn
                    SeƱior Mod
                    • 21049
                    #36144
                    Heres what I needed for mine
                    Minor update. When I installed the Italvolanti steering wheel, I didn't know and didn't install the slip ring so it caused my blinker to continue blinking until I manually returned it to the center position, but I also had what I call a "rage horn." Basically, if I pushed the steering in anger I could get it to honk. It would also happen when parking. Funny at first but got annoying. Here's some pics of the parts needed.
                    These tiny screws are expensive for what you get, but it's a solution that cost about $25
                    Might be worth looking to see if this alone is something that can be replaced
                    Simon
                    Current Cars:
                    -1966 Blue Boat
                    -1969 Red VW
                    -1986 White BMW
                    -2006 Green Thing
                    • 5Toes
                      • 9836
                      #36145
                      got it aligned and car feels great. some bump steer still but nothing crazy... I used the AKG rack spacers and placed them on top of the rack. had the alignment set to 0.00degrees toe.
                      and without power steering it is fine. another perk of the 16V :)
                      • spiDmang
                        • 3941
                        #36146
                        nicely done, kid :)
                        91' 318iS - S54/6MT Swapped
                        08' E90 M3 6MT - Daily
                        • 5Toes
                          • 9836
                          #36147
                          thanks brad! next project is new exhaust with Aarons help :)
                          • Matt-B
                            The Waffler
                            • 3856
                            #36148
                            Lol people at my job.
                            "Don't know if we can give you the 25/26th off.
                            Me: Yea but can't I call in sick 2 days in a row, no note, no doctor note.
                            Them: "yes"
                            • kid325e
                              • Sep 2007
                              • 6422
                              #36149
                              Lol wut?
                              Sent from my Nexus 5 using Tapatalk
                              clutchCTRL!
                              Move with a purpose.
                              - 1991 325iX 4dr/5spd
                              - 2000 323i AT
                              2016 Mazda CX3 Sport AWD
                              • car_gal_jenni
                                • Aug 2015
                                • 319
                                #36150
                                Brakes: bled
                                Clutch: bled
                                Rear seats: in
                                Oil change: complete
                                Almost ready for the exhaust shop tomorrow morning!!!
                                Current daily: 2003 Mitsubishi Evo (Isabelle)
                                Gone, but never forgotten: 2017 VW Golf R 6sp (Maria, sold)
                                1989 325i 5sp (Lorelei, sold)
                                1991 BMW 318is 5sp (Michaela; totaled)
                                2000 Mitsubishi Eclipse GS 5sp (Selena, parted out)
                                IG: mitsugal_jenni
