N52 Swap Discussion
  • Northern
    I like cupcakes & sh!tboxes
    • 5284
    #76
    Originally posted by digger
    It's still not very economical to 3D print a manifold that will actually last long term . Some of the less critical areas of the manifold would work fine. Bolting to the head no way. A Cnc or cast adapter is the way to go IMO depending on quantity
    We had a full (ie. from behind single throttle body to port) single-piece 3d printed intake for a CBR600RR in an old iteration of our FSAE car, probably ~2012ish. I think it survived 3-4 engines (~1 engine per year... lol) and seems to be in good shape after being thrown around the past 4 shops we've had. Seems at least as robust as an e36 intake. It was a sponsored part made by Realize Inc. I think they're super common now in FSAE. Sure it's not the same as 200k+ on a production engine, but I think there's a reasonable possibility it would last.
    I 100% agree that it's not economical though.
    Originally posted by priapism
    Originally posted by shameson
    • Motheye99
      • May 2018
      • 853
      #77
      Originally posted by Northern
      We had a full (ie. from behind single throttle body to port) single-piece 3d printed intake for a CBR600RR in an old iteration of our FSAE car, probably ~2012ish. I think it survived 3-4 engines (~1 engine per year... lol) and seems to be in good shape after being thrown around the past 4 shops we've had. Seems at least as robust as an e36 intake. It was a sponsored part made by Realize Inc. I think they're super common now in FSAE. Sure it's not the same as 200k+ on a production engine, but I think there's a reasonable possibility it would last. I 100% agree that it's not economical though.
      What was the material? I built my own printers and while they're not close to commercial printers. THey've got the capabilities for 400+c° prints.
      91' 318is 90' 325is
      Originally posted by Sonny
      Buy the E30s, they ain't gonna last long
      E30 can make you, E30 can break you
      "He who controls the Nova's, controls the Boomers"
      • digger
        • Nov 2005
        • 6212
        #78
        I'm interested in the material to. The complicated part is adding metal inserts for the mounting bolts to stop relaxation.
          • 34847
          #79
          Originally posted by The Dark Side of Will
          Why an adapter? It bolts up, why not port out the N52 head to match the throttles? The ports and, I @$$ume, the valves are smaller than S54's, but we don't yet know if the N52 head can be improved to perform closer to an S54 head. I suspect that someone looking to swap on S54 throttles could afford a head/throttle package.
          because a spacer (about 1" thick) is needed anyway in order for it to clear the OFH.
          • wazzu70
            • Jan 2005
            • 1143
            #80
            Material: http://www.windform.com/
            Example: https://www.crptechnology.com/intake...-xt-vm-motori/
            -Nick
            M42 on VEMS
            • Motheye99
              • May 2018
              • 853
              #81
              That would certainly work. I don't think I print that material. I really need to buy a s54 TB and get to work on this.
              91' 318is 90' 325is
              • Northern
                • 5284
                #82
                Our team has no documentation to go with it. There was a team reboot in 2015, and 99% of what came before that is gone.
                Here is their materials page: https://realizeinc.com/materials/
                I think they mostly did SLA in that era, but I don't know what resin. I think there has been some evolution in 3d printing since this was made too
                • wazzu70
                  • Jan 2005
                  • 1143
                  #83
                  Im 99% sure you don’t have a hobby laser sintering machine :) They are starting to make more affordable printers so its possible to have one at home. Definitely not the run of the mill 3D printer!
                  -Nick
                  M42 on VEMS
                    • 34847
                    #84
                    I was going to say - that looks cool, but sounds expensive.
                    • Motheye99
                      • May 2018
                      • 853
                      #85
                      I've used these before. They would even somewhat replicate the OE plastic intake manifold. Of course i'd have to heat them up a bit more for the filament I plan to use.
                      91' 318is 90' 325is
                      • Motheye99
                        • May 2018
                        • 853
                        #86
                        Its only a matter of time before we get a DIY SLS solution. Filament based printers have plateaued.
                        Defiantly a ways to go before i can make my own intake!
                        91' 318is 90' 325is
                        • jeenyus
                          • Aug 2011
                          • 2064
                          #87
                          I didn't know where else to pose this questions, so i'll post it here.
                          I noticed recently that the N54 is a rear oil sump. Would this mean that you could basically drop that into an IX? If you wanted to bastardize the IX and make it RWD with an N54 (because the front subframe is oriented further toward the front)? would that be possible you think (in theory?)
                            • 34847
                            #88
                            Yeah, I've test fitted it (N52 pan is the same). It fits really well.
                            • jeenyus
                              • Aug 2011
                              • 2064
                              #89
                              So the ix (ironically) is perfect for an N5X swap IF you're willing to become RWD? That's kind of crazy.
                                • 34847
                                #90
                                I've considered it. Just to get it moving... But really I just need time to build a motor.
