Criticize My Turbo Build Plan
  • NathanR
    • Dec 2023
    • 33
    Hi all,
    I've been working through sorting out getting my 1987 325e with an M20B25 prepped for a turbo. The car is reaching a point where it's pretty solid, so I'm starting to try to plan out how to go about getting some more power. Engine-wise, the M20B25 in the car had a fresh rebuild within the last 5K miles, and has a brand new head. I have attached my proposed build sheet, and have roughly selected the vast majority of components, but I have a number of questions to help point me in the right direction, and am generally looking for anything I may have missed or any criticisms to my plan thus far.
    My plan for the car is a target reliable 350whp (please let me know if I'm being realistic here). I'm not wanted to go super budget-build, but looking to do a mid-tier, and am open to alternatives that can help me save some cash here and there. My target for the build is under $7K, which I'm already exceeding without including a diff or any fabrication (I'm capable of doing all of the "bolt-on" work, but don't have the equipment nor the skills to do any fabrication. With that said, I'm aware that I'm likely going to need to increase the budget by a grand or two if I can't find some ways to cheapen it up without making it less reliable.
    Here's my questions (numbered to make the direct answers easier):
    1. What am I missing? Besides ignition, (see question 5)
    2. I have a number of turbo options listed here, but it's difficult for me to parse through each and make a decision, open to suggestions here, though I want to note that I would like something with a T51R Mod if possible (it's the inner child in me that requires this)
    3. Looking for information to help me decide on a wastegate from my included options or other suggestions.
    4. Looking for information to help me decide on a BOV from my included options or other suggestions.
    5. I currently have a 4.10 LSD that came with the car from factory. Are there options to regear, or is it better/cheaper to just sell the 4.10 and buy something else?
    6. What do I need to run a wasted spark setup?
    7. Do I really need to O-Ring the block? I don't mind doing it but buying the $400 Isky tool to use once bums me out a bit.
    8. What intercooler is suggested to use that allows me to keep A/C? I live in Central Texas, so A/C is a must.
    9. I have High Flow Cat in here just because the car is currently cat-less and my Fiancée hates the smell, but I don't want to add back pressure issues so if it's recommend to keep it as is, that's fine with me.
    10. At 350whp, am I going to run out of brakes? Given the car's existing lack of safety equipment, I'm happy to add a BBK, but ultimately it will push out the turbo build to fund it, which is fine, but would like to know now rather than later.
    I'm sure I'm missing a couple of questions here, so apologies in advance, but thank you for your help!
    Also if anyone wants to follow my build, I'm @shts_fkd_garage on Instagram!
    https://www.instagram.com/shts_fkd_g...l4ZmRsajFlbjh2
  • AWDBOB
    hooptie connoisseur
    • Aug 2013
    • 4442
    Buy a full kit from ClassicDaily. His kit retains A/C, uses Pulsar G30 copy you want to use, and you can get it all done in your budget, including ECU. It's not on his site, so you have to email.
    Suggestions:
    -Don't waste your $$ on a cam, stock cam is fine for a turbo car
    -Use an eBay FX clutch to save $$, they're great and I don't see them as a compromise.
    -Sell your s4.10 and buy a different limited slip and you'll have an almost even swap vs all the new diff setup costs
    -Buy the whole LS coil kit and ECU from ClassicDaily.
    -Head gasket is a fuse. At 350whp you should keep a stock gasket, if you're popping HGs something is failing so if you oring the block you have a higher chance of melting a piston instead of blowing a HG
    -I wouldn't worry about a hi flow cat hurting back pressure, non-issue
    -Stock brakes are fine with some nice pads/rotor/fluid
    -Their FMIC & piping kit is meant to work with A/C
    My buddy just did all of the above and his car has been incredible.
    His dyno results are here:
    • e30davie
      • Apr 2016
      • 1788
      What ecu is the classic daily based on? mega squirt?
      • jakeb
        • 1909
        No it runs FOME. Much better than megasquirt by todays standards.
        Deets here, https://www.classicdaily.net/collect...g-and-play-ecu
        1970 m42 swapped 2002
        1985 LS1/T56 Swapped e28 (557e)
        www.blunttech.com - For all your parts needs
        Follow me on Instagram for constant build updates @classicdaily
        https://www.facebook.com/ClassicDailyLLC
        • e30davie
          • Apr 2016
          • 1788
          Interesting, the onboard wideband controller and knock sensor are massive upgrades
          • NathanR
            • Dec 2023
            • 33
            Suggestions:
            https://www.r3vlimited.com/board/for...0#post10123560
            This is all super helpful!
            I did reach out and Jake gave me some great info, thanks Jake!
            Some follow up questions I have:
            1. I've removed the cam from my list, what about the rocker arms and valve springs? Will I be okay with just the new stock head?
            2. Do you have a link to the knockoff FX400? Or the brand name?
            3. What's the benefit of the LS Coil Kit vs. the Wasted Spark setup?
            • varg
              Florida Turbo Man
              • May 2014
              • 3374
              Your 4.10LSD is going to traction limit you, I went down in ratio immediately after M20 swapping because the power was useless in 2nd gear, and I had to pedal it the whole time. If you want to see how it all goes together with AC when not using a kit, take a look at my build thread, I have one of the few turbo E30s with AC. As for brakes I don't think you need a BBK. You're in flatland like me and unless you're going to track the car, you're not going to overheat the brakes. Not that there's a point in tracking a 350whp E30 without a ton of other mods so the power is actually useful.
              In my experience, avoid cheap clutches, especially kevlar ones if you want to ignore me and buy cheap anyway. Years ago my FX/F1 kevlar clutch became "sticky" as it warmed up and would not disengage from the flywheel when the pressure plate pulled back. Since that happened to me years ago, I have heard of it happening to others. Might not happen with weekend toy cars that see hardly any miles, but I was daily driving so the car was getting tested in all conditions.
              Lesson learned: Clutches are a huge pain in the ass when they go wrong, so buy a good one instead of chinabay stuff.
              IG @turbovarg
              '91 318is, M20 turbo
              • moatilliatta
                • 6136
                Terrible.
                @Zakspeed_US
                • AWDBOB
                  hooptie connoisseur
                  • Aug 2013
                  • 4442
                  My general rule of thumb is based on cam wear. If the cam isn't worn and the rockers match the cam I typically leave them. If you replace the rockers it's best practice to replace the cam as well and vice versa.
                  The cheapies people typically use are "FXRacing" brand, sold by gripforce-clutches on fleebay. Jake has the kevlar one in his car with a stock pressure plate. His car makes a little over 300whp and it's held up well.
                  He'll have a more educated answer than I will re: LS coils/WS
                  Good intel- I know many folks who have used the FX clutches over the years and haven't heard a bad account until now. But I'm sure no one I know has put them through DD paces. Like Garagistic parts..... they can't break if they're always in the trunk waiting to be installed
                  You've had good luck with Clutchmasters?
                  • AWDBOB
                    hooptie connoisseur
                    • Aug 2013
                    • 4442
                    Originally posted by moatilliatta
                    Terrible.
                    you still planning to turbo your home furnace and work van?
                    • varg
                      Florida Turbo Man
                      • May 2014
                      • 3374
                      You've had good luck with Clutchmasters?​
                      The only clutchmasters I've had is the 850 twin disc in my wagon. The spec stage 3+ in my E30 wouldn't disengage fully when new and now occasionally causes a vibration that goes away when I clutch in and back out slowly. It's easiest to reproduce that by popping the clutch in neutral, it'll almost always vibrate after that. I have a UUC lightweight flywheel and M5 clutch conversion waiting to go in my E30, probably this winter and if it's any good it'll be my top recommendation because it's pretty cost effective and the lightweight setup in my wagon is just so nice. Eminently blippable.
                      I do not abuse my cars, but I was always notoriously hard on parts because of the long commutes and daily driving. If something is going to rear its head with time it'll show up sooner with someone who is putting as many miles in a month on an old car as most do in a year. Now I have a much shorter commute, and I'm putting hardly any miles on my cars.
                      IG @turbovarg
                      • NathanR
                        • Dec 2023
                        • 33
                        • On the note of a clutch, I don't think I mind spending an extra couple hundred just to avoid needing to do it again if the eBay clutch gives up. In that case, is the FX400 appropriate? Or should I do like an FX300/FX350 or others? The car is daily driven-ish when the sun's out, I probably drive it 4-5k mi/year.
                        • On intercooler mounting, I assume I'll need to delete the oil cooler?
                        • While I’m at it, should I be planning on adding a catch can here?
                        • Don’t wanna let the LS coils vs wasted spark question die off here, any feedback on this one?
                        • Final dumb question for the day - how does timing work after the distributor is deleted?
                        • varg
                          Florida Turbo Man
                          • May 2014
                          • 3374
                          Timing works the same way as it does now, it's controlled by the ECU, the distributor is only there because there's one coil. Either wasted spark or sequential LS coils will be fine with this kind of power goal, choose what works out for you i.e. if you don't want to do some wiring use whatever there is a kit for. FWIW, you can run LS coils in the wasted spark configuration too, the difference between the two is one requires a cam sensor, and one doesn't. One configuration fires two coils at once, one fires one at a time. You don't have to delete the oil cooler, you can mount an aftermarket one somewhere. I have my stock one mounted to my core support, and it does still do some cooling there believe it or not. I've confirmed with a thermal camera.
                          IG @turbovarg
                          • Northern
                            I like cupcakes & sh!tboxes
                            • 5220
                            Blue flywheel of death
                            1: See below
                            2: I think pulsar G30 is the way to go for this power range. Will spool fast and give you lots of usable power but still gives you room to grow. P6262 is way too big.
                            3: I run a TiAl MVR as well, no issues but it's a chonky boi. I think any brand name is fine, BFG, Turbosmart, etc.
                            4. I would cheap out on a BOV. I have an ebay SSQV knockoff (comes with a flange and whatnot) and it has been fine. I prefer the TiAl Q sound though. Can buy pieces of charge pipe with the flange already welded on, and it's quite cheap.
                            5. I would try to sell the S4.10 or straight trade for a S3.73 since it should be the most common ratio, some NA track guy might be into that trade.
                            6. There are a few wasted spark options, but I think there's a thread here on a Bosch unit you can get from rockauto. I bought one of those GM V6 DIS and re-wired it (per some thread that's long gone on myE28 or E30tech) and it was jank. Don't need a cam sensor for this, but you need one for sequential spark with individual coils.
                            7. For 350whp you will probably be fine without Oringing the block. Get on the e30 facebook groups and look for people renting the tool for much cheaper, I think it's worth Oringing over other options if you end up popping HGs.
                            8. Can't comment, but just know the difference between tube&fin and bar&plate intercoolers and be able to identify them, and you can probably pop the valence off, install the bumper, and be able to measure what clears.
                            9. probably not going to impact power noticeably either way.
                            10. If the brakes work properly and your pads are a decent OEM brand like Pagid, Textar, etc, you're probably fine.
                            Charge piping is really easy if you run straight forward under the headlights.
                            Basically:
                            Turbo
                            Coupling to orient output toward highbeam
                            straight aluminum tube + BOV bung
                            90deg silicone coupler run under right highbeam
                            FMIC
                            90deg silicone coupler run under left highbeam
                            Throttle body boot.
                            Make tubes and 90 degree couplers whichever size they need to be to suit.
                            +1 to what others said, just run the stock cam for your goal. A good NA or turbo cam (like that bimmerheads one) will make power, sure, but that's when you need springs, rockers, etc. and the cost balloons. Can always go back and do it later.
                            I would run stock exhaust manifold gaskets, realizing you need to trim the head shields a bit. They'll help your wires last longer.
                            Exhaust hardware - I love the cheap "HFS" amazon vbands for exhaust stuff. Stainless, have locating groove, quick release, and all metal lock nut. Don't seem to warp as badly as the vibrant ones I used on the rest of my exhaust, which were 3x the price.
                            Clutch - I run the S52 FX Racing Stage 3 clutch on my 24v and have no issues. I have heard they blow up if clutch kicked, but hadn't heard of the "sticky" issue. Mine's been installed for 10 years, but I have maybe 10k km on it. it does chatter in traffic.
                            Wideband - big fan of the Spartan stuff. Seems cheap and good. The LSU4.9 version (spartan 2? I think) is "good enough" IMO. If the ECU can run a sensor natively, obviously do that.
                            manual boost controller - I wouldn't bother. Run it on spring pressure, change spring if needed. Eventually ideally have the ECU do closed loop boost control, or get something like a BFG G-force III if the ECU doesn't support it.
                            Oil filter housing relocation - don't bother. Loosen the oil filter housing and oil lines, rotate it until it clears whatever it doesn't. I don't think it's really an issue with the Kangaroo manifold.
                            Injectors - I ran deka 60s for a while and couldn't get the idle smooth. There are off-the-shelf 60lb-ish Bosch EV14s that IMO are better and not much more money.
                            ECU - no idea what Jake's current ECU is but it's probably fine. I would buy a wire-in Link G4X to ditch the stock harness/connector and run e-throttle and have a lot of future capacity for I/O, but maybe that's not a reasonable opinion.
                            Originally posted by priapism
                            Originally posted by shameson
                            • NathanR
                              • Dec 2023
                              • 33
                              Alright, thanks for all the input here. I've made a revision to my build sheet attached below.
                              Generally I think I'm looking pretty good here, Jake's kit seems the absolute way to go for me, including the 5455g, I also added some more odds and ends like a catch can, A/C updates, and tentatively going with Spec Stage 3 for the clutch.
                              Seems like every time I make good progress, more questions pop up though:
                              1. Since the top mount turbo will clash with my expansion tank on my early-model car, does anyone have a nice clean solution for a relocation or a new expansion tank? I know I can always fall back on a hacky bracket to mount it in the battery tray, was wondering what's the norm here.
                              2. Looking through gauge pods, at minimum I want to run boost and oil pressure, but the 3 gauge pods seem to fit best on the console, so for the 3rd, I'm open to suggestions here. Was going to fall back on voltmeter but maybe AFR? Wondering how that complicates things with the ECU and how useful it would be to me.
                              3. Jake's kit includes a cheap eBay BOV. The 5455g has anti-surge, so trying to weigh how much I should look into getting a higher quality BOV. If I decide to update a bit, may just do the PSR to keep things common with Turbo and Wastegate.
                              4. For some reason, I thought the SPAL aux fan was an improvement over the OEM one, doing some reading now, it looks like it’s actually worse, though difficult to find by how much. Jake suggested SPAL IX-30100399 (1032 CFM). I’m trying to see if there’s anything in the same package with higher CFM. A/C Solutions lists both 30101508 (1186 CFM) and 30102045 (1710 CFM). Mostly I’m worried my already weak A/C will get even worse.
                              For now, planning on holding out on purchasing parts until Black Friday hits to try to get some deals and do the build over the winter while it's not sweltering here in Texas. In the meantime, will do the supporting mods like clutch, aux fan, oil cooler delete, fuel pump, diff swap, etc.
