Emma Watson and 2 E34's (Low Mount Turbo M50 Project)
Also your reflective heat tape on the charge pipe, where did you buy? DEI looks expensive. I saw Panici running it too. Guessing I'll want that here in Phoenix when it hits 120F.'90 325isComment
Turbo M42 Build Thread :Here
Ig:ryno_pzk
I like the tuna here.
Originally posted by lamboButtchug. The official poster child of r3v.Comment
By the way, what a great view to welcome you while walking outside.
Spare engine for $100, can't beat that! Cheap insurance for piece of mind.
Such a classy looking car, inside and out.
'87 BMW E30 325is Turbo
'98 BMW E36 328iComment
IC spray version two here. Much cleaner with the delrin knob.
Ig:ryno_pzk
This car is really satisfying, from an interior / exterior perspective I don't know how it could be more subtle given how much its been modified. The intercooler sprayer install is bitchin'
I was curious how you like the self-centering shifter, I'm always tempted by body mount shifters to try cleaning up the internal G260 trans slop, but I'm hesitant to install solid / poly trans mounts. Trying to thread the needle of keeping the car enjoyable on the street with "race car" parts. Though, even with solid mounts I imagine the E34 masks vibrations a bit better than a E30.Comment
Thanks for the comments. Its been a long hard build ha.
I always have run OEM mounts on all my cars because they are all street driven. I did have to upgrade to poly subframe mounts in my e30 due to OEM parts failing constantly. Poly mounts definitely make things louder. The difference is substantial. This self centering shifter is actually really nice. It is a bit notchy but I enjoy the feel. Expensive for what it is but it will definetly remove ALL slop in a shift linkage. There is zero play in the assembly and it has a wide range of adjustment. Worth the $400+ in my opinion.
Ig:ryno_pzk
Installed new blow off. Sounds nice. (Ignore shitty tig welds. The aluminum was not cooperating for whatever reason)
Catch can setup to keep the few watery oil drips from my crankcase vent off the driveway and garage floor. Nice location using old airbox bracket and factory crankcase nipple under the intake.
Ig:ryno_pzk
That's good feedback, I appreciate it!
I always have run OEM mounts on all my cars because they are all street driven. I did have to upgrade to poly subframe mounts in my e30 due to OEM parts failing constantly. Poly mounts definitely make things louder. The difference is substantial. This self centering shifter is actually really nice. It is a bit notchy but I enjoy the feel. Expensive for what it is but it will definetly remove ALL slop in a shift linkage. There is zero play in the assembly and it has a wide range of adjustment. Worth the $400+ in my opinion.Comment
I had the bubblegum weld problem putting my BOV flange onto my pipe too, with the generic BOV I just assumed the quality of the material they made the coped flange out of was terrible and causing me problems. Looks worse than yours for sure. What's with the screw in the fitting on the intercooler end tank?Comment
Yeah I may redo it at some point but its alright for now. That ghetto screw is a plug for a IAT sensor location that comes factory with the volvo intercooler. I need to fix that lolI had the bubblegum weld problem putting my BOV flange onto my pipe too, with the generic BOV I just assumed the quality of the material they made the coped flange out of was terrible and causing me problems. Looks worse than yours for sure. What's with the screw in the fitting on the intercooler end tank?
Ig:ryno_pzk
