ForcedFirebird's m20 dyno thread.
This is a sticky topic.
  • 82eye
    • Jan 2009
    • 2108
    #136
    found it ! i gotta lotta reading to get back here though lol
    edit : love the thread. makes me wonder where i'd wind up. would be a dart toss of a guess and i'll probably never really know. be fun to see but i'm sure i might not like it lol.
    • FRODADDY
      • Feb 2012
      • 144
      #137
      I wonder what I will be seeing as soon winter is over and I get it tuned.
      My winter's project was the following:
      • M52B28 crank
      • 276° dbilas cam
      • 130mm maxpeedingrods
      • Early, catless pistons
      • Supertech valves
      • ported intake manifold and head
      • 3" all the way to the MAF (inclusive widened OEM air box)
      • late M30 MAF
      • enlarged throttle body
      • 19 pounds Ford injectors
      • OEM exhaust
      I just might have made an mistake in terms of the combustion chamber.
      In order to equalize the different chambers I mildened the edge of the squish area.
      1990 kashmir beige BMW e30 327i
      1993
      muggello rot BMW e36 M3 Gruppe A Euro
      1990 GP weiss Porsche 964 C2
      1997 schwarz II BMW e36 328iS supercharged
      • varg
        Florida Turbo Man
        • May 2014
        • 3430
        #138
        What's the resulting compression ratio? Stack height is 0.5mm less than stock, combustion chamber larger, how about the deck height/piston to deck clearance?
        IG @turbovarg
        '91 318is, M20 turbo
        • FRODADDY
          • Feb 2012
          • 144
          #139
          Compression ration should be in the realm of 9.5-9.7.
          1993
          • AWDBOB
            hooptie connoisseur
            • Aug 2013
            • 4508
            #140
            Got some fun M20 dyno stuff to share.
            Went back up to Jakes to dyno the 2.7 in my car, but more importantly, to convert my buddy Andrew's car (MT2 from post 105) to Jake's PNP M20 standalone and ITBs.
            For reference, Jakes dyno is comprised of a dynojet 248 48" roller powered by 3rd party Norwegian dyno software called "YourDyno".
            Andrews car on a regular ole Dynojet (SAE correction) in Oct of 2020 made a best pull of 178/179. See post 105 for that sheet.
            On Jakes dyno, Andrews baseline pull on the same setup as before was 167/164, compared to the dynojet best of 178/179 of 10/2020. The weather was great both days (in 10/2020 and on Saturday), so they should be relatively similar simulations, but still so many variables at play, so take it with a grain of salt. The dynojet vs jakes dyno comparison is valuable to me, because when we Dyno'd Linda my old 3.1L M20 on Jake's dyno, the numbers seemed lower than expected.
            Andrews car is a 3L M20 comprised of S52 crank/rods with 84mm flat top pistons, 9.3:1. Stock 885 head, IE billet 272 cam, BBTB, stock 320i exhaust with eBay catback.
            Andrew's 3L Stock vs Standalone conversion, where it ran out of injector on standalone:
            Andrew - Stock vs Standalone by Bobbie Morrone, on Flickr
            Andrew's 3L standalone vs RHD 42mm throttles, open trumpets. The car lost some mid range, but really picked up strong up top.
            Andrew standalone vs ITBS by Bobbie Morrone, on Flickr
            3L ITB open trumpets vs RHD Airbox. RHD airbox lost power up top and didn't gain down below. We were only spinning the car to 6300 on the open trumpet pull, would've made more pulling to 6700 like the pull with the airbox.
            with and without airbox by Bobbie Morrone, on Flickr
            My 2.7 (325e crank/rods, late model "i" pistons, deck shaved 2mm, unknown aftermarket cam, BBTB, stock exhaust, M50 injectors, MarkD chip) vs Andrews 3L on stock ECU:
            Andrew vs Boobie - Stock ECU by Bobbie Morrone, on Flickr
            My old 3.1L M20 (same dyno) with heavily ported 731 head with +2mm valves, 10.5 comp, 284/280 cam, stock intake mani, BBTB, Dbilas airbox, IE Long Tube headers vs Andrews 3L on standalone (no ITBS). Notice the mid range torque difference on the 3.1. 3.1 had a better pull that made 188, but this is just the one he had handy to overlay
            Andrew Standalone vs Linda by Bobbie Morrone, on Flickr
            My 3.1L M20 (same dyno) vs Andrews 3L on standalone WITH ITBS. I think the 3.1 would have some crazy gains with ITBs
            Andrew itbs vs Linda by Bobbie Morrone, on Flickr
            If he sends me any more overlays from the weekend i'll post them up. I blew up the clutch on my 2.7 first pull, so we didn't get to mess with it at all. I think there was still a lot on the table. Unfortunately i also found out my 2.7 was detonating a ton and I caught it too late and ruined my pistons, sadly. I will either build another 2.7 to get better data or go the 3L route but this time with an 885 head.
            Anyways, hope this is enjoyable for some. It's always interesting putting these big stroke M20s on the dyno, as they rarely do what the internet says they will. Small details are so incredibly important when trying to extract big power out of them. I'm just trying to get more actual data out there, since there is so little.
            Sucks that there are holes in the data but we only had a day to do all of this so we did the best we could. Really needed 2 days to get it all done. IE, each pull to the same RPM, putting injectors in the stock IM on standalone to see that test through, etc. Oh well, better than nothing!
            How much would the 3L gain with a free flowing exhaust? What would my 2.7 have made if it had a free flowing exhaust and standalone? What would a 3L make without crappy flat top lower comp pistons? How would a worked 885 head compare to the worked 731 head in the 3.1L?
            Hopefully I'll be able to answer these questions, over time.
            • It's Soda Not Pop
              • Jan 2022
              • 877
              #141
              You know what I never see dyno plots of? SETA's with a stock bottom end (seta crank, rods, and domed pistons) and a 885 head with a 272 or 274 cam. I always see the 2.7 with crank, rods, and "i" pistons or a m20 with worked over 731 head. Are the SETA 2.7i conversions that rare? I've never dynoed my car (I would love too). I would really like to see those numbers from a true SETA 2.7i build or one with a Bimmerheads head.
              I do know what this forum and the internet claim. I just never see any graphs.
              88' Seta 2.7i Zinno
              https://www.r3vlimited.com/board/for...430-my-88-seta
              • AWDBOB
                hooptie connoisseur
                • Aug 2013
                • 4508
                #142
                I've never seen a SETA dyno either. I have heard from folks who have done it that I trust, that they make the same HP as a stock m20b25, with slightly more torque.
                • jbontke
                  • Mar 2019
                  • 449
                  #143
                  Is this just a SETA block swap or is the combination tuned? Where the torque is made is important as well. You may see a max gain of ~15ft lbs at peak, but it may have gained more at a lower RPM.
                  • turbdan
                    • Sep 2023
                    • 6
                    #144
                    I've never dyno'd one without a turbo on it. They make good bottom end, similar midrange power and they roll over a little sooner than the B25 does on top. This is to be expected with the same intake manifold and the extra displacement.
                    With boost and a sufficiently large turbine, they hang onto peak power quite a bit longer. I have a chart somewhere with a GT35R at 1.4 bar. Stock B25 cam, super ETA bottom end, 2.5 head and intake. It may be too soon to try to post pics, I just signed up.
                    • It's Soda Not Pop
                      • Jan 2022
                      • 877
                      #145
                      I've been wanting ITBs for awhile now, but I miss my old turbo car. So I'm thinking of just refreshing my bottom end and hanging a snail on it. I have (in case you didn't guess by now lol) a seta with a 885 and 284/274 cam.
                      88' Seta 2.7i Zinno
                      • turbdan
                        • Sep 2023
                        • 6
                        #146
                        Boost has a lot of advantages. Can make a buttload more power than any NA build, with a stock cam, pleasant driveability and good mileage.
                        Are you already running standalone injection? That removes the main obstacle. If the motor isn't using oil and runs well I wouldn't worry about freshening up either. No need for all the foreplay, just get right in there and boost it.
                        I've never run a hot NA cam with FI. I did try the catcams mild turbo conversion cam. Not a bad option bit the B25 cam spools earlier and makes more power from the bottom up until about 5k. I don't know which I prefer.
                        • varg
                          Florida Turbo Man
                          • May 2014
                          • 3430
                          #147
                          I, too, like the idea of ITBs, particularly on a high revving engine. I gave up on that though. I estimated the price of a 280hp+ 2.8L ITB build for my car, because I don't want any more than 10lb/hp, and I arrived at well over $5,000 just in the ITBs and head (upgraded valve train and porting).
                          IG @turbovarg
                          • It's Soda Not Pop
                            • Jan 2022
                            • 877
                            #148
                            I've been going back and forth on what I want to do. I was sold on ITBs for last 2 years or so. But the power a turbo can give is hard to pass up. Plus overall it will be cheaper. I can always switch over to ITBs later down the road if I want. Or just buy another E30. I do have C10 that I need to work on as well.
                            88' Seta 2.7i Zinno
                            • NightOwl
                              • Jun 2014
                              • 78
                              #149
                              Bumping my favorite thread!
                              • AWDBOB
                                hooptie connoisseur
                                • Aug 2013
                                • 4508
                                #150
                                My buddy eight~deuce turbo'd his E30 got it tuned last week.
                                -ClassicDaily M20 Turbo Kit and ECU using Kangaroo Cast Mani and Pulsar G30-660 w/ .83 a/r open scroll T3 hot side
                                -Stock M20b25 with head studs and a cylinder head refurbishment
                                Pump graph: 14psi
                                Ethanol graph: 18-19psi
                                (dynojet rollers with YourDyno software)
                                Screen Shot 2024-07-13 at 9.23.49 PM by Bobbie Morrone, on Flickr
